Results 1 to 12 of 12
    January 2011
    allowing Users to create Sub-Channels, but not to create "Main"-Channels?!?
    Hi guys,
    i want my users to can create sub-channels in a certain channel, but parallely not to create channels in the main-tree.
    for sub-channels, there is a nice param: b_channel_create_child
    but this is missing for the creating of not-sub-channels...
    the only way i found to disallow the creating of channels is to deactivate these params:
    b_channel_create_modify_with_codec_speex8
    b_channel_create_modify_with_codec_speex16
    b_channel_create_modify_with_codec_speex32
    but ofcourse then are sub-channels forbidden too...
    anyone have an idea to solve that?
    and sorry for bad english
    September 2010
    USA
    39
    Right click the channel you want them to do it in and go to Channel Permissions then enable b_channel_create_child along with the other permissions such as:
    b_channel_create_modify_with_codec_(speex8/speex16/speex32/celtmono48) note: celtmono48 is for music streaming and probably should not be granted to guests.
    b_channel_create_(temporary/semi-permanent/permanent)
    i_channel_create_modify_with_codec_maxquality (value of 10)
    i_channel_create_modify_with_codec_latency_factor_ min (value of 1)
    b_channel_create_with_needed_talk_power
    b_channel_create_with_password
    b_channel_create_with_description
    b_channel_create_with_maxclients
    You may also want i_channel_max_depth with a value of 2, just to make sure they can't make channels inside their new channel.
    Make sure you do this to the channel you want them to make sub channels in.
    After you do this, tell them to enter the channel and then right click the channel and Create Sub Channel.
    January 2011
    thank you for the quick answer.
    this variant is similar to the one I am using at the moment. I guess this is the "nearest" solution for the problem.
    the channel permission variant activates / deactivates both: the creating of sub-channls and the creating of normal-channels.
    it seems there is no way to allow one and disallow the other at the same time...
    September 2010
    USA
    39
    Using the setup I posted, the user shouldn't be able to make main channels, if they try they should get a error. You might want to check the permissions on the groups they are in.
    http://img695.imageshack.us/img695/3484/permissions.png
    http://img638.imageshack.us/img638/5474/guests.png
    Here are two examples.
    February 2006
    Texas, USA
    4,143
    Use the permission i_channel_min_depth to limit them to sub-channels only.
    September 2010
    USA
    39
    I think you mean max depth and even if he did use this it wouldn't stop users from making channels outside his current channel. I do believe he has permissions set on server groups that he doesn't know about.
    February 2006
    Texas, USA
    4,143
    No, minimum depth. This permission requires a channel be a sub-channel. Max depth would limit the number of sub-channels that are sub channels of a channel.
    September 2010
    USA
    39
    Minimum depth isn't required (at least with the method I am using) as he is in the main channel creating a sub channel in it. Max depth however would limit the Channel Admin from making channels inside his newly created channel. That is if the Channel Admin even has the power to make sub channels after making the channel.
    February 2006
    Texas, USA
    4,143
    Based on this statement he needs the min depth permission. He didn't say anything about limiting creation inside the sub-channels that are created. I am merely addressing the question he had to start with.
    September 2010
    USA
    39
    I understand, but the method he said he was trying (similar to mine) should work as well and since he is already trying it.. well :P
    Quote Originally Posted by Holley View Post
    and after I read his original post again..
    Hi guys,
    He would still probably need the permissions enables on the channel unless he added a minimum depth of 2 to each main channel, assigned the create permissions to the group, then assign a minimum depth of 1 on the channel he wanted users to make channels in.
    Catalunya
    2,350
    Quote Originally Posted by .:Paul:. View Post
    With this system it isn't necessary the permission i_channel_max_depth = 2.
    Assign permissions to the channel, the subchannels do not inherit the settings, and therefore can't create nested channels, just brothers.
    To get to create all sorts of sub-channels within the parent channel, you must create a new Channel Group, and assign it the permission is turned off in the Normal Server Group: b_channel_create_permanent, you must also enable b_group_is_permanent
    And of course, assign the users you want, to this Channel Group, in the relevant Channel
    January 2011
    thanks very much for your solutions.
    when I have the time I will read it slowly and try it.
    I think with that my problem is solved, thanks again.
  1. Issue with allowing users to create temporary channels
    By AmazeCPK in forum Permission System
    Last Post: December 17th, 2014, 09:00 AM
  2. Allowing users to only create temp. channels under a spacer?
    By Matt8991 in forum Permission System
    Last Post: June 15th, 2014, 08:14 PM
  3. How do I create "red" channels
    By DaDenz in forum Server Support
    Last Post: July 2nd, 2013, 09:39 AM
  4. [Solved] how to create "locked" channels as banner?
    By sanlostsoul in forum Permission System
    Last Post: April 6th, 2010, 03:15 PM
