Results 1 to 3 of 3
    February 2011
    Solved Problem with ip on debian server?
    first of all.. google gave me 10000000 topics but this didnt help at all
    i cant get on my ts3 server,
    here the log:
                          I M P O R T A N T
                  Server Query Admin Acccount created
    2011-02-04 07:00:36.727648|INFO    |Accounting    |   | Licensing Information
    2011-02-04 07:00:36.727648|INFO    |Accounting    |   | type              : Non-profit
    2011-02-04 07:00:36.727648|INFO    |Accounting    |   | starting date     : Thu Feb  3 00:00:00 2011
    2011-02-04 07:00:36.727648|INFO    |Accounting    |   | ending date       : Fri Feb  3 00:00:00 2012
    2011-02-04 07:00:36.727648|INFO    |Accounting    |   | max virtualservers: 10
    2011-02-04 07:00:36.727648|INFO    |Accounting    |   | max slots         : 512
    2011-02-04 07:00:36.867648|ERROR   |FileManager   |   | bind() failed: 98
    2011-02-04 07:00:36.867648|ERROR   |FileManager   |   | bind failed on 0.0.0.0:30033
    2011-02-04 07:00:36.887648|INFO    |VirtualSvrMgr |   | executing monthly interval
    2011-02-04 07:00:36.887648|INFO    |VirtualSvrMgr |   | reset client traffic statistics
    2011-02-04 07:00:36.887648|INFO    |VirtualSvrMgr |   | reset virtualserver traffic statistics
    2011-02-04 07:00:38.415648|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2011-02-04 07:00:38.415648|INFO    |VirtualServer |  1| client 'server'(id:0) added privilege key for servergroup 'Server Admin'(id:6)
    2011-02-04 07:00:38.423648|WARNING |VirtualServer |  1| --------------------------------------------------------
    2011-02-04 07:00:38.423648|WARNING |VirtualServer |  1| ServerAdmin privilege key created, please use the line below
    2011-02-04 07:00:38.423648|WARNING |VirtualServer |  1| token=
                          I M P O R T A N T
          ServerAdmin privilege key created, please use it to gain
          serveradmin rights for your virtualserver. please
          also check the doc/token_guide.txt for details.
    2011-02-04 07:00:38.431648|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2011-02-04 07:00:38.431648|ERROR   |Query         |   | bind failed on 0.0.0.0:10011
    2011-02-04 07:00:38.535648|INFO    |VirtualServer |  1| stopped
    bind failed on 0.0.0.0:9988
    bind failed on 0.0.0.0:330033
    some questions.. why 0.0.0.0?
    doesnt this have to be my servers ip?
    i added the ip and another port in the ts3server.ini (in same dir like the rest like the runscripts) and i changed the prots to 10012 and 330034 to test it.. but nothing happened...
    ofc i added inifile=ts3server.ini in the startscript
    whats wrong?
    /edit
    tired to run it with inifile=ts3server.ini as parameter
    [email protected]:/home/teamspeak3/ts3server_linux-amd64$ ./ts3server_linux_amd64 inifile=ts3server.in
    TeamSpeak Server 3.0.0-beta30 [Build: 12998]
    (c)TeamSpeak Systems GmbH
    Logging started
    2011-02-04 07:04:41.879648|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta30 [Build: 12998], Linux
    2011-02-04 07:04:41.879648|INFO    |DatabaseQuery |   | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2011-02-04 07:04:41.879648|CRITICAL|DatabaseQuery |   | unable to load database plugin library "libts3db_sqlite3.so", halting!
    regards
    May 2010
    6,310
    0.0.0.0 indicates that the server listens to all IP addresses.
    Quote Originally Posted by HolGORE
    Please read the documentation. You can't start a server like that.
    Quote Originally Posted by Server_quickstart.txt
    Example (On Screen):
    $ tar xzf teamspeak3-server-linux_x86.tar.gz
    $ cd teamspeak3-server-linux_x86
    $ ./ts3server_minimal_runscript.sh
    Example (Background):
    $ ./ts3server_startscript.sh
    You can find several answers, writing "bind failed" in the search function
    February 2011
    hey
    i fixed it myself
    but after i tried it again i got another error (tried too often in a time period) and i didnt notice it because i had to go afk
    now i tried it again snd its working
    thxxxxx
  1. updating server to 3.0.10.3 problem on linux debian.
    By Senka in forum Server Support
    Last Post: January 22nd, 2014, 12:32 AM
  2. Replies: 4
    Last Post: March 7th, 2013, 03:11 PM
  3. Problem to start my server (upgrade debian)
    By v1g00 in forum Linux / FreeBSD
    Last Post: February 17th, 2011, 10:24 PM
  4. Debian server problem
    By NameLess in forum Linux / FreeBSD
    Last Post: November 24th, 2010, 09:24 AM
