Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
    Taiwan
    313
    [Release]Channel Control Module
    Alright, similiar with the plugin in this thread http://forum.teamspeak.com/showthread.php?t=56218
    the purpose of this script is to be able to gather everyone, or sending global announcement to everyone.
    We all know that it is possible to mass whisper to everyone in the server now (with the help of whisper to all in the whisper dialog)
    However, there are times where people who are not around, so they missed the message, then what?
    Here comes the solution for you, the mass move/message/poke script
    Changelog
    Ver 1.3 - Fixed a Lua update that removed the ... as arg issue
    Ver 1.2 - Included self check (so it won't poke/move/message yourself)
    Ver 1.1 - Added Copyright Text + mass message command
    Ver 1.0 - Initial release
    Requirements
    1. Must be using client 3.17 or above (because of the new Lua methods)
    2. Must have some ways to by pass anti-flood system (because mass poking + messaging would generate ALOT of spam)
    3. Must have downloaded this script (duh)
    Installation Steps
    1. Uncheck the Lua plugin in your plugins window (if you have it checked)
    2. extract this zip into a folder named chancontrolmodule (all lower cased) into the "lua_plugin" folder in your ts3's "plugins" folder.
    To make it clear, here's an example. If you installed your TeamSpeak 3 in this directory:
    C:\Program Files\TeamSpeak 3 Client
    then you'd extract this zip to this location:
    C:\Program Files\TeamSpeak 3 Client\plugins\lua_plugin\chancontrolmodule
    3. check the Lua plugin again in the plugins window. done
    Usage
    /lua run mm - Mass Move - Moves everyone (visible) to your current location
    /lua run mp <Your Message Here> - Mass Poke - Pokes everyone (visible) with the message supplied
    /lua run mmsg <Your Message Here> - Mass Message - Messages everyone (visible) with the message supplied
    /lua run mmp <Your Message Here> - Mass Message + Poke - Pokes + messages everyone (visible) with the message supplied
    there's also a g (global) version of the command: /lua run gmm, /lua run gmp, /lua run gmmsg, and /lua run gmmp
    The differences is that if a global version of the command is executed, it'll subscribe all possible channel first prior to moving. Meaning, you can decided to just mass move a selective groups of user by utilizing the subscribing channel function.
    Feel free to comment on the script. And as for those who know how to code, the scripts are already supplied. Meaning that you can simply just modify the script to your own liking
    PS: Oops, did I forgot to mention that ... you do not need to worry to update this script if TS3's API version get upgraded? Because TS3 will update Lua plugin for it automatically, and that's the beauty of this script
    Taiwan
    313
    oops. found a little bug in my script.
    Fixed it and re-uploaded it.
    Please re-download it if you have downloaded it previously.
    18,144
    works like a charm , but i made a bad mistake.
    I opened poke and message on public server and the client hang around some minutes
    Taiwan
    313
    awe, I missed it D:
    should have been there watching dante poking everyone XD
    PS: oh, right. forgot to mention. if you were to use mass message method ... your client will ended up with tons of PM window (since current ontextsend event cannot be handled alternatively at the moment ... so, yeah =\)
    Germany, Cologne
    1,355
    Nice Plugin! It works.
    Is there a Way to send only mass Messagas (without Pokes) ?
    Taiwan
    313
    If you want, I could add that to the package...
    but be warned, using mass message will spam your client's tabs (especially when tons of users)
    that's why I didn't include it in the package.
    Added the package now with mass message only command /lua run mmsg <message>, as well as the gloabl version of it /lua run gmmsg <message>
    use this at your own risk. you could end up hanging your client for a moment like dante had already demonstrated.
    Germany, Cologne
    1,355
    Quote Originally Posted by willy_sunny View Post
    /lua run mmp make it too.
    Thx for including.
    Germany, Cologne
    1,355
    Is it possible to hide myself?
    So if i make a Mass Poke that i don't Poke myself too?
    Self with Message & Move?
    January 2008
    UK
    any chance of increased message limit?
    I got:
    = Channel Control Module Version 1.1 by Willy_Sunny =
    Channel ID = 21.
    == Mass poking & messaging 5 visible clients ==
    == Successfully poked 5/5 clients, and messaged 5/5 clients ==
    <09:45:29> "{UFP}Neo": pokes you: Teamspeak restarting in about 10
    what I actually said was:
    /lua run mmp Teamspeak restarting in about 10 seconds.
    Taiwan
    313
    Quote Originally Posted by Neology2k View Post
    I think this is a bug with the lua script taking the amount of arguments in the TS3 client itself. I'm able to reproduce it and can only give you this solution for now - limit your sentence up to 5 words
    /lua run mp 1 2 3 4 5 6
    <-- will stop at 5 instead of 6
    I'll report this back to Dante (stares )
    Germany, Cologne
    1,355
    No Answer to my Question? +.+
    United States
    23
    Red face
    Just FYI I think that can only done by Server admins by default
    Just throwing that out there
    Taiwan
    313
    Quote Originally Posted by SpWiRa View Post
    did that, and done
    Ver 1.2 is up for grabs
    November 2006
    NY
    34
    why dont you add support for serverquery style messages?
    when a command comes in, before you execute it, take the "message" parameter and run
    msg = string.gsub(msg, "\\s", " ")
    on it. thus you can use \s for spaces just like in serverquery
    Germany, Cologne
    1,355
    So i ask this again..
    Hope i get now a Answer..
  1. [Release] Volume Control (Windows 7+ only) remake
    By Goreki in forum Client Plugins / Lua Scripts
    Last Post: August 28th, 2019, 01:40 PM
  2. [RELEASE]Return to Last Channel
    By Screech in forum Client Plugins / Lua Scripts
    Last Post: August 1st, 2019, 04:30 PM
  3. [RELEASE] foolower - foobar2000 volume control
    By rossmann in forum Client Plugins / Lua Scripts
    Last Post: February 21st, 2017, 10:22 AM
  4. problem with Mass Control Module
    By sphxt in forum Client Plugins / Lua Scripts
    Last Post: March 7th, 2013, 06:43 AM
