Results 1 to 10 of 10
    January 2011
    Not possible modify group permissions as superadmin
    As superadmin I have all the permits for modify the usergroups, nevertheless, when it is tried to modify the permissions group the value changed is reverted back.
    That is, it is allowed to changed from 75 to 70 but the value is back to (75) when just leave the line..
    Any help is welcome.
    May 2010
    6,310
    In your server group, what is the i_group_modify_power ?
    In the group that you want change, what is the i_group_needed_modify_power ( and the "Grant" value) ?
    January 2011
    In my group group modify power is 75
    In the one I want to modify only is activated the group needed modify power is 75 too. Problem is that there is not any grant value there.
    Thanks.
    February 2006
    Texas, USA
    4,143
    If you are in the admin query server group you should have a power of 100. If you don't have a grant value for the server admin group you will need to either add it via server query or add yourself to the admin query server group and give the server admin group a grant value (default is 75)
    January 2011
    Yes I understand it , but when I have tried , as superadmin,to modify and add grant values or power, for the modify channel group I am not able.
    I always received insuficcient permits...
    May 2010
    6,310
    When you said, "superadmin", you mean you are in the Server Admin group or in the Query Admin Group ?
    Could you post your permission please (with an snapshot query command), just copy and paste in the file the information after "begin_permissions"
    January 2011
    I am in the Server Admin Group. I am never and I can not use SQL Queries (always received not npough permits....)
    Permissions:
    Global: Information,Virtual SErver Management, Aministration,Settings all in grey..
    Virtual Server: all marked with x (enabled),
    except: b_virtual_server_select, b_virtual_server_start/stop,snapshop deploy,create,reset,
    modify_max_clients,modif_ft_settings,ft_qouta,host message,hostbanner,hostbutton,port,autostart,modif y_codec_encryption_mode (all in grey)
    Channel: all marked with x ,except: channel_modify_make_coec_encrypted.(grey)
    b_channel_group_inhertance_end not marked.
    power and join power all 75
    Group: all marked x except permission_modify_power_ignore,group_auto_update_t ype (grey)
    power,modify power all 75
    Client: all marked with x.
    Strange is that I do not see any thing on grant values..and I do not remember if there should be something there.
    Thanks in Advance.
    May 2010
    6,310
    Do you rent your server ?
    January 2011
    yes. I know now that it could be better solutions...but
    May 2010
    6,310
    In this case, you must talk about that with your hoster.
    Maybe he has blocked some necessaery permissions.
  1. [Not possible] Increasing group modify and client permission modify above 75
    By Warith in forum Permission System
    Last Post: September 20th, 2015, 02:44 PM
  2. Replies: 1
    Last Post: August 20th, 2015, 09:32 PM
  3. Replies: 1
    Last Post: January 24th, 2014, 01:46 PM
  4. Replies: 1
    Last Post: January 11th, 2014, 05:10 PM
  5. Replies: 3
    Last Post: July 15th, 2012, 01:18 PM
