Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 112
  1. #16
    July 2014
    9
    I have attempted that and the same error still occurs... I am stumped, I have tried everything.
  2. #17
    UK
    769
    Are you sure your NPL isn't still being used on the old host?
  3. #18
    July 2014
    9
    Check all the old hosts, the servers have been deprovisioned. It has also been months since this license was last used
  4. #19
    December 2004
    RF
    3,008
    Check all logs. Better yet, show all logs.
    You only showed instance log, but the information you are looking for is in server logs.
  5. #20
    July 2014
    9
    I am posting the excerpts taken directly from the server logs folder on the dedicated box. The server marks the error and then a new log file is created that simply stops the server.
  6. #21
    December 2004
    RF
    3,008
    We don't need a crative remix of the log files.
    We need THE log files.
    Stop your server.
    Delete all logs.
    Start your server.
    Read the logs.
    If that did not shed any light, post the logs here. All of them.
  7. #22
    July 2014
    9
    Alright I did what you said and the logs are exactly the same, only two files were produced:
    ts3server_2014-07-25__05_34_53.932332_0.log
    2014-07-25 05:34:53.932332|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-07-25 05:34:53.932332|INFO    |ServerLibPriv |   | SystemInformation: Windows Server 2012 (9200) x64 (AMD or Intel) Binary: 64bit
    2014-07-25 05:34:53.943344|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-07-25 05:34:53.944345|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2014-07-25 05:34:53.944345|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-07-25 05:34:54.932457|INFO    |Accounting    |   | Licensing Information
    2014-07-25 05:34:54.932457|INFO    |Accounting    |   | type              : Non-profit
    2014-07-25 05:34:54.932457|INFO    |Accounting    |   | starting date     : Mon Mar 10 00:00:00 2014
    2014-07-25 05:34:54.933457|INFO    |Accounting    |   | ending date       : Sat Sep 27 00:00:00 2014
    2014-07-25 05:34:54.933457|INFO    |Accounting    |   | max virtualservers: 10
    2014-07-25 05:34:54.933457|INFO    |Accounting    |   | max slots         : 512
    2014-07-25 05:34:57.406778|INFO    |              |   | Puzzle precompute time: 2461
    2014-07-25 05:34:57.407769|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2014-07-25 05:34:57.479779|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1, 92.27.248.237,
    2014-07-25 05:34:57.480778|INFO    |Query         |   | listening on 0.0.0.0:10011
    2014-07-25 05:34:58.221871|ERROR   |Accounting    |   | too many slots hosted, shutting down!
    ts3server_2014-07-25__05_34_53.932332_1
    2014-07-25 05:34:57.479779|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2014-07-25 05:34:58.272883|INFO    |VirtualServerBase|  1| stopped
    Same as posted above, these are the complete log files, after that the server will not start unless the license key is removed and server is restarted
  8. #23
    April 2011
    1,266
    I havn't tried that, yet. But is it possible to configure the virtual server 1 with 550 slots running a NPL?! This would indeed result in only one virtual server trying to be started which then of course will immediately shutdown because of to many slots...
  9. #24
    July 2014
    9
    I have taken a look at the slots and they are set to 32 on start up this still causes an immediate shutdown.
    To ensure this I used telnet and on sid=0 set max slots to 32 and sid=1 -virtual set max slots to 32, and tried again.
    Same issue.
  10. #25
    December 2004
    RF
    3,008
    Two possible answers.
    1. Server did not unregister at the accounting server. Wait 2-3 hours then try again.
    2. A server with the same license is running elsewhere. Shutdown that other server.
  11. #26
    July 2014
    9
    Once again, I have tried the shut the server off and wait three times now, and the license has not been in use since March.. There are no other servers running.
    Still encountering this issue can anyone please help!
  12. #27
    July 2014
    9
    Still encountering this issue, I have read a lot of the other threads and still can't find a solution. Can anyone help
  13. #28
    April 2011
    1,266
    No, we can't everything was said.
  14. #29
    August 2014
    8
    Have you tried running the server with 32 slots but without the license file?
    If it still doesn't work then your configuration might just be incorrect.
  15. #30
    September 2014
    too many slots hosted, shutting down! [ Tried everything ]
    Recently I received a NPL, I'm trying to use it on my server but I keep receiving this error.
    I really tried everything, I've been looking all over the forums but I didn't find anything that could actually help me to figure out the problem.
    I'm willing to install a whole new VPS because of that.
    Anything I can do?
    Thanks
    Edit: I just tried to install a new teamspeak server on a windows VPS, Started the server with the same licensekey and I received the same error.
    Without the licensekey the server started correctly.
  1. too many slots hosted, shutting down!
    By Natsumi in forum Linux / FreeBSD
    Last Post: May 1st, 2016, 05:19 PM
  2. too many slots hosted, shutting down
    By GerrardLFC in forum Server Support
    Last Post: September 26th, 2014, 09:41 AM
  3. Too many slots hosted, shutting down!
    By Crypto in forum Server Support
    Last Post: October 3rd, 2013, 11:03 PM
  4. too many slots hosted, shutting down
    By asd3344 in forum Server Support
    Last Post: June 21st, 2010, 05:50 PM
  5. [bug?] server shutting down > too many slots hosted
    By Hollanda in forum Server Support
    Last Post: December 23rd, 2009, 12:13 PM
