Results 1 to 7 of 7
    November 2010
    Spain
    Exclamation Problem Audio TS3+MAC HELP PLEASE :(
    Hi,friends.
    I would like to say first of all, forgive me if I do not understand I'm Spanish and my English is not very good, thanks.
    My problem is this ..
    TS3 installed smoothly, OK .. all users hear perfectly well, but when I speak I listen and if they do it with LAG.
    I tried to change everything in mac 10.6.4 and teamspeak, but will not let me do anything, and people just listen to me and LAG can not understand anything ...
    My ping is perfect, and my mac snow leopard is newly formatted ..
    The problem of hearing bad happens to me too in the configuration of the microphone teamspeak ..
    I'm going crazy, because I seem to remember that this problem when installing teamspeak 1 month ago I happened.
    Please! help me, forgive my language.
    November 2010
    Spain
    hi?? help please
    November 2010
    Exclamation
    i got the same probs. Fisrt i thought it could be my internet. Then iīve checked my micīs. Both are perfectly working. Iīve tested the micīs in several audio apps and got no problems. Only when i try to speak in TS (even in the voicecheck) it sounds laggy or echoing. I got these probs since the last update to the v3.0.0 Beta36 [Build12815] QT version 4.6.2.
    Iīm using Mac OS X 10.6.5 with the integradet mic on my MacBook or a external Presonus Audiobox USB with a t.bone sc400 mic.
    regards
    ralf
    November 2010
    US - Ohio
    21
    Same problem.
    There is a mac user who connects to my server who is having the same problem. She can connect without problem and hear everyone else perfectly fine, but when she talks her microphone cuts in and out really bad and nobody can understand what she's saying. She said she tested her microphone in other programs and that her mic worked fine so the problem seems to only be with the TS3 audio. Has anyone found a solution?
    November 2010
    France
    Users with Mac client have the same problem, they can listen but when they try to speak, they have big problems.
    We switch from the Teamspeak 2 and the old version works fine.
    His someone from the teamspeak team read this ?
    Best regards,
    Tumbac
    November 2010
    France
    Any news about this problem ?
    January 2011
    Hey guys, I sorted out my mic problem in TS3.
    1. Run /Applications/Utilities/Audio MIDI Setup.app
    2. Click on Built-In Microphone
    3. Under the Input tab make sure the Format is set to 44100.0 Hz, default is 96000.0 Hz which is seemingly incompatible with TS3.
    4. ???
    5. Profit
  1. Ts3 Audio problem with echo
    By MasterMoster in forum Windows
    Last Post: August 7th, 2014, 07:53 AM
  2. Input audio problem
    By Beanux in forum Linux
    Last Post: October 2nd, 2011, 09:37 PM
