Results 1 to 5 of 5
    December 2010
    [Question] LUA Plugin: Using function calls from another lua instance
    Is it possible to use function calls and receive events from another lua instance (lcdhost in my example). For example when a person talks I would like the nick of that person to be passed on along with the notification that that event is taking place.
    Another not so directly related question:
    If that is not possible, is it possible to popen a file from within teamspeaks lua and have it write all the things that might be interesting to me and popen it from another lua instance to read it at the same time (I have the idea that windows doesn't allow files to be opened by two applications at once)
    April 2009
    italy
    44
    ++++++++++++++1
    September 2005
    Germany / Dortmund
    1,376
    Have a look at the clientquery plugin.
    You can open a tcp connection within your lua instance to port 25639. With clientnotifyregister you receive the talkstatuschangeevent.
    April 2010
    new zealand
    I am confuse? How do I open a port from lua, I thought lua sockets were not supported. At least not last time I tried.
    Thanks,
    Jason
    September 2005
    Germany / Dortmund
    1,376
    Yeah, that's right.
    But if the other lua instance supports sockets, you can connect to the clientquery plugin. So you completely ignore the lua plugin.
  1. [Question] Run lua function by click menu instead of /lua run xx
    By Viziss in forum Client Plugins / Lua Scripts
    Last Post: May 30th, 2015, 08:22 PM
  2. Replies: 0
    Last Post: February 23rd, 2014, 04:47 PM
  3. [On Todo] Lua Plugin PlayWaveFile Function breaking long sounds
    By VenomAK in forum Bug Reports [EN/DE]
    Last Post: May 27th, 2011, 10:31 AM
  4. Replies: 2
    Last Post: August 20th, 2010, 03:31 PM
