Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
  1. #31
    May 2010
    6,310
    Quote Originally Posted by 114th_Fighters
    error id=257 msg=unable\sto\sbind\snetwork\sport
    This error message indicates that the 9988 port is already use (by teamspeak or another soft).
    Try with another port.
  2. #32
    April 2010
    Seattle Wa
    17
    Port 9988 wasn’t in use I did forward and check port 9988 and got the same message
    I changed the command line and port to 19988 and still get the same message
    TS3
    Welcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.
    login serveradmin xxxxxxxx
    error id=0 msg=ok
    servercreate virtualserver_name=TeamSpeak\s]\p[\sServer virtualserver_port=9988 virtualserver_maxclients=32
    sid=2 virtualserver_port=19988 token= 8AGf37tUNlkkhQrgWlwRYnQvhNPqRT9Q93OCPNXu
    error id=256 msg=command\snot\sfound
    I then changed port to 12002
    TS3
    error id=0 msg=ok
    sid=2 virtualserver_port=12002 token= 8AGf37tUNlkkhQrgWlwRYnQvhNPqRT9Q93OCPNXu
    I am sorry to be a pain
    I Just noticed I needed to change the port in 2 places
    TS3
    error id=0 msg=ok
    servercreate virtualserver_name=TeamSpeak\s]\p[\sServer virtualserver_port=12002 virtualserver_maxclients=32
    sid=3 token=Es6Gm89I+kbKUsjmnKlhU0fXuB0eONYuIgBvRotD virtualserver_port=12002
    error id=0 msg=ok
    This is New ?
    sid=3?
    Now Im really confused
    florian_fr40 Thank you so much for your Help We did it
    Thank you again for your time
    114th Fighters
  3. #33
    May 2010
    6,310
    Hum I have a doubt now
    So, please, to be clear could you use the the code tag ([ CODE]......[ /CODE] for the command that you use (only the command, not the server answer).
    Like
    login serveradmin ...........
    servercerate .....
  4. #34
    April 2010
    Seattle Wa
    17
    Pasted :
    ??? Did I do somthing Wrong?
    114th Fighters
  5. #35
    May 2010
    6,310
    error id=0 msg=ok
    Sound like you write youself the first line. Is it the case ?
  6. #36
    April 2010
    Seattle Wa
    17
    Quote Originally Posted by florian_fr40 View Post
    If I understand your question correctly
    I inserted My server token and forwarded the port 12002 and inserted the port in 2 places
    Other then those changes I used the line from the server query pdf
    114th Fighters
  7. #37
    May 2010
    6,310
    Please read the documentation :
    TeamSpeak 3 Server Query Manual.pdf
  8. #38
    April 2010
    Seattle Wa
    17
    Ok Thank You
    114th Fighters
  1. ServerQuery login problems
    By julsy in forum Permission System
    Last Post: April 16th, 2012, 12:16 PM
  2. [Resolved] Problems with serverquery rights
    By schiri22 in forum Permission System
    Last Post: June 19th, 2011, 05:40 PM
  3. ServerQuery Problems
    By DJBlackLight in forum Permission System
    Last Post: January 18th, 2010, 11:13 AM
