Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    May 2008
    Luxembourg
    14
    Admin Server Query - insufficient permission modify power
    Hey there,
    I am in the Group Admin Server Query and can grant myself ServerAdmin etc, but I still get the message "Insufficient permission modify power" when trying to modify certain settings, why ?
    Catalunya
    2,350
    First check this:
    In the Channels Tree, click on your name, and look, in the rigt window, that says in Server Groups:
    - Normal ... ?
    - Guest ... ?
    - Admin Server Query ... ?
    - Server Admin ... ?
    May 2008
    Luxembourg
    14
    I removed myself from every group except for ADmin Server Query, I can join the others without a Problem.
    May 2010
    6,310
    What is your i_client_member_add_power in the Admin Query Group and the i_client_needed_member_add_power in the server admin group ?
    You can recreate the server admin group with the template.
    - Right click on Server Admin Template (3) and select "copy"
    - In target group select your actual server admin group
    May 2008
    Luxembourg
    14
    erm, how do I see those variables ? They are called differently for me in the Server Groups Panel ?
    But I think you guys misunderstand my problem: I can join whatever group I want as I am a member of the Admin Query group, taht works. My problem is, that even though I am in the Admin Query group, I cannot set certain settings, like Manage Icons etc as it tells me as I do not have the permission to.
    May 2010
    6,310
    Too see the same name permission, select "Show names" in bottom of the server group window. I think is "Show description" for you.
    When you have an error message you have also the perm id to show what permission miss in the group.
    To find the permission, you have "Filter" just on top of permissions list.
    To help you, you can use this spreadsheet :
    Permissions List
    The copy group information is the last solution to restore the group
    May 2008
    Luxembourg
    14
    Ok, I see the names now, the problem is: I cannot edit certain permission, like i_client_modify_power as it tells me I do not have the permission, but Admin Query Group is the highest group, isnt it ?
    May 2010
    6,310
    Yes it is.
    So :
    Quote Originally Posted by florian_fr40
    May 2008
    Luxembourg
    14
    I cannot find those ? o.0 there's only a handful of i_client properties, and none of them are these two ?
    May 2010
    6,310
    This permissions are :
    - in your server group => Group => Modify
    Have you set "Show granted only" ?
    If yes, unset to see all permissions.
    May 2008
    Luxembourg
    14
    ah, so you mean i_group_member_add_power and i_group_needed_member_add_power ? If so, both 100
    May 2010
    6,310
    Read my question please
    May 2008
    Luxembourg
    14
    Yes, read my reply, those properties are NOT present in my settings, they do not exist, i filtered with copy paste.
    I am using MySQL and the installation of the Teamspeak Database is quite old, one of the first publicly released versions, did the structure change in recent releases ? If so it might be better to start with a fresh db and recreate the sql structure?
    May 2010
    6,310
    Never mind,
    More simple :
    If you have make several updates you had make also a database updates like write in each changelog (I hope)
    Effectively you have right, the good action at this point is erase all old teamspeak instance, download the latest version and restart with new instance and new database.
    May 2008
    Luxembourg
    14
    Alright, almost done, but the thread http://forum.teamspeak.com/showthread.php?t=46779 is marked as outdated, how do I add myself to the server query group now ? I used that method back in the days.
  1. insufficient permission modify power server admin
    By John_55 in forum Permission System
    Last Post: September 14th, 2015, 11:24 PM
  2. Insufficient Permission Modify Power - Despite Server Admin
    By Prime55 in forum Permission System
    Last Post: December 23rd, 2013, 04:12 PM
  3. [Resolved] Insufficient Permission Modify Power as Server Admin
    By Sebi94 in forum Permission System
    Last Post: March 2nd, 2012, 12:06 PM
  4. Server Admin - Yet 'insufficient permission modify power'
    By guitar112993 in forum Permission System
    Last Post: September 3rd, 2011, 10:40 PM
  5. insufficient permission modify power As Server Admin
    By Lt-Fighter in forum General Questions
    Last Post: August 6th, 2011, 09:03 AM
