Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 91
  1. #61
    June 2014
    Ts3 Server newbie, what am I doing wrong?
    Hello!
    Im new to setting up a server in Ts3 (have been using voice.teamspeak.com for a while but now I want my own server) and I just can't get it working. Guides online wont help me much so Im posting this here in hope for someone to be able to guide me through everything with setting up a server. My native language isnt Enligsh so excuse me if I express or explain myself wrong sometimes;
    I already have a fine working Ts Client.
    Im in win 7, 64 bit, so I download the 64 bit server 3.0.10.3
    After installation is complete, it pops up as an icon in the bottom right corner.
    Here is where I understand that I should get my WAN-IP from, but all it says when i mark WAN Ip is "request" and underneath that, it says "needs to be requested". Nothing seems to happen when i click on any of those.
    That above would be problem nr 1.
    Problem nr 2 is, okay, moving on with the server anyway since a WAN Ip is basically information that can be obtained everywhere. So I'm opening ports, all three of them, counter-check so that my ports are firmly open which they are, and I connect to my Ts3 server as "localhost". I am also able to connect with my router Ip, 192.xxx.x.xxx. I am however not able to connect to my server with my Internet Ip, 213.185.244.42
    <14:05:33> Trying to connect to server on 213.185.244.42
    <14:05:38> Failed to connect to server
    None of my friends are able to connect to my server, but we can all see my server in the "server list" in teamspeak connections. What have I done wrong? What more information do you need to be able to understand my problem better?
    Thanks for all the help and support I can get!
  2. #62
    2,698
    Quote Originally Posted by zepzoq View Post
    Question1: Don't worry. Lately the servers don't retrieve the WAN IP
    Question2: I've connected to your server.
    27/06/2014 16:09:39	ClientUI	Info	Connect to server: 213.185.244.42
    27/06/2014 16:09:39	ClientUI	Info	Blacklist check ok
    27/06/2014 16:09:39	ClientUI	Info	Initiating connection: 213.185.244.42:9987 213.185.244.42
    27/06/2014 16:09:39	ClientUI	Info	Connect status: Connecting
    27/06/2014 16:09:39	PktHandler	Devel	Puzzle solve time: 21
    27/06/2014 16:09:40	ClientUI	Info	Connect status: Connected
    27/06/2014 16:09:40	ClientUI	Info	Connect status: Establishing connection
    27/06/2014 16:09:40	ClientUI	Info	Connect status: Connection established
    27/06/2014 16:09:40	PermManager	Info	Requesting permissions from server
    Don't worry if you can't connect indicating the wan-ip to your server from your own LAN, this happens with some routers and maybe yours is one of that kind. Your friends should connect indicating the WAN-IP you have indicated --> 213.185.244.42
    As you can see in my client log, I've connected.
  3. #63
    February 2014
    39
    guys why dont u help me -.- <look above>
  4. #64
    December 2004
    RF
    3,006
    Because you're unable to read?
  5. #65
    June 2014
    PotaBlava - Thanks a lot! Good explanation and well, everything is up and running. Guess I did it right from the beginning ;-)
    Cheers!
  6. #66
    July 2014
    Wan IP Issues
    I know that this has been asked a ton before, but does anyone know the solution to finding the wan IP when it needs to be requested...?
  7. #67
    18,151
    Quote Originally Posted by Vitruvius View Post
    Really? The answer was already given.
    This is currently not available, but will be available again at a later point in time.
    It doesn't impact anything, your server will still work just fine, you only need to know your WAN IP or find it out yourself.
  8. #68
    February 2014
    39
    Help Please:::::::::::::
    In the past i was opening my teamspeak server easily but now when i opened it and pressed the right mouse key in the icon > Wan IP it says "Needs to be requested" , i've requested one but nothing happend , i can connect with localhost:9987 , but none can connect with my ip , Port Forward: 9987,30033,10011 and tried 2008 not working either! went to the server list searching for my server couldn't find it either in the past it was showing the ip and everything was perfect , but i dont know what happend
    Please Help Me ASAP
    Have a nice day
  9. #69
    July 2014
    Help!!! i cant find solution ... i can join the server with localhost ip address but nobody else can join the server ... i host from PC win7 64bit, in server icon on the toolbar appears "Request" and "Need to be requested" and i can do nothing i tryed to reset my routers settings to factory defaults and nothing ... These ports are forwarded 9987,2008,10011,30033. The firewall is okey ... so what is the problem? i cant understand :/
    LOG:
    2014-07-05 03:35:09.913000|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-07-05 03:35:09.915000|INFO |ServerLibPriv | | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2014-07-05 03:35:09.916000|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-07-05 03:35:09.916000|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2014-07-05 03:35:10.001000|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2014-07-05 03:35:10.125000|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2014-07-05 03:35:12.822000|INFO | | | Puzzle precompute time: 2666
    2014-07-05 03:35:12.854000|INFO |FileManager | | listening on 0.0.0.0:30033
    2014-07-05 03:35:13.045000|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2014-07-05 03:35:13.047000|INFO |Query | | listening on 0.0.0.0:10011
    2014-07-05 03:35:16.556000|ERROR |GetWanIP | | failed to retrieve WAN ip
    2014-07-05 03:40:31.319000|ERROR |GetWanIP | | failed to retrieve WAN ip
    2014-07-05 03:35:13.043000|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2014-07-05 03:52:56.832000|INFO |VirtualServerBase| 1| stopped
  10. #70
    April 2011
    1,266
    Quote Originally Posted by sp33der7 View Post
    Because there is none! The resolving WAN-IP routine in Teamspeak 3 is broken. Also it is an irrelevant "error" perhaps the devs should changed it to WARNING... You can just ignore it.
    P.S.: Also what I wanted to point out for a long time... This silly "request WAN-IP" function is only part of the Windows Teamspeak3-Server. I think it tells you a great deal about what the devs think about the knowlegde or skill of the common user running Teamspeak3-Server on Windows plattform.
  11. #71
    July 2014
    "Needs to be Requested"
    I have a server set up for personal use on my computer. Every time I try to find the WAN IP on the taskbar it says "needs to be requested" where it's supposed to be. I have a static IP setup, and I had the server working before, but one day it just stops working. This has been going on for the past month and I can't find any solution. I know for sure that the server used to work; I had all my ports forwarded and all of my friends could join. I can only join the server by typing in "localhost." No point since no one can join but me http://puu.sh/a2lmd/e751d3c053.jpg
    (I'm running windows 8.1 on i5 4670k)
    Server Logs: 2014-07-08 17:33:44.929124|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-07-08 17:33:44.930126|INFO    |ServerLibPriv |   | SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 64bit
    2014-07-08 17:33:44.930126|INFO    |ServerLibPriv |   | Using hardware aes
    2014-07-08 17:33:44.930126|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-07-08 17:33:44.930126|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2014-07-08 17:33:44.931127|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-07-08 17:33:44.950145|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2014-07-08 17:33:46.165310|INFO    |              |   | Puzzle precompute time: 1207
    2014-07-08 17:33:46.166311|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2014-07-08 17:33:46.202346|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2014-07-08 17:33:46.203347|INFO    |Query         |   | listening on 0.0.0.0:10011
    2014-07-08 17:34:26.492439|ERROR   |GetWanIP      |   | failed to retrieve WAN ip
    See here
  12. #72
    December 2004
    RF
    3,006
    That's an error in message categorization. "ERROR |GetWanIP" should be "INFO", means, it's a mere inconvenience.
  13. #73
    July 2014
    So how do I fix the issue?
  14. #74
    July 2014
    Never mind, the server just couldn't find my WAN IP. I just used PFPORTCHECKER to find it!
  15. #75
    6,078
  1. Replies: 2
    Last Post: July 8th, 2015, 10:39 AM
  2. [Resolved] Add "Channel" Text Location to "Sent poke" and back to "Received poke"
    By PatPeter in forum Suggestions and Feedback
    Last Post: May 9th, 2013, 06:09 AM
  3. Can I use "whisper" to enable a "Public" and "Private" channel?
    By DadisAjax in forum General Questions
    Last Post: June 28th, 2012, 11:59 PM
  4. Replies: 0
    Last Post: February 12th, 2011, 11:32 AM
  5. [Already Requested] Suggestion"Open in new tab" in bookmarks
    By IKShadow in forum Suggestions and Feedback
    Last Post: March 12th, 2010, 01:38 PM
