Results 46 to 49 of 49
  1. #46
    18,151
    What does your client log print when you get that error message?
  2. #47
    August 2012
    In answer to your request for more information on my bug thread
    This is the log entry for the Error, could not open Capture Device message
    14/05/2019 15:31:01 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    14/05/2019 15:31:01 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    14/05/2019 15:31:01 CapSoundSet Error Failed to open capture device when updating capture system: 2321
    14/05/2019 15:31:01 Windows Audio Session Debug WAS:penDevice-enter - {0.0.0.00000000}.{76d3b384-fac4-4eb0-8474-421d585cc721}
    14/05/2019 15:31:01 Windows Audio Session Devel Mix Format: SRate:16000 Bitrate: 32 Channels: 2 - Communication Path (Turtle Beach Z60 Chat Audio)
    14/05/2019 15:31:01 Windows Audio Session Devel Initializing with mix format. - Communication Path (Turtle Beach Z60 Chat Audio)
    14/05/2019 15:31:01 Windows Audio Session Info Initialized with 2 channels in 32bit, 16kHz. - Communication Path (Turtle Beach Z60 Chat Audio)
    14/05/2019 15:31:01 Windows Audio Session Devel WAS Buffer size: 352 - Communication Path (Turtle Beach Z60 Chat Audio)
    14/05/2019 15:31:01 Windows Audio Session Debug WAS:penDevice-leave - {0.0.0.00000000}.{76d3b384-fac4-4eb0-8474-421d585cc721}
    14/05/2019 15:31:01 Windows Audio Session Debug WAS::startDevice-enter - {0.0.0.00000000}.{76d3b384-fac4-4eb0-8474-421d585cc721}
    14/05/2019 15:31:01 Windows Audio Session Debug WAS::startDevice-leave - {0.0.0.00000000}.{76d3b384-fac4-4eb0-8474-421d585cc721}
    14/05/2019 15:31:01 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    Which means nothing to me lol
  3. #48
    18,151
    I do not have a solution for this.
    Last time i saw these error messages was around 2012 and it was a driver problem.
    What i can offer are these posts from the past. You can try these things and maybe you can solve it that way.
    Maybe this helps you:
    - Use another USB Slot
    - Remove your Headset from any usb cable extender or usb hub.
    - Try to setup the device directly under Tools > Options > "Playback" and "Recoding". Also try direct sound and windows audio session.
    Seems to be a driver issue, what driver versions are you using (Both Headset (if any) and sound drivers)?
    You can try and reinstall your sound / headset drivers. Make sure to install the latest version.
    Also try the following:
    If you have echo cancellation enabled - disable it and test it again (Tools -> options -> capture)
    Try setting another capture format in windows (Right click speaker in systray -> Recording -> dbl click microphone -> Advanced)
    Try direct sound (tools -> options -> capture)
  4. #49
    August 2012
    I have tried all of those suggestions with no joy. So I'll have to keep on using the headset directly.
    This problem with TS3 seems to be similar to a problem I am having with DayZ, which is the only other application I have that cannot use the default capture device, but unfortunately DayZ does not offer the option to directly select the capture device, so I have lost voip completely in the game.
    It was working fine up until recent windows updates (not sure which one), so I am helpless to solve the issue Microsoft have created, which is why I hate Windows.
    Thanks for your help.
  1. Error, Could not open Capture device???
    By Alfred_Timperley in forum General Questions
    Last Post: December 28th, 2015, 07:03 PM
  2. Error Could Not Open Capture Device
    By |DHC|John in forum Windows
    Last Post: March 26th, 2014, 04:06 PM
  3. Error, could not open Capture Device.
    By feral in forum Windows
    Last Post: January 5th, 2012, 05:05 PM
  4. Error: Could not open selected capture device. HELP!!!!!
    By CrispyFries in forum Bug Reports [EN/DE]
    Last Post: August 19th, 2011, 08:02 PM
  5. Replies: 1
    Last Post: April 19th, 2011, 07:47 PM
