Results 1 to 8 of 8
    December 2010
    Canada
    Solved [solved] Voice activation lowers volume to about 25% temporarily.tem
    So, I've had this problem for a while, Every time someone or myself talks teamspeak feels it's appropriate to lower all the sound on my computer except.. You guessed it! Teamspeak, I've re-installed teamspeak many times, Fiddled around with ALLLLLLLLLLLLLL the settings, and I'm getting a little bit pissed off now because nothing I do does anything.
    February 2006
    Texas, USA
    4,143
    I assume you are running Windows 7. Go to Control Panel, Hardware and Sound and click on SOUND. Now select the Communications tab.
    December 2010
    Canada
    Before and After.
    This is before and after.
    And I am using Windows 7 x64bit Home Premium.
    18,153
    Please check this thead it will help you to solve this problem.
    http://forum.teamspeak.com/showthread.php?t=60315
    December 2010
    Canada
    That's not it, Like I said I've fiddled with every single option, even had my friends try it on they're client. Nothing has worked so far.
    December 2010
    Canada
    Nope.
    That one doesn't work, I've tried everything within my power to solve this problem
    November 2004
    74
    My bet, you should (re-)Configure Settings->Plugins->Volume Control Plugin
    (added the following to make forum search more effective )
    which has a description of:
    "Reduce volume of other applications when someone is speaking in your channel. On systems other than Windows 7 or newer only Winamp's volume is affected."
    Which means, with Windows 7 all applications are affected which is just like what you described. Additionally, it has configuration to reduce volume of other application when yourself are speaking.
    December 2010
    Canada
    Thumbs up Thanks
    Thank you, I guess I had not used all the tools within Teamspeak, I thank you so much, You have no idea how annoying that was to be playing a game all of a sudden, all the volume goes down and you can't hear anything for a couple seconds.
  1. [Resolved] TS3 lowers volume of other application
    By s4lfish in forum Windows
    Last Post: February 28th, 2019, 09:57 PM
  2. Replies: 3
    Last Post: July 16th, 2011, 03:13 PM
  3. [Solved] Voice Activation not working
    By Cally_Rexxar in forum macOS
    Last Post: September 23rd, 2010, 07:28 PM
  4. [Solved] Disabled Voice Activation on specific channels.
    By BimSekai in forum Tools / Web Based
    Last Post: July 30th, 2010, 09:36 PM
  5. [Solved] My talking lowers others volume
    By royalflushxx in forum Windows
    Last Post: February 8th, 2010, 11:09 PM
