Results 1 to 4 of 4
Thread: DOS udp_flood
    19
    DOS udp_flood
    Befor reinstall my Rootserver
    2010/08/10 21:11:05 -- [DOS][Block][udp_flood,
    >  timeout=10][83.169.21.216:9987->88.78.55.149:57719][UDP][HLen=20, TLen=108]
    >  2010/08/10 21:12:03 -- [DOS][Block][udp_flood,
    >  2010/08/10 21:54:51 -- [DOS][Block][udp_flood,
    >  2010/08/10 22:16:06 -- [DOS][Block][udp_flood,
    >  2010/08/10 22:22:01 -- [DOS][Block][udp_flood,
    >  2010/08/10 22:24:56 -- [DOS][Block][udp_flood,
    >  2010/08/15 20:28:47 -- [DOS][Block][udp_flood,
    >  timeout=10][83.169.21.216:9987->88.78.46.0:57776][UDP][HLen=20, TLen=108]
    >  2010/08/15 20:32:02 -- [DOS][Block][udp_flood,
    >  2010/08/15 20:40:28 -- [DOS][Block][udp_flood,
    >  2010/08/15 20:41:24 -- [DOS][Block][udp_flood,
    >  2010/08/15 20:46:49 -- [DOS][Block][udp_flood,
    >  2010/08/15 21:11:36 -- [DOS][Block][udp_flood,
    >  2010/08/15 21:32:47 -- [DOS][Block][udp_flood,
    >  2010/08/15 21:34:08 -- [DOS][Block][udp_flood,
    >  2010/08/22 21:28:18 -- [DOS][Block][udp_flood,
    >  timeout=10][83.169.21.216:9987->88.78.46.0:58303][UDP][HLen=20, TLen=108]
    >  2010/08/22 21:32:54 -- [DOS][Block][udp_flood,
    >  2010/08/22 21:46:03 -- [DOS][Block][udp_flood,
    >  2010/08/22 21:46:17 -- [DOS][Block][udp_flood,
    >  2010/08/22 21:54:06 -- [DOS][Block][udp_flood,
    >  2010/08/22 22:33:12 -- [DOS][Block][udp_flood,
    >  2010/09/03 19:09:00 -- [DOS][Block][udp_flood,
    >  timeout=10][83.169.21.216:9987->88.78.46.0:60192][UDP][HLen=20, TLen=108]
    >  2010/09/03 20:47:52 -- [DOS][Block][udp_flood,
    >  2010/09/03 21:41:26 -- [DOS][Block][udp_flood,
    >  2010/09/03 21:56:19 -- [DOS][Block][udp_flood,
    >  2010/09/03 21:57:09 -- [DOS][Block][udp_flood,
    >  2010/09/03 21:57:30 -- [DOS][Block][udp_flood,
    >  2010/09/03 21:58:25 -- [DOS][Block][udp_flood,
    >  2010/09/03 22:15:51 -- [DOS][Block][udp_flood,
    >  timeout=10][83.169.21.216:9987->88.78.46.0:60192][UDP][HLen=20, TLen=44]
    a day after i had make a cleaninstall of my rootserver
    2010/09/12 19:34:19 -- [DOS][Block][udp_flood, timeout=10][83.169.21.216:9987->88.78.52.23:49538][UDP][HLen=20, TLen=108]
    2010/09/12 19:34:30 -- [DOS][Block][udp_flood, timeout=10][83.169.21.216:9987->88.78.52.23:49538][UDP][HLen=20, TLen=108]
    2010/09/12 19:48:27 -- [DOS][Block][udp_flood, timeout=10][83.169.21.216:9987->88.78.52.23:49538][UDP][HLen=20, TLen=108]
    2010/09/12 20:02:20 -- [DOS][Block][udp_flood, timeout=10][83.169.21.216:9987->88.78.52.23:49538][UDP][HLen=20, TLen=108]
    2010/09/12 21:38:44 -- [DOS][Block][udp_flood, timeout=10][83.169.21.216:9987->88.78.52.23:49538][UDP][HLen=20, TLen=108]
    2010/09/12 22:07:04 -- [DOS][Block][udp_flood, timeout=10][83.169.21.216:9987->88.78.52.23:49538][UDP][HLen=20, TLen=108]
    Since the server was reinstalled and the attacks only the start of the port are set at the ts-server, I'll assume from the attacks of the ts-server from
    July 2002
    2,192
    this sounds like your "udp flood detection" is broken. Note that a TS3 quite usually sends 50+ packets per seconds to each client in a channel (whenever somebody is talking...). Disable or tweak your "udp flood detection" if it is triggering just because of normal activity (which it looks like it is).
    19
    http://83.169.21.216/flood.PNG
    This picture show my config for anti-flood control.
    how should I then set it to work normally
    I do not want to disable for guests
    237
    The problem is not related to the Teamspeak 3 anti-flood settings but to your servers firewall.
    Your firewall has an automatic attack detection that gives you a false positive due to the high number of UDP packets per second your server is sending through.
    If you know how to configure your servers firewall you will have to modify your settings so that either outbound traffic is ignored by the attack recognition or that the limit is above 50 packets per second.
    If you dont know how to configure your firewall, contact your hoster.
