Page 6 of 7 FirstFirst ... 4567 LastLast
Results 76 to 90 of 91
  1. #76
    February 2014
    39
    Well, Teamspeak Staff members suppose to support their customers / ppl that are using Teamspeak Servers or clients
    But i see that we are not getting an assistance , i cannot open my server , therefore i know the ip im adding it it didnt work , dat Lack of Effort , Teamspeak Suppose to fix this issue ASAP or give us a vaild answer to fix it ,
    >Wan IP > Needs to be requested , Request didnt work , All ports are open it worked before.
    I know the ip , but ppl cannot connect using it i gave it to them tried to make a Domain not working also
    Tried to forward 2008 didnt work , what the fuck SHALL i do? teamspeak is important
    See how many replies i've made? and none answered
    Asking #1
    Asking #2
    Asking #3
    Asking #4
    Enough though! Respond to this! if your staff cannot answer appoint more staff members that are quallified to do thisss job ,
    Before Submitting any reply , read my previous replies as i explained everything in it
  2. #77
    6,080
    Hmm let's see... each and every post of yours, has received a reply but apparently you either ignored it, or are not capable of reading the tiny forum font...
    Request WAN-IP is purely informational and does not impact server functionality at all!
    This topic has NOTHING to do with whatever your problem is! You need to forward your ports correctly.
    Literally the post directly above yours points to the solution / explanation! Read before you post please!
  3. #78
    February 2014
    39
    lol , im not blind sir , tell me how can i fucking fix it -.-, i know the ip but when ppl try to connect using this ip they cannot connect is there anything in the files i can edit so it can get the ip?
    btw, the ports are forwarded correctly , and it was working in the past 9987 30033 10011 are open UDP and TCP
  4. #79
    February 2014
    39
    NEVERMIND working!
    No need for the WAN IP i just understood , Get the WAN Ip and connect to it worked
  5. #80
    December 2012
    6
    Question Wan IP -> need to be requested
    Can anyone help with that "Wan IP --> Need to be requested think?
    I forwarded 9987 UDP 10011 and 30033 TDP.
    No one can connect anymore to my Windows Teamspeak Server.
    Worked before. Changed Router and Modem, now it doesnt work anymore
    Regards
    Mark
  6. #81
    December 2004
    RF
    3,007
    Fix your router/modem settings, this has nothing to do with TeamSpeak, and your "problem" is completely unrelated as well.
  7. #82
    August 2014
    Wan IP: needs to be requested
    Hi, i have portforwarded my server, the portforward checker says that all my ports are open, but my server is not working, i cant connect. when i look at the server it says wan ip needs to be requested, any ideas how to fix? it would be good if i can sort this out quick because i am looking to host a server today
  8. #83
    18,273
    This feature was disabled and will no longer be part of server 3.0.11.
    -------merged-------
    Quote Originally Posted by ELITE_x_SCOPEz View Post
    i dont know what to do? i have tried connecting with localhost (failed to connect). my wan ip does not work either :/. i cant seem to find a solution. Please can someone help?!
    This has nothing to do with this thread. Check your server logs and open the ports, then read this
    http://forum.teamspeak.com/showthrea...annot-connect)
    Do not reply here!
  9. #84
    August 2014
    This has nothing to do with this thread. Check your server logs and pen the ports, then read this
    Do not reply here!
    It does have something to do with this thread.
    2014-08-12 12:37:28.124523|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-08-12 12:37:28.125523|INFO |ServerLibPriv | | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2014-08-12 12:37:28.125523|INFO |ServerLibPriv | | Using hardware aes
    2014-08-12 12:37:28.182031|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-08-12 12:37:28.182031|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2014-08-12 12:37:28.192532|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2014-08-12 12:37:28.218035|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2014-08-12 12:37:30.530829|INFO | | | Puzzle precompute time: 2292
    2014-08-12 12:37:30.805364|INFO |FileManager | | listening on 0.0.0.0:30033
    2014-08-12 12:37:30.931380|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2014-08-12 12:37:30.931880|INFO |Query | | listening on 0.0.0.0:10011
    2014-08-12 12:37:38.561979|ERROR |GetWanIP | | failed to retrieve WAN ip
    It says failed to retrieve WAN ip ^
  10. #85
    18,273
    As explained above "This feature was disabled"
    Everybody in this world with server 3.0.0 up to 3.10.3 will get this message.
    "I or other can not connect to my server" are off-topic.
  11. #86
    April 2011
    1,266
    well maybe if i had some help with my problem i wouldn't be
    "Failed to get WAN IP" isn't your problem, because this "error" doesn't cause any trouble. It is a just an old legacy function in the windows version of the teamspeak server. It never had any real function other than inform the windows users which external IP his server has at the moment.
  12. #87
    August 2014
    why then, cant i connect?
  13. #88
    18,273
    Because you ignore the answer.
    Do not reply here!
    Start reading. Thank you.
    Edit
    All new off-topics will be deleted without any warning!
  14. #89
    August 2014
    Cannot request WAN IP
    Hi guys, im trying to setup a port forward TS 3 server. I port forwarded the 3 ports but for some reason the WAN ip wont show up and i cant request it. Even if i press the button nothing happens. Help please :/
  15. #90
    September 2014
    Question Problem with WAN IP
    i have problem with my WAN IP adress..
    When i want to make TS server and when i go to small icon and want to see my WAN IP i get this "Needs to be requested"
    now how can i solve this ? Name:  Untitled.png
    Thanks,
    Snicker
  1. Replies: 2
    Last Post: July 8th, 2015, 11:39 AM
  2. [Resolved] Add "Channel" Text Location to "Sent poke" and back to "Received poke"
    By PatPeter in forum Suggestions and Feedback
    Last Post: May 9th, 2013, 07:09 AM
  3. Can I use "whisper" to enable a "Public" and "Private" channel?
    By DadisAjax in forum General Questions
    Last Post: June 29th, 2012, 12:59 AM
  4. Replies: 0
    Last Post: February 12th, 2011, 12:32 PM
  5. [Already Requested] Suggestion"Open in new tab" in bookmarks
    By IKShadow in forum Suggestions and Feedback
    Last Post: March 12th, 2010, 02:38 PM
