Since yesterday my microphone isn't working anymore from time to time, When i restart TS3 client. Yesterday i was able i was able to fix the problem with weird changing of the record streams, today there is not to do anything anymore that helps
Quote Originally Posted by client
2010-10-05 16:02:44.696315 Info Logging started, clientlib version: 3.0.0-beta31 [Build: 12451]
2010-10-05 16:02:44.705315 Query Info listening on 127.0.0.1:25639
2010-10-05 16:02:45.200315 ClientUI Info TeamSpeak 3 client version: 3.0.0-beta31 [Build: 12451]
2010-10-05 16:02:45.201315 ClientUI Info Qt version: 4.6.2
2010-10-05 16:02:45.201315 ClientUI Info Using configuration location: C:/Users/XXXXXXX/AppData/Roaming/TS3Client/ts3clientui_qt.conf
2010-10-05 16:02:45.679315 ClientUI Info Last update check was: Di 5. Okt 15:56:38 2010
2010-10-05 16:03:01.002315 PreProSpeex Info Speex version: speex-1.2beta3
2010-10-05 16:03:01.101315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:03:01.115315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:03:16.225315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:03:16.245315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:04:09.817315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:04:09.836315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:04:14.499315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:04:14.513315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:06:15.879315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:06:15.898315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:06:33.558315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:06:33.577315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:06:44.742315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:06:44.757315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:07:32.651315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:07:32.670315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:07:37.055315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:07:37.069315 ClientUI Warning Error opening capture device: could not open capture device
2010-10-05 16:12:36.554315 Bookmarks Info Disconnect, total time: 575 - 784369
2010-10-05 16:12:36.554315 ClientUI Info Connecting to next server...
2010-10-05 16:12:39.875315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:12:39.891315 ClientUI Error Error activating microphone: 2310
2010-10-05 16:24:37.402315 CapFMOD Error recordstart: Error initializing output device.
2010-10-05 16:24:37.419315 ClientUI Error Error activating microphone: 2310
And i use Windows Vista Business
