Results 1 to 3 of 3
    September 2010
    Maryland
    Help with channel latency
    I need help fast cause I have been messing with it for hours and cant fix it. I need to fix the channels in our ts cause they all got moved around and I can cause I keep getting this message and dont know what to do to let me make channels
    <21:54:45> insufficient client permissions (failed on i_channel_create_modify_with_codec_latency_factor_ min (12887/0x3257))
    New England USA / Marnbach, Weilheim i.OB, Germany
    425
    Set that value to 1. If you have it set to 75, note that that is a value that doesn't exist for channel latency. Channel latency settings go from 1 to 4, and those values may be used for this permission. If you set it to 4, users can't create a channel with a latency factor of 1. If you set it to 3, they can create a channel with latency factor of 4 or 3. Set it to 1 (being the minimum and best setting) and let us know if that fixes your issue! :-)
    September 2010
    Maryland
    Nope didnt work. I set it to 1 and this is what Im getting still
    <10:55:55> insufficient client permissions (failed on i_channel_create_modify_with_codec_latency_factor_ min (12887/0x3257))
  1. DPC latency (TS3 3.0.16)
    By KayZze in forum General Questions
    Last Post: October 24th, 2014, 07:45 AM
  2. Higher Latency
    By Gamestar in forum Client Support
    Last Post: December 28th, 2009, 10:42 PM
