Results 31 to 45 of 58
  1. #31
    91
    maybe in the next version
    for now just don't set game.enabled=1 in gamesettings.ini
    this won't stop it from hooking into every process, but the hook won't actually do anything ( except waiting until it is unloaded)
  2. #32
    June 2010
    48
    I cant make it work on win7 x64, with x64 ts3 client.... the executable just exit....I have problems with my own plugin too in the same configuration..
  3. #33
    June 2010
    48
    Great, the last version fixes some more issues. I like how I can configurate it.
  4. #34
    July 2012
    TS3 Notifier
    Notifier not work
    This thread was moved.
    Please use the search function first.
  5. #35
    91
    when I get home from work (only 3 more hours) I will create a new version, that works with the new ts3 version.
  6. #36
    July 2012
    Quote Originally Posted by cfxxl View Post
    Will it be available through the TSNotifier's menu clause?
  7. #37
    91
    you will have to download the version from my homepage.
    that button you mentioned has another purpose. it copies the helper plugins from your tsnotifier directory into your ts3 plugins directory (you only need this if you didn't use the installer and don't want to copy the plugin manually or if the plugins couldn't be copied during the installation e.g. because ts3 was still running and locked the files)
  8. #38
    July 2012
    I have now Notifier version 1.5.2. Should I download earliest version?
  9. #39
    91
    1.5.2 is the most current version. you will to wait until 1.5.2a(or maybe 1.5.3, depends on my mood^^) is available. just check my homepage http://tsnotifier.cfxxl.de or follow me on facebook http://www.facebook.com/TSNotifier
  10. #40
    July 2012
    I hope Your mood wiil be good))) and I'll soon see my friends in TS channel while playing))
  11. #41
    April 2010
    Montreal, Canada
    Cool TSNotifier info?
    Hi Everyone! where can i can get detailled info on TSNotifier, i've notice you can change position, font, size etc in the .ini.
    I'm using it in W U 7 64 bit and it's working perfectly, i want to fine tune it.
    Thank in advance
  12. #42
    91
    I already answered your msg on facebook
  13. #43
    January 2014
    TSNotifier Dont Work for My samp
    I installed TSNotifier In every Program it works
    And I even Dont Did 1 on Enable
    But In SAMP Its not WOrk
    And Its Show up only when I am Clicking on [X] (X Its my hotkey to speak)
    How to fix it
  14. #44
    January 2014
    [HELP] TsNotifier crashing GTA SA
    First of all, sorry for my english, i'm brazilian.
    Second, i dont know if there is the right place for posting it, i registered in this forum some minutes ago
    Please help me, when i'm playing samp if i press esc i cant return to my game, its stop working, if i press alt+tab my game stop working, i want to use tsnotifier for overlay, because the "original" overlay plugin dont works with my gta, i i want very much use overlay, so i wanna know if someone know how to fix it, in my ts sometimes i see a X and a atention icon, when i am using tsnotifer.
  15. #45
    91
    another user reported, that this http://hotmist.ddo.jp/plugin/mousefix/index.html helped him fix that problem.
