Results 1 to 3 of 3
    February 2010
    Seattle
    69
    No function to set wave playback volume
    Currently, there is no method to set wave file volume short of doing 3d attenuation on the wave playback (which is also currently broken until next pre release), which will also exhibit weird behavior in 5.1 surround options.
    I request one of the following, if you guys would be awesome enough to implement it:
    1. setWaveVolume(waveHandle, float);
    or
    2. append a volume to playWaveFileHandle, so it can be played as
    ret = ts3Functions.playWaveFileHandle(ts3Functions.getCu rrentServerConnectionHandlerID(),
    this->getSquawkOnPath(),
    0,
    volume,
    &playHandle);
    Obviously, option #1 is preferred so it can be changed on the fly, but I thought I'd request both
    July 2002
    2,191
    this should already work, simply call setPlaybackConfigValue or setPlaybackConfigValueAsFloat with ident="volume_factor_wave". The value should be in decibel, so 0 is the loudest there is, and negative numbers make things more quiet.
    February 2010
    Seattle
    69
    Ah! Had no idea. Thanks Peter!
  1. very low Playback Volume within TS3
    By Iorvar in forum Windows
    Last Post: November 1st, 2012, 06:21 PM
  2. [No Bug] No function to set wave playback volume
    By jaynus in forum Bug Reports [EN/DE]
    Last Post: February 18th, 2011, 08:08 AM
  3. Playback volume always too low
    By Rikupsoni in forum General Questions
    Last Post: March 19th, 2010, 05:53 PM
  4. Low Playback Volume - extremely low
    By Ellgee in forum Windows
    Last Post: February 15th, 2010, 02:00 AM
