Results 16 to 30 of 57
  1. #16
    Taiwan
    313
    if you failed to read two post up, I can't really help you :P
    @GMT2000
    Great idea, I'll go ahead and code that in
  2. #17
    Germany, Cologne
    1,358
    Ooooops.
    I think i was in Thoughts.
    But i've already updated after your 1.2 Release and see that's work.
  3. #18
    April 2010
    Sweden, Kungälv
    29
    chat message
    I can only write:
    Just a Massmessage test. dont
    when i want to write something longer:
    Just a Massmessage test. Dont worry, this is not spam.
  4. #19
    Taiwan
    313
    because of the limitation of the amount of variable that the plugin can take, please change your spaces into \s, and it'll be solved.
    eg:
    Change it to
    Just\sa\sMassmessage\stest.\sDont\sworry,\sthis\si s\snot\sspam.
    and it should work fine.
  5. #20
    GER
    94
    works, thx
  6. #21
    Germany, Cologne
    1,358
    Please update this Plugin!
    MP and so on won't work now...
  7. #22
    Taiwan
    313
    Quote Originally Posted by SmokinShark View Post
    odd, I just tested it with "/lua run mp test", and it poked everyone
    and I'm using 3.0.1
    what command did you execute?
    and did you check to enable the chancontrol module inside the lua plugin settings?
  8. #23
    Germany, Cologne
    1,358
    Yes, with 3.0.1 it's work.
    But it hasn't work on 3.0.0.
  9. #24
    January 2012
    Quote Originally Posted by willy_sunny View Post
    eg:
    Change it to
    it dont work:
    <07:34:10>"mhimmel": Just\sa\sMassmessage\stest.\sDont\sworry,\sthis\si s\snot\sspam
    Do u have an idea, why it dont works?
  10. #25
    December 2010
    Europe
    download link doesn't work for me
    http://www.ts3chinese.com/downloads/...trolmodule.zip
  11. #26
    Taiwan
    313
    Wow, didn't realized there's alot of people enjoying my plugin
    So, to thank you all for still using it, Just a sneak peek.
    I'm adding context menus + more mass control options
    Stay tuned on this thread
    PS: apparently TS3 provides no way of giving pop up input boxes for Developers to get input via lua scripts =\
    So I'm going to use an alternative method, stay tuned
  12. #27
    April 2010
    England
    22
    Would it be possible to recognise a string within quotes as one variable or similar to avoid the message length / number of variables issue?
    Also, your suggestion of using \s to avoid the max length doesn't work, TS may be escaping it and preventing it from being recognised as space.
  13. #28
    March 2013
    Hi I wanted to download the script needed for the control module so I can mass poke and move people in TS. The thing is I do not know what a script is and the link yu put for the script does not seem to work for me. Can you please tell me what the script is and how to download it.
  14. #29
    February 2009
    USA
    9
    Just an update, because I wanted a mass poke/message tool, this one still seems to work fine but the original link is broken. I found a copy on a server here: http://acre.unitedoperations.net/chancontrolmodule.zip
    I uploaded that same file (above) here as a backup: http://www.orderofatlas.com/permanen...trolmodule.zip
    Standard warning with all files that come from random places: This (afaik) isn't the original authors.
    It appears to be version 1.2
    Edit: apparently this now sets off the anti-spam system for large amounts of users, which makes it worthless for my actions. I'm going to try to modify the script if I can to fix this, but it'll be just playing with it in my free time, no promises I'll get anywhere.
    In the mean time, this script is now 3-4 years old. If anyone feels like updating/re-writing it, that would be amazing.
  15. #30
    August 2014
    Massive Control Channel permissions
    Hello Guys,
    I just installed Channel Control Module (http://forum.teamspeak.com/showthrea...Control-Module) and everything works just fine but I have a question.
    On my TS server I have rangs - Server Admin (me), and Admins.
    And at the moment, only I can uste that Channel Control Module, and I want to ask You, if there is a possibility to give permissions to my admin to use those commands too without downloading and instaling that script.
    Thank You very much guys
  1. [Release] Volume Control (Windows 7+ only) remake
    By Goreki in forum Client Plugins / Lua Scripts
    Last Post: August 28th, 2019, 01:40 PM
  2. [RELEASE]Return to Last Channel
    By Screech in forum Client Plugins / Lua Scripts
    Last Post: August 1st, 2019, 04:30 PM
  3. [RELEASE] foolower - foobar2000 volume control
    By rossmann in forum Client Plugins / Lua Scripts
    Last Post: February 21st, 2017, 10:22 AM
  4. problem with Mass Control Module
    By sphxt in forum Client Plugins / Lua Scripts
    Last Post: March 7th, 2013, 06:43 AM
