Results 1 to 11 of 11
    January 2011
    Austria
    Microphone volume fading
    recently i installed Teamspeak, everything working fine, tests all good... only when connecting und using ist, my voice fades after the first 3-4 seconds and only rgoes back to normal after i stop talking. Makes conversations a bit tiring
    It's the same with PTT and voice activation, i tried disabling all the advanced options recording in turn, no help.
    I'm running Vista 64 and some realtek HD onboard sound with a Digitus Headset that seems to be working fine.
    Some help would be great
    Thanks in advance,
    Frizzl
    February 2006
    Texas, USA
    4,143
    Do you have ECHO reduction turned on in your capture settings?
    January 2011
    Austria
    Tried with it turned off and on, so nothing there
    February 2006
    Texas, USA
    4,143
    hm... Drivers all up to date? Do the other clients notice this or is it just you that can hear this?
    January 2011
    Austria
    updating the drivers was the first thing i did, and it was the others that noticed it :-(
    November 2008
    United States
    1,718
    You know, some guy came on the public server with the same problem and they got it fixed but i can't for the life of me remember the exact problem. If you jump on the public server and into maybe one of the English Talk Channels, you can ask for help there as most of them don't check the forums. I think it had to do with some setting in windows. Sorry mate i'll try and find out for ya if i can but i just can't remember right now.
    Here is address to Teamspeaks public server voice.teamspeak-systems.de
    November 2011
    Mic problems
    Sometimes I find that I'll be talking and my mic will fade out.
    To fix it, I just mute, and un mute my mic, but its getting annoying since I'm a warlord of my clan, and I need to call piles for the game I play.
    I've googled the problem, and apperenlty there was a solution that someone could not recall, help please!
    Another thread regarding what appears to be the same problem.
    Additional info-
    I'm using a turtle beach x11 headset
    Realtek high def. Audio
    18,513
    AGC (Automatic voice gain control) also does change the volume for your mircophone, while you talk.
    Your sound get's lowered, when you yell into your microphone and i guess your mouth is not that far away from the microphone.
    February 2014
    had the exact same problem here is what worked for me
    the problem was caused by the realtek hd audio manager
    disabeling background noise reduction and the 2nd option there (sry dont find the translation "nachhallunterdrückung") totaly fixed it for me
    April 2012
    317
    Quote Originally Posted by Mr.Wrong View Post
    I think 'nachhallunterdrückung' is 'echo cancellation' in english.
    October 2012
    553
    It's actually not, but it's probably the actually correct term, as the german translation ain't exactly correct, implying it'd have sth. to do with room ambience / reverb which it doesn't.
    The correct german term for the algorithm would've been Echoauslöschung (using frequency spectrum of speaker output as source to reduce the very same spectrum in the microphone input), in contrast to Echounterdrückung (solely using volume) as techniques for Echokompensation (all stuff that makes echo go away), although compensation is sort of a questionable term for that.
    Lesson learned, translators are often not really up to the task
  1. Fading issues with microphone
    By Voltigeuse in forum General Questions
    Last Post: November 2nd, 2012, 10:05 AM
