Results 1 to 5 of 5
Thread: DOC and forum.
    January 2011
    6
    FIXED. DOC and forum.
    Somehow the messages are mixed here. IN forums people say don't do this ....
    Example 64-bit:
    $ tar xzf teamspeak3-server-linux_amd64.tar.gz
    $ cd teamspeak3-server-linux_amd64
    $ ./ts3server_linux_amd64
    Instead use "./ts3server_startscript.sh start" to generate the initial setup.
    I don't want to use sqlite and logs shows this.
    [email protected]:/opt/ts3# cat logs/ts3server_2011-01-21__14_21_32.224866.log
    2011-01-21 14:21:32.225146|INFO |ServerLibPriv | | Server Version: 3.0.0-beta22 [Build: 10723], Linux
    2011-01-21 14:21:32.225509|INFO |DatabaseQuery | | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2011-01-21 14:21:32.225564|CRITICAL|DatabaseQuery | | unable to load database plugin library "libts3db_sqlite3.so", halting!
    If I use ts3server_minimal_runscript.sh, i get the following
    ./ts3server_minimal_runscript.sh: line 6: ./ts3server_linux_x86: No such file or directory
    Is there no proper instructions and requirements somewhere that someone can follow?
    Thank you.
    May 2010
    6,310
    This is an old server (with an old documentation).....
    Update your server and try again.
    If you have the same error, can you please post the result of
    ldd libts3db_mysql.so
    January 2011
    6
    negative, it's the lastest server on the official links.
    And why do you want me to look at libts2db_mysql.so .. it's looking for libts3db_sqlite3.so....
    --- Merged ---
    [email protected]:/lib$ ldd libts3db_mysql.so
    linux-vdso.so.1 => (0x00007fff8b1ff000)
    libmysqlclient.so.15 => not found
    libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fce23461000)
    libm.so.6 => /lib/libm.so.6 (0x00007fce231dd000)
    libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007fce22fc6000)
    libc.so.6 => /lib/libc.so.6 (0x00007fce22c43000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fce23984000)
    Ubuntu libmysqlclient16 only available.
    May 2010
    6,310
    Quote Originally Posted by tevoda View Post
    There seems not.
    The lastest version is beta 30 (and beta 31-pre) not beta 22
    So, I assume you used the correct start parameters to use mysql
    January 2011
    6
    Ah darnit. I was trying different sources, copied over the wrong one. Thx ... long day XD
    --- Merged ---
    ./ts3server_minimal_runscript.sh start
    ./ts3server_minimal_runscript.sh: 17: ./ts3server_linux_x86: not found
    Still same issue, I don't see any howto or what is what or anything about ts3server.ini in docs/
    --- Merged ---
    Nevermind ... all done.
  1. are new to the forum, asking for help
    By svebol in forum Skins / Icon & Sound Packs
    Last Post: February 2nd, 2012, 12:22 AM
  2. Forum Home button | Forum Ease of Use
    By BHKai in forum Suggestions and Feedback
    Last Post: August 6th, 2011, 05:05 AM
