Results 1 to 4 of 4
    August 2010
    Romania
    ServerQuery Problem
    Well , i am new to this , and i barely understand what i am doing Sadly
    I start Server Query , and I enter this :
    login client_login_name=Tanix
    client_login_password=*password*
    -response:
    error id=0 msg=ok (50 ms)
    Total: 50 ms
    So far so good ... but then , when i try to turn off Web Server Listing :
    use sid=<serverID>
    serveredit virtualserver_weblist_enabled=0
    -response:
    error id=1540 msg=convert\serror (49 ms)
    Total: 49 ms
    What am I doing wrong ?
    February 2006
    Michigan
    21
    If you've set everything correctly server query wise you have the [RED] S icon next to your name.
    Then you only need to do this
    Open up Server Query [Don't worry about the Authentication tabs leave them blanks.]
    As you can see below i used the username & password that was generated for me when i first installed my TS3. Just change the password to yours and copy and paste it in and hit the green play looking button.
    login serveradmin mypasswordhere
    use sid=1
    Should work without error if you did it correctly. Takes 15 minutes to remove out of web list.
    August 2010
    Romania
    error id=2568 msg=insufficient\sclient\spermissions failed_permid=9030 (49 ms)
    Total: 99 ms
    I do have an S next to my name but it is not red :|
    May 2010
    6,310
    To change this parameter, you must be in Admin Server Query group.
    If you don't have the red S icon, your are not in this group.
    So, to change weblist you can use the serveradmin account.
    This account is create at the first start of you teamspeak 3 instance.
    If you create a new query login, this account have the same permission that your groups.
  1. ServerQuery Admin problem
    By MrStorm in forum Windows
    Last Post: December 14th, 2012, 01:12 PM
  2. ServerQuery Permissions Problem
    By LogicSequence in forum Permission System
    Last Post: November 26th, 2012, 05:11 PM
  3. ServerQuery Admin Problem
    By MrStorm in forum Off Topic
    Last Post: October 16th, 2012, 04:14 PM
  4. [Resolved] ServerQuery channel_icon_id problem
    By devour in forum Linux / FreeBSD
    Last Post: January 26th, 2012, 10:02 AM
  5. Problem with ServerQuery users.
    By Korxu in forum Server Support
    Last Post: June 5th, 2011, 11:34 PM
