Results 1 to 6 of 6
    May 2010
    Verona - Italy
    122
    Token permission
    A person trying to install on the server side TS3 Windows7x64 but once launched the exe of the server and copied the important information, go in his server and he hasn't the ability to click on "use token", what to do?
    May 2010
    6,310
    This is the fresh install or an update ?
    Info :
    "Use token" is on old client version. The client and server are the latest version ?
    May 2010
    Verona - Italy
    122
    fresh install
    May 2010
    6,310
    Very strange.
    For test, you can reset your database with this start command :
    ./ts3server_win64.exe clear_database=1
    You can try to add this permission by query command
    (with putty or TS3 client ServerQuery)
    login serveradmin <password>
    use <server ID> ("or" use port=<virtual server port>
    servergroupaddperm sgid=8 permid=8741 permvalue=1 permnegated=0 permskip=0
    February 2006
    Texas, USA
    4,143
    Try adding the server to your bookmarks,select the server and then putting the privilege key (token) in the options under MORE in the bottom left.
    May 2010
    Verona - Italy
    122
    solved, thx
  1. [Resolved] Channel Admin permission overwrite group permission
    By spyder25000 in forum Permission System
    Last Post: February 22nd, 2015, 03:25 AM
  2. [No Bug] Bug permission Asign and remove member (add user,manage token)
    By xVirus in forum Bug Reports [EN/DE]
    Last Post: February 18th, 2015, 03:39 PM
  3. Replies: 1
    Last Post: September 5th, 2011, 02:03 PM
  4. Token dont appear in permission
    By Arnobio in forum Server Support
    Last Post: July 15th, 2010, 11:19 PM
  5. Replies: 9
    Last Post: February 13th, 2010, 01:08 PM
