Results 46 to 57 of 57
  1. #46
    November 2015
    Mass Move
    I get this error when trying to mass move
    = Channel Control Module Version 1.3 by Willy_Sunny =
    Error running Lua function 'mm': ...ent/plugins/lua_plugin/chancontrolmodule/chancontrol.lua:90: attempt to index global 'vararg' (a nil value)
  2. #47
    November 2015
    What I did was open chancontrol.lua
    Edited the following:
    local password = ""
    print(type(arg))
    ---print(type(vararg))
    print(type(arg[1]))
    --print(type(vararg[1]))
    The line with varag just make it into a comment by putting --
    Just find line 90 Save and reload Lua should fix it.
  3. #48
    Taiwan
    313
    Sticky
    Quote Originally Posted by Zyxiel View Post
    local password = ""
    print(type(arg))
    print(type(arg[1]))
    Quote Originally Posted by samabenie View Post
    If you are encountering this issue, one of the possible reason is that you guys are still using the older version of the Channel Control Module, please upgrade it
    Because since one of the upgrade made the LUA plugin to take vararg instead of arg
    So yes, if you are using an older version and you want to continue using the updated version of the channel control, just do what Zyxiel did, replace every occuring string of vararg into arg, and problem solved.
  4. #49
    January 2016
    First, thank you for the script. Definitely going to use it!
    Secondly, is there a way to mass poke certain server groups, as I do not want to mass poke guests?
  5. #50
    June 2013
    Mod not working?
    This mod does not appear to be working with the 3.0.18.2 any idea when a fix will be out?
  6. #51
    April 2016
    Need this plugin to 3.0.19
    Need for 3.0.19
  7. #52
    Taiwan
    313
    Quote Originally Posted by destroyarch View Post
    Would be nice if you guys can point out the error it gives
  8. #53
    July 2011
    8
    Quote Originally Posted by willy_sunny View Post
    Error running Lua function: Function 'mm' not found
  9. #54
    June 2016
    Keep getting this error:
    "Error running Lua function 'mmsg': attempt to index a nil value"
    and
    "Error running Lua function 'mm': ...les/plugins/lua_plugin/masscontrolmodule/masscontrol.lua:84: attempt to index a nil value (global 'arg')"
    and
    "Error running Lua function 'mp': attempt to index a nil value"
    and
    "Channel ID = 5973.
    Error running Lua function 'mmp': attempt to index a nil value"
  10. #55
    August 2016
    Error running Lua function: Function 'mp' not found
    get that error when l try do mass poke or some other errors when l try do a command.
    lve followed the steps and made a chanmodul folder etc and extracted the fles lnto that. can u help plz?
    ive got the box ticked aswell
    --merged--
    when l try the commands l get a error. l want to mass poke /lua run mp hey guys
    but i get a error saying Error running Lua function: Function 'mp' not found
    ive checekd the lua plugin and made a chanmodule folder ln lua plugins folder ln teamspeak 3 and followed the steps
    any help?
    --merged--
    nvm fixed it
  11. #56
    August 2016
    since like 2 days ago my entire masspoke message dont show anymore, it only shows like the first 3-4 words anyone know how to fix this?
    (no it's not that the message is to long)
  12. #57
    December 2016
    I cant Mass Move
    alright, similiar with the plugin in this thread http://forum.teamspeak.com/showthread.php?t=56218
    the purpose of this script is to be able to gather everyone, or sending global announcement to everyone.
    We all know that it is possible to mass whisper to everyone in the server now (with the help of whisper to all in the whisper dialog)
    however, there are times where people who are not around, so they missed the message, then what?
    Here comes the solution for you, the mass move/message/poke script :d
    changelog
    ver 1.3 - fixed a lua update that removed the ... As arg issue
    ver 1.2 - included self check (so it won't poke/move/message yourself)
    ver 1.1 - added copyright text + mass message command
    ver 1.0 - initial release
    requirements
    1. Must be using client 3.17 or above (because of the new lua methods)
    2. Must have some ways to by pass anti-flood system (because mass poking + messaging would generate alot of spam)
    3. must have downloaded this script (duh)
    installation steps
    1. Uncheck the lua plugin in your plugins window (if you have it checked)
    2. Extract this zip into a folder named chancontrolmodule (all lower cased) into the "lua_plugin" folder in your ts3's "plugins" folder.
    To make it clear, here's an example. If you installed your teamspeak 3 in this directory:
    c:\program files\teamspeak 3 client
    then you'd extract this zip to this location:
    c:\program files\teamspeak 3 client\plugins\lua_plugin\chancontrolmodule
    3. Check the lua plugin again in the plugins window. Done
    usage
    /lua run mm - mass move - moves everyone (visible) to your current location
    /lua run mp <your message here> - mass poke - pokes everyone (visible) with the message supplied
    /lua run mmsg <your message here> - mass message - messages everyone (visible) with the message supplied
    /lua run mmp <your message here> - mass message + poke - pokes + messages everyone (visible) with the message supplied
    there's also a g (global) version of the command: /lua run gmm, /lua run gmp, /lua run gmmsg, and /lua run gmmp
    the differences is that if a global version of the command is executed, it'll subscribe all possible channel first prior to moving. Meaning, you can decided to just mass move a selective groups of user by utilizing the subscribing channel function.
    Feel free to comment on the script. And as for those who know how to code, the scripts are already supplied. Meaning that you can simply just modify the script to your own liking
    ps: oops, did i forgot to mention that ... You do not need to worry to update this script if ts3's api version get upgraded? because ts3 will update lua plugin for it automatically, and that's the beauty of this script :d
    hello my pluging cant mass move i dont know why can help me with?
  1. [Release] Volume Control (Windows 7+ only) remake
    By Goreki in forum Client Plugins / Lua Scripts
    Last Post: August 28th, 2019, 02:40 PM
  2. [RELEASE]Return to Last Channel
    By Screech in forum Client Plugins / Lua Scripts
    Last Post: August 1st, 2019, 05:30 PM
  3. [RELEASE] foolower - foobar2000 volume control
    By rossmann in forum Client Plugins / Lua Scripts
    Last Post: February 21st, 2017, 11:22 AM
  4. problem with Mass Control Module
    By sphxt in forum Client Plugins / Lua Scripts
    Last Post: March 7th, 2013, 07:43 AM
