Results 1 to 3 of 3
    February 2010
    Seattle
    69
    Solved 3D Sound and Attenuation set via API's is not respected
    It seems no 3d sound via the API's is respected at all.
    using channelset3DAttributes to set position to -1000.0f, -1000.0f, -1000.0f
    Attenuation is passing me 0.0f, I return the same, but I can still hear the person (muffled).
    The 3d position also does not reflect in the "3d Sound" dialog.
            TRACE("SET POSITION: %d=%f,%f,%f", player->getId(),vec.x, vec.y, vec.z);
    	if( (ts3Functions.channelset3DAttributes(ts3Functions.getCurrentServerConnectionHandlerID(),
    		(anyID)player->getId(), &vec)) == ERROR_ok) {
    			res = ACRE_OK;
    	} else {
    		res = ACRE_ERROR;
    	TRACE("%d", res);
    Setting the 3D sound via dialog works fine. But setting positions via API is not respected at all.
    June 2002
    Netherlands
    1,049
    The ts3 client had a minimum gain for 3D sound, so that you could always hear a person speaking. This has been removed. passing 0.0f now, should result in silence, in the next release.
    February 2010
    Seattle
    69
    Confirmed fixed in pre-7
  1. Attenuation for Mic
    By doveman in forum Suggestions and Feedback
    Last Post: June 26th, 2013, 07:57 AM
  2. Voice Attenuation?
    By Bedlam3485 in forum General Questions
    Last Post: May 8th, 2013, 09:59 AM
  3. [Resolved] set3DWaveAttributes does not seem to be respected when playing files
    By jaynus in forum Bug Reports [EN/DE]
    Last Post: February 25th, 2011, 05:51 PM
  4. [Fixed?] sendPluginCommand defined scope still not respected
    Last Post: August 27th, 2010, 02:48 PM
  5. [PLUGIN API] sendPluginCommand SCOPE is not respected
    By jaynus in forum Client Plugins / Lua Scripts
    Last Post: July 2nd, 2010, 03:09 AM
