Results 1 to 2 of 2
    February 2010
    Seattle
    69
    Solved [Fixed?] sendPluginCommand defined scope still not respected
    This bug still persists within B25, with fresh TS3 installs and deletion of all client/identity data.
    cic: http://forum.teamspeak.com/showthread.php?t=55996
    Currently, you are (assuming, it is not documented) able to specify a scope for a pluginCommand to be sent via sendPluginCommand(). However, TS3 does not respect the provided scope.
    Eg:
    ts3Functions.sendPluginCommand(ts3Functions.getCur rentServerConnectionHandlerID(), this->mCommandId, msg->getData(),
    PluginCommandTarget_CURRENT_CHANNEL, NULL);
    Broadcasts to *all* players on the server. no matter what channel they are in, all players receive this command.
    Repro steps:
    1. Register a valid plugin, with a valid command name.
    2. Setup the appropriate plugin callbacks
    3. Have 2 clients on a server, in seperate channels
    4. Call sendPluginCommand with PluginCommandTarget_CURRENT_CHANNEL
    5. See that all clients still receive the plugin command via ts3plugin_onPluginCommandEvent
    Krün, Germany
    510
    You are right, there was still a bug with the sendPluginCommand function in the client. Should be fixed now.
  1. Question regarding sendPluginCommand
    By MadStyleCow in forum General Questions
    Last Post: September 11th, 2013, 11:34 PM
  2. [Resolved] set3DWaveAttributes does not seem to be respected when playing files
    By jaynus in forum Bug Reports [EN/DE]
    Last Post: February 25th, 2011, 05:51 PM
  3. [Resolved] 3D Sound and Attenuation set via API's is not respected
    Last Post: January 25th, 2011, 07:48 PM
  4. [PLUGIN API] sendPluginCommand SCOPE is not respected
    By jaynus in forum Client Plugins / Lua Scripts
    Last Post: July 2nd, 2010, 03:09 AM
