One of our Server Admin has a hard time getting into the server. He needs to try numerous times to be connected (connected but no ping, unable to move and talk, "retrieving data" and after 10 sec. he is disconnected) but after 10-15 attempts usually he is successful and he can use the server with full permissions. This issue happens every day, it is reproducable for him every day so it's not a network problem. Today he was able to join for the first time but with crippled (?) privileges. He was not able to upload / download, move clients, ignore passwords but he was able to join to a channel with "Needed join power = 75" for example. Please look at the screenshot, he was asked for a Channel Password although he is a SA. Please look at the "Last Connected" field too, it shows an incorrect time. (server: beta 28-pre). After serveral reconnect, he gained the correct permissions automatically (we didn't change anything). As you can see from the screenshot he is a member of Server Administrator group only as we all are. (I'm too) In the Client log there are only these lines:
2010-08-16 20:29:45.843750 Info Logging started, clientlib version: 3.0.0-beta26 [Build: 12040]
2010-08-16 20:29:51.062500 ClientUI Info TeamSpeak 3 client version: 3.0.0-beta26 [Build: 12040]
2010-08-16 20:29:51.062500 ClientUI Info Qt version: 4.6.2
2010-08-16 20:29:51.062500 ClientUI Info Using configuration location: C:/Documents and Settings/Rendszergazda/Application Data/TS3Client/ts3clientui_qt.conf
2010-08-16 20:29:51.156250 ClientUI Info Last update check was:
2010-08-16 20:29:51.156250 Info Checking for updates...
2010-08-16 20:29:52.437500 Info Update check, my version: 12040, latest version: 12040
2010-08-16 20:30:30.843750 PreProSpeex Info Speex version: speex-1.2beta3
2010-08-16 20:31:29.031250 ClientUI Info Autoreconnecting...
2010-08-16 20:32:25.812500 ClientUI Info Autoreconnecting...
2010-08-16 20:33:17.250000 ClientUI Info Autoreconnecting...
2010-08-16 20:34:41.250000 ClientUI Info Autoreconnecting...
2010-08-16 20:35:37.093750 ClientUI Info Autoreconnecting...
2010-08-16 20:36:32.421875 ClientUI Info Autoreconnecting...
2010-08-16 20:37:27.765625 ClientUI Info Autoreconnecting...
2010-08-16 20:38:22.109375 ClientUI Info Autoreconnecting...
So no sign of a successful connection although he is on the server, he is able to speak, he has icons...etc.
