Results 31 to 45 of 49
  1. #31
    June 2012
    6/26/2012 8:01:30 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    6/26/2012 8:01:30 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    6/26/2012 8:01:30 AM	CapSoundSet	Error	Failed to open capture device when updating capture system: 2321
    6/26/2012 8:01:30 AM	CapSoundSet	Error	Error setting PreProcessorConfigValues onPTTActivated: 2304
    6/26/2012 8:01:30 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:01:31 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:01:32 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:01:33 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:01:33 AM		Error	VADDisplay timer: Error reading voice power: 2304	6/26/2012 8:01:35 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:01:36 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:01:36 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    6/26/2012 8:01:36 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    6/26/2012 8:01:36 AM	CapSoundSet	Info	Could not reactivate capture device after VAD voice test: 1799
    6/26/2012 8:01:36 AM	CapSoundSet	Error	Failed to open capture device when updating capture system: 2321
    6/26/2012 8:01:36 AM	CapSoundSet	Error	Error setting PreProcessorConfigValues onPTTActivated: 2304
    6/26/2012 8:01:37 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:01:37 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    6/26/2012 8:01:37 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    6/26/2012 8:01:37 AM	CapSoundSet	Info	Could not reactivate capture device after VAD voice test: 1799
    6/26/2012 8:06:02 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    6/26/2012 8:06:02 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    6/26/2012 8:06:02 AM	CapSoundSet	Error	Failed to open capture device when updating capture system: 2321
    6/26/2012 8:06:02 AM	CapSoundSet	Error	Error setting PreProcessorConfigValues onPTTActivated: 2304
    6/26/2012 8:06:02 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:06:03 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/
    6/26/2012 8:06:04 AM		Error	VADDisplay timer: Error reading voice power: 2304
    6/26/2012 8:06:04 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    6/26/2012 8:06:04 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    6/26/2012 8:06:04 AM	CapSoundSet	Info	Could not reactivate capture device after VAD voice test: 1799
    That's most of it.
  2. #32
    18,151
    Is this client 3.0.7 and did it work with client 3.0.0 -3.0.6.
  3. #33
    June 2012
    I have the most current download from the download section, I didn't have TS downloaded before this version but it did work on my laptop
  4. #34
    18,151
    It looks like the device got removed.
    Maybe this helps you:
    - Use another USB Slot
    - Remove your Headset from any usb cable extender or usb hub.
    - Try to setup the device directly under Settings > Options > "Playback" and "Recoding". Also try direct sound and windows audio session.
  5. #35
    June 2012
    I'm playing music through the headset and it's playing fine I wonder if it might just my microphone slot doesn't work for some reason, any suggestions for things to do for that?
    EDIT: Plugged the headset into the back of the computer instead of the front and it now works, must have just been my microphone jack is installed incorrectly in the front, thanks for trying
  6. #36
    November 2012
    The configured capture device was not found (mic bug)
    Mic bug. All drivers and firmware up to date.
    Everything was working fine, I was using TS and this exact setup for about a week playing WWII Online. Then I tried the Overlay Plugin, and now even though my mic works fine in Windows 7 64bit (sound/recording/etc.) and it even works in TS when I first start up, it stops working as soon as I connect to any server. I have disabled the pluging uninstalled TS deleted remaining plugin folders and done a clean TS reinstall, but I am still having the same issue. I tried uninstalling and reinstalling my headset drivers as well.
    As soon as I connect to any server I get the message:
    The configured capture device was not found.
    Instead using: Razer Megalodon
    Press OK to apply the changes or press Setup to change the configuration manually.
    Which is weird because that IS the one I configured. After that if I try to test the mic I get this error:
    Error, could not open capture device.
    Even If I choose the mic in the dropdown list in settings (it is not red in the dropdown) and I know it is working in all other programs (but it stops working in those programs as long as I am connected to a server in TS).
    I have tried making new capture profiles and chosing them under "self", still no good.
    This is one of my logs (I had muted my speakers because I was using the default public server for these tests):
    2012-11-11 01:14:25.657480|INFO    |              |   | TeamSpeak 3 Client 3.0.9.2 (2012-10-29 10:00:43)
    2012-11-11 01:14:25.688680|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2012-11-11 01:14:25.758883|INFO    |              |   | *** Time [SPAWN_EVENTCONVERTER]: 101
    2012-11-11 01:14:25.766883|INFO    |Query         |   | listening on 127.0.0.1:25639
    2012-11-11 01:14:25.812886|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:14:25.812886|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:14:25.900891|INFO    |Input         |   | Default monitoring enabled
    2012-11-11 01:14:25.909891|INFO    |              |   | *** Time [MAINWINDOW]: 268
    2012-11-11 01:14:25.910891|INFO    |              |   | *** Time [INIT]: 269
    2012-11-11 01:14:25.910891|INFO    |ClientUI      |   | *** Time [SQLITE_CONVERTER]: 0
    2012-11-11 01:14:25.919892|INFO    |ClientUI      |   | Qt version: 4.7.2
    2012-11-11 01:14:25.919892|INFO    |ClientUI      |   | Using configuration location: C:\Users\Colin\AppData\Roaming\TS3Client\settings.db
    2012-11-11 01:14:26.409920|INFO    |ClientUI      |   | Last update check was:
    2012-11-11 01:14:26.413920|INFO    |              |   | Checking for updates...
    2012-11-11 01:14:26.444922|INFO    |              |   | DNS resolve successful, "update.teamspeak.com"=80.190.225.139
    2012-11-11 01:14:27.019955|INFO    |              |   | Update check, my version: 1351504843, latest version: 1351504843
    2012-11-11 01:14:35.923464|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:14:35.923464|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:14:35.924464|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2012-11-11 01:14:35.938465|DEBUG   |Windows Audio Session|   | WAS Buffer size: 960
    2012-11-11 01:14:35.938465|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2012-11-11 01:14:35.938465|INFO    |PreProSpeex   |  2| Speex version: speex-1.2beta3
    2012-11-11 01:14:35.938465|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2012-11-11 01:14:35.938465|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2012-11-11 01:14:35.939465|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2012-11-11 01:14:35.941465|ERROR   |Windows Audio Session|   | ERROR (-125 -2147024895): Incorrect function.
    2012-11-11 01:14:35.942465|ERROR   |SoundBckndIntf|   | C:/Program Files/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win64.dll error: DEVICE_INITIALIZE
    2012-11-11 01:14:35.942465|ERROR   |              |   | Error opening playback device when activating local test mode 2311
    2012-11-11 01:14:38.147591|DEBUG   |Windows Audio Session|   | WAS::stopDevice-enter
    2012-11-11 01:14:38.147591|DEBUG   |Windows Audio Session|   | WAS::stopDevice-leave
    2012-11-11 01:14:38.147591|DEBUG   |Windows Audio Session|   | WAS::closeDevice-enter
    2012-11-11 01:14:38.148591|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - enter
    2012-11-11 01:14:38.148591|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - leave
    2012-11-11 01:14:38.148591|DEBUG   |Windows Audio Session|   | WAS::closeDevice-leave
    2012-11-11 01:14:38.148591|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
    2012-11-11 01:14:38.148591|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:14:38.148591|DEVELOP |Windows Audio Session|   | Waiting for device to close
    2012-11-11 01:14:38.303600|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:14:38.303600|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - leave
    2012-11-11 01:14:38.303600|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:14:38.498611|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:14:38.498611|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:14:52.457410|INFO    |ClientUI      |  1| Connect to server: voice.teamspeak.com
    2012-11-11 01:14:52.458410|INFO    |ClientUI      |  1| Trying to resolve voice.teamspeak.com
    2012-11-11 01:14:52.459410|INFO    |              |   | SRV DNS resolve unsuccessful for "_ts3._udp.voice.teamspeak.com"
    2012-11-11 01:14:52.459410|INFO    |              |   | No SRV TSDNS found at "_tsdns._tcp.voice.teamspeak.com"
    2012-11-11 01:14:52.459410|INFO    |              |   | DNS resolve successful, "voice.teamspeak.com"=194.97.114.2
    2012-11-11 01:14:53.063444|INFO    |              |   | TSDNS found at "voice.teamspeak.com" and queried successfully. Result: 194.97.114.2:9987
    2012-11-11 01:14:53.065445|INFO    |              |   | SRV TSDNS found at "_tsdns._tcp.teamspeak.com"=>"voice.teamspeak.com:41144" and queried successfully. Result: 194.97.114.2:9987
    2012-11-11 01:14:53.065445|INFO    |ClientUI      |  1| Lookup finished: 194.97.114.2 9987 voice.teamspeak.com 1 0
    2012-11-11 01:14:53.065445|INFO    |ClientUI      |  1| Resolve successful: 194.97.114.2:9987
    2012-11-11 01:14:53.066445|INFO    |ClientUI      |  1| Blacklist check ok
    2012-11-11 01:14:53.066445|INFO    |ClientUI      |  1| Initiating connection: 194.97.114.2:9987 voice.teamspeak.com
    2012-11-11 01:14:53.070445|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:14:53.070445|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:14:53.070445|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2012-11-11 01:14:53.094446|DEBUG   |Windows Audio Session|   | WAS Buffer size: 960
    2012-11-11 01:14:53.094446|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2012-11-11 01:14:53.094446|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2012-11-11 01:14:53.094446|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2012-11-11 01:14:53.101447|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:14:53.102447|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:14:53.102447|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2012-11-11 01:14:53.106447|ERROR   |Windows Audio Session|   | ERROR (-125 -2147024895): Incorrect function.
    2012-11-11 01:14:53.106447|ERROR   |SoundBckndIntf|   | C:/Program Files/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win64.dll error: DEVICE_INITIALIZE
    2012-11-11 01:14:53.110447|INFO    |ClientUI      |  1| Connect status: Connecting
    2012-11-11 01:14:53.365462|INFO    |              |   | DNS resolve successful, "blacklist.teamspeak.com"=80.190.225.139
    2012-11-11 01:14:54.039500|INFO    |ClientUI      |  1| Connect status: Connected
    2012-11-11 01:14:54.340517|INFO    |ClientUI      |  1| Connect status: Establishing connection
    2012-11-11 01:14:55.863605|INFO    |ClientUI      |  1| Connect status: Connection established
    2012-11-11 01:20:28.608637|INFO    |ClientUI      |  1| Connect status: Disconnected
    2012-11-11 01:20:28.610637|INFO    |ClientUI      |  1| Disconnected or forced to leave, want autoreconnect = 0
    2012-11-11 01:20:36.382081|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:20:36.382081|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:20:36.382081|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2012-11-11 01:20:36.388081|ERROR   |Windows Audio Session|   | ERROR (-125 -2147024895): Incorrect function.
    2012-11-11 01:20:36.388081|ERROR   |SoundBckndIntf|   | C:/Program Files/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win64.dll error: DEVICE_INITIALIZE
    2012-11-11 01:20:36.388081|ERROR   |CapSoundSet   |   | Failed to open capture device when updating capture system: 2310
    2012-11-11 01:20:36.392082|ERROR   |CapSoundSet   |   | Error setting PreProcessorConfigValues onPTTActivated: 2304
    2012-11-11 01:20:36.402082|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.422083|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.442085|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.462086|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.482087|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.502088|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.522089|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.542090|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.562091|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.582093|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.602094|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.622095|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.642096|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.662097|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.682098|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.702099|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.722101|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.742102|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.762103|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.782104|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.802105|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.822106|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.842107|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.862109|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.882110|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.902111|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.922112|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.942113|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.962114|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:36.982115|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.002117|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.022118|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.042119|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.062120|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.082121|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.102122|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.122123|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.142125|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.162126|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.182127|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.202128|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.222129|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.242130|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.262131|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.282133|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.302134|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.322135|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.342136|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.362137|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.382138|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.402139|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.422141|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.442142|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.462143|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.482144|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.502145|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.522146|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.542147|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.562149|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.582150|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.602151|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.622152|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.642153|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.662154|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.682156|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.702157|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.722158|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.742159|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.762160|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.782161|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.802162|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.822164|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.842165|ERROR   |              |   | VADDisplay timer: Error reading voice power: 2304
    2012-11-11 01:20:37.868166|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:20:37.868166|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:20:38.024175|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:20:38.024175|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:20:38.024175|INFO    |CapSoundSet   |   | Could not reactivate capture device after VAD voice test: 1799
    2012-11-11 01:20:39.596265|DEBUG   |Windows Audio Session|   | WAS::stopDevice-enter
    2012-11-11 01:20:39.597265|DEBUG   |Windows Audio Session|   | WAS::stopDevice-leave
    2012-11-11 01:20:39.597265|DEBUG   |Windows Audio Session|   | WAS::closeDevice-enter
    2012-11-11 01:20:39.597265|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - enter
    2012-11-11 01:20:39.597265|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - leave
    2012-11-11 01:20:39.597265|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
    2012-11-11 01:20:39.597265|DEBUG   |Windows Audio Session|   | WAS::closeDevice-leave
    2012-11-11 01:20:39.597265|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:20:39.597265|DEVELOP |Windows Audio Session|   | Waiting for device to close
    2012-11-11 01:20:39.705271|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - leave
    2012-11-11 01:20:39.705271|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:20:39.722272|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:20:39.722272|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2012-11-11 01:20:39.924284|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2012-11-11 01:20:39.924284|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    I would very much like to get this working again.
    Thanks.
  7. #37
    November 2012
    Bump.
    Also I tried with 32bit client and got the same problem.
  8. #38
    November 2012
    I get the feeling this is the problem:
  9. #39
    6,078
    Seems to be a driver issue, what driver versions are you using (Both Headset (if any) and sound drivers)?
    You can try and reinstall your sound / headset drivers. Make sure to install the latest version.
    Also try the following:
    If you have echo cancellation enabled - disable it and test it again (Settings -> options -> capture)
    Try setting another capture format in windows (Right click speaker in systray -> Recording -> dbl click microphone -> Advanced)
    Try direct sound (settings -> options -> capture)
    Curious as to how you know the microphone works before connecting? no devices are opened by TeamSpeak until you connect, unless you are doing the test in the settings.
  10. #40
    November 2012
    Yes if I test the capture device in the settings it works fine, but if I connect to a server the error happens.
    But I already got it working again by doing a system restore to before I installed the Overlay Plugin.
    Also all my drivers were up to date before the problem started. Something about the plugin messed up the way TS accesses the device while logged into a server, and it is persistent even after uninstalling the plugin and TS. Maybe a registry change? It seems like that might be it since a system restore fixed it.
    [Edit: I will post my drivers when I get back to that system]
  11. #41
    January 2013
    hey guys,
    I am having the same problem as colincbn with my TS as he described.
    Mic bug. All drivers and firmware up to date and now even though my mic works fine in Windows 7 64bit (sound/recording/etc.) and it even works in TS when I first start up, it stops working as soon as I connect to any server.
    but have not changed any of my plugins and after doing a system restore it still isnt working for me.
    1/17/2013 10:46:10 AM Info TeamSpeak 3 Client 3.0.9.2 (2012-10-29 10:00:43)
    1/17/2013 10:46:10 AM Query Info listening on 127.0.0.1:25639
    1/17/2013 10:46:10 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:46:10 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 10:46:10 AM Input Info Direct Input monitoring enabled
    1/17/2013 10:46:10 AM Info *** Time [HOTKEYS]: 136
    1/17/2013 10:46:10 AM Info *** Time [MAINWINDOW]: 407
    1/17/2013 10:46:10 AM Info *** Time [INIT]: 407
    1/17/2013 10:46:10 AM ClientUI Info Qt version: 4.7.2
    1/17/2013 10:46:10 AM ClientUI Info Using configuration location: C:\Users\Duck\AppData\Roaming\TS3Client\settings.d b
    1/17/2013 10:46:10 AM Input Info Input device name: Mouse
    1/17/2013 10:46:10 AM Input Info Input device name: Keyboard
    1/17/2013 10:46:10 AM Input Info Input device name: Logitech Extreme 3D Pro
    1/17/2013 10:46:11 AM ClientUI Info Last update check was: Thu Jan 17 09:23:57 2013
    1/17/2013 10:46:21 AM ClientUI Info Connect to server: 202.62.137.195
    1/17/2013 10:46:21 AM ClientUI Info Blacklist check ok
    1/17/2013 10:46:21 AM ClientUI Info Initiating connection: 202.62.137.195:9989 202.62.137.195
    1/17/2013 10:46:21 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:46:21 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 10:46:21 AM Info DNS resolve successful, "blacklist.teamspeak.com"=176.9.148.78
    1/17/2013 10:46:21 AM ClientUI Info Connect status: Connecting
    1/17/2013 10:46:21 AM ClientUI Info Connect status: Connected
    1/17/2013 10:46:21 AM ClientUI Info Connect status: Establishing connection
    1/17/2013 10:46:21 AM ClientUI Info Connect status: Connection established
    1/17/2013 10:46:34 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:46:34 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 10:46:36 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:46:36 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 10:46:50 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:46:50 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 10:46:52 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:46:52 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 10:46:52 AM CapSoundSet Info Could not reactivate capture device after VAD voice test: 1799
    1/17/2013 10:48:25 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:48:25 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 10:48:26 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    1/17/2013 10:48:26 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    1/17/2013 11:01:10 AM Info Memory usage: 75.16 MiB
    if anyone has any ideas please help
    cheers,
    duck
  12. #42
    6,078
    Make sure the device configured in TeamSpeak is actually connected, working properly and recognized by Windows. If not TeamSpeak cannot detect it either. If another app is using the mic, it may prevent TeamSpeak from using it too, so you might want to try and disable exclusive control in the microphone options in windows.
    If all else fails you can try and delete the settings.db file and then start TeamSpeak, you will lose your bookmarks and other settings though.
  13. #43
    December 2015
    Error, Could not open capture device
    have a Razer Kraken pro head set.. it works with everything but TS, here is the error report i am getting.. i am not as tech savy as i once was lol.. any help would be great
    08/12/2015 21:09:17 Error VADDisplay timer: Error reading voice power: 2304
    Last edited by dante696; December 9th, 2015 at 12:58 PM. Reason: merged, this is a problem with your sound card
  14. #44
    October 2012
    553
    Hmm, what I can tell you is that VAD stands for "Voice Activity Detection", which - you guessed it - errors out on that headset for whatever reason. I haven't seen that yet, and it's not even a USB headset which might do some funny stuff device driver programmer's might have decided to be cool...
    For urgent matters however, you should be able to simply use Push To Talk instead of Voice Activation to get it working at all.
  15. #45
    August 2012
    TS3 does not recognize working USB capture devices
    Bug found with sound capture device.
    System
    • Windows 10 Home
    • version 1803
    • build 17134.706
    Teamspeak 3
    • Version: 3.5.2 (17/04/2019 17:07:33)
    • Qt Version: 5.6.2
    I have a USB Turtle Beach Z60 headset, and a USB Logitech HD Pro Webcam C920 installed on my system.
    • TS3 does not recognize the headset, it is not in the list of capture devices.
    • The only devices in the dropdown list are the default device, and the Webcam.
    If I select the default device and press the <Begin Test> button in the Options->Capture panel I get the error message Error, could not open Capture Device, even though the Webcam is the default device on my system. If I select the Webcam in the device list, then TS3 works correctly.
    Both the headset and the webcam work perfectly with all other applications on my system.
    In the Windows 10 privacy:microphone settings
    • Allow access to the microphone on this device is on
    • Allow apps to access the microphone is on
    So the bug I am reporting is
    1. TS3 does not recognize my working Headset in the capture device list.
    2. TS3 cannot use the default device which is the Webcam, even though it can use the Webcam when specifically selected.
    This is really frustrating, causing me to have to use the webcam instead of my headset, which is far from an optimal experience.
    My setup was working fine upto around three months ago, and then suddenly started behaving like this. I have not made any changes, but windows of course has done at least two automatic updates that I can remember during this time. All drivers on my system, are uptodate.
  1. Error, Could not open Capture device???
    By Alfred_Timperley in forum General Questions
    Last Post: December 28th, 2015, 07:03 PM
  2. Error Could Not Open Capture Device
    By |DHC|John in forum Windows
    Last Post: March 26th, 2014, 04:06 PM
  3. Error, could not open Capture Device.
    By feral in forum Windows
    Last Post: January 5th, 2012, 05:05 PM
  4. Error: Could not open selected capture device. HELP!!!!!
    By CrispyFries in forum Bug Reports [EN/DE]
    Last Post: August 19th, 2011, 08:02 PM
  5. Replies: 1
    Last Post: April 19th, 2011, 07:47 PM
