Page 6 of 8 FirstFirst ... 45678 LastLast
Results 76 to 90 of 112
  1. #76
    December 2004
    RF
    3,006
    Solved
    Quote Originally Posted by ikats View Post
    1. I do not want to update the server cause i cant run MariaDB to the server.
    You don't have to. The TS3 support is lying to you.
    Percona, MariaDB and MySQL protocols are compatible, and you can use TS3's MariaDB client library to connect to the either of the three.
    You will only need to upgrade your MySQL server, if it is below the recommended version. (Which you really absolutely must do, no excuses.)
  2. #77
    Secret Base in Arctic Region
    1,671
    You should update, since youre running a very old server.
    And you dont have to use mariadb, the server should still use sqlite as default.
  3. #78
    November 2013
    16
    So let me understand what you are saying...
    If i upgrade to the latest version the problem will be solved???
    Why so long in the past 3 years the server was running smooth?
    Isn't my problem a license problem?
  4. #79
    November 2013
    16
    Sorry for the double post.
    As you suggested i update the server to the latest version.
    PHP Code:
    2016-08-25 16:38:19.057917|INFO    |ServerLibPriv |   |TeamSpeak 3 Server 3.0.13.3 (2016-08-18 16:46:43)
    2016-08-25 16:38:19.058149|INFO    |ServerLibPriv |   |SystemInformationLinux 3.10.0-327.el7.x86_64 #1 SMP Thu Nov 19 22:10:57 UTC 2015 x86_64 Binary: 64bit
    2016-08-25 16:38:19.059401|INFO    |DatabaseQuery |   |dbPlugin name:    SQLite3 pluginVersion 3, (c)TeamSpeak Systems GmbH
    2016
    -08-25 16:38:19.059449|INFO    |DatabaseQuery |   |dbPlugin version3.11.1
    2016
    -08-25 16:38:19.059784|INFO    |DatabaseQuery |   |checking database integrity (may take a while)
    2016-08-25 16:38:19.076559|INFO    |SQL           |   |database updated successfully to revision22
    2016
    -08-25 16:38:19.078704|INFO    |SQL           |   |database updated successfully to revision23
    2016
    -08-25 16:38:19.081150|INFO    |SQL           |   |database updated successfully to revision24
    2016
    -08-25 16:38:19.084408|INFO    |SQL           |   |database updated successfully to revision25
    2016
    -08-25 16:38:19.218806|INFO    |Accounting    |   |Licensing Information
    2016
    -08-25 16:38:19.218879|INFO    |Accounting    |   |type              Non-profit
    2016
    -08-25 16:38:19.218917|INFO    |Accounting    |   |starting date     Sat Apr 30 00:00:00 2016
    2016
    -08-25 16:38:19.218942|INFO    |Accounting    |   |ending date       Tue Nov  8 00:00:00 2016
    2016
    -08-25 16:38:19.218965|INFO    |Accounting    |   |max virtualservers10
    2016
    -08-25 16:38:19.218986|INFO    |Accounting    |   |max slots         512
    2016
    -08-25 16:38:19.282798|INFO    |DatabaseQuery |   |database busywaiting for finishing index tasksmay take some time!
    2016-08-25 16:39:00.418975|INFO    |              |   |Puzzle precompute time1119
    2016
    -08-25 16:39:00.420553|INFO    |FileManager   |   |listening on 0.0.0.0:30033, :::30033
    2016
    -08-25 16:39:00.479973|INFO    |CIDRManager   |   |updated query_ip_whitelist ips127.0.0.1/32
    2016-08-25 16:39:00.480515|INFO    |Query         |   |listening on 0.0.0.0:10011, :::10011
    2016
    -08-25 16:39:00.648881|ERROR   |Accounting    |   |too many slots hostedshutting down
    As you can see same error.
    What must i do now? Any suggestions?
  5. #80
    November 2013
    16
    No one can help?
  6. #81
    December 2015
    Canada
    76
    Remove the license file from your folder, restart teamspeak with 32 slots, contact TeamSpeak's license department to check the status/renew of your license.
  7. #82
    November 2013
    16
    Quote Originally Posted by Randinator View Post
    i have allready contact with teamspeak license department and they said to me that is a technical issue, not license issue.
  8. #83
    November 2013
    16
    I try to install a new ts server, clean install and i have run it with out the license key file.
    Server was started normally with out errors.
    If i shut down and put my license key the server stop with the same error.
    I dont know what else i can do.
    Is there no solution to my problem?
    The Support from teamspeakusa.com tells me that is not a license issue
  9. #84
    October 2016
    The problem with the license Non-profit
    Hello, I have problem with the license is a Non-profit, the problem is that without a license it works, but as soon as you throw the license says error connecting to the server
ID:	14398   Click image for larger version.
ID:	14396   Click image for larger version.
  10. #85
    November 2016
    NPL Licence Key - too many slots hosted
    Hi. Since a few days, when I set up a new server, it I cant use my NPL Licence anymore. It says (even though the licence is activated) that I have too many slots hosted. I didn't even set the server slots. There is 1 virtual server on it. If I have the server running without licence, it has 32 slots, and we're able to connect. As soon as I put the licencekey.dat in place, it says too many slots hosted - shutting down. Can anyone help me with this? I tried reducing the slots to 500 and 256 but it doesnt work. It's a 512 slot TS3 NPL-licence.
  11. #86
    April 2012
    Australia
    14
    Disconnected with no explanation?
    Hi all,
    my Non-profit licensed ts3 server has been online for about ten years, give or take a year
    I needed to move it from my home server to a server in the US
    I decided to reinstall it and make a new start, however, not long after I apply the license the server kicks me out with no explanation?
    I can not get back in, the logs show the database it corrupted. So I go through the hassle of unpacking to another location, overwrite the corrupted database and bingo, I'm in and it works, than I get kicked out again after about an hour.
    Is this a licence issues? Cause if so, that's a sad way of going about it, a simple text box with the words upgrade your license would do the trick.
    - JH
  12. #87
    18,119
    database disk image is malformed means your database is broken.
    This is is not license related.
    You may have moved the database while the server still was running.
  13. #88
    April 2012
    Australia
    14
    Thanks for the quick reply dante696,
    you guys do a great job nothing but excellent support in these forums,
    Hmm... back to my VPS, rm -r teamspeak_whatever/wget new - x86 version/unpacked it/start_script/joined it/let it run for 12 hours/no issues.
    Then...
    [email protected]:~# cd /home/teamspeak3-server_linux_x86
    [email protected]:/home/teamspeak3-server_linux_x86# ./ts3server_startscript.sh stop
    Stopping the TeamSpeak 3 server..done
    [email protected]:/home/teamspeak3-server_linux_x86# wget http://notme.com/licensekey.dat
    --2017-02-22 08:32:47--  http://notme/licensekey.dat
    Resolving notme.com (notme.com)... 69.not.me.83
    Connecting to notme.com (notme.com)|69.not.me.83|:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 901 [text/plain]
    Saving to: 'licensekey.dat'
    100%[======================================>] 901         --.-K/s   in 0s
    2017-02-22 08:32:47 (190 MB/s) - 'licensekey.dat' saved [901/901]
    [email protected]:/home/teamspeak3-server_linux_x86# ls
    CHANGELOG            licensekey.dat          sql
    LICENSE              logs                    ts3server
    doc                  query_ip_blacklist.txt  ts3server.sqlitedb
    files                query_ip_whitelist.txt  ts3server_minimal_runscript.sh
    libts3db_mariadb.so  redist                  ts3server_startscript.sh
    libts3db_sqlite3.so  serverquerydocs         tsdns
    [email protected]:/home/teamspeak3-server_linux_x86# ./ts3server_startscript.sh start
    Starting the TeamSpeak 3 server
    TeamSpeak 3 server started, for details please view the log file
    All good for about three hours/updated to 500 slots/twenty minuts latter...
    Yep, kicks me and a test client
    I run a GameSpy emulator with the same VPS hosting Co. and that database cops a pounding at times and it survives so my host is good.
    perhaps my old license is corrupt, it's all I can think of.
    it's been so long, where/how do I get a new licensekey.dat
    thanks again
    -JH
  14. #89
    4,344
    Quote Originally Posted by struth View Post
    Hi all,
    Running a software that is 7 years old for about 10 years is impressive.
  15. #90
    April 2012
    Australia
    14
    Hi numma_cway,
    thanks for the help, I started out hosting ts2 in, 06-07 for a year or so, when ts3 was released, I resisted upgrading for about six months. so your right - ts3 for about 6 or perhaps even 7 years and ts for 9 or 10
    Since then I've migrated & DB and licenses to a new home para-virtualized VM about five years ago. It must of worked as it's still running to this day. I haven't kept a running log of the decade-long shenanigans, though I have one now.
    The above issue remains - fresh VPS/install ts3/good for 12 hours/shut down/apply license/start/disconnected after about an hour?
    Not sure why applying my old licensekey.dat should kill the DB but that's what happens! I've gone over this process 3 times
    -JH
  1. too many slots hosted, shutting down!
    By Natsumi in forum Linux / FreeBSD
    Last Post: May 1st, 2016, 04:19 PM
  2. too many slots hosted, shutting down
    By GerrardLFC in forum Server Support
    Last Post: September 26th, 2014, 08:41 AM
  3. Too many slots hosted, shutting down!
    By Crypto in forum Server Support
    Last Post: October 3rd, 2013, 10:03 PM
  4. too many slots hosted, shutting down
    By asd3344 in forum Server Support
    Last Post: June 21st, 2010, 04:50 PM
  5. [bug?] server shutting down > too many slots hosted
    By Hollanda in forum Server Support
    Last Post: December 23rd, 2009, 11:13 AM
