Results 1 to 6 of 6
    October 2010
    11
    Exclamation Problem with Server
    iīve got the following Problem:
    I want to host my TS3 Server on a Root Server with 2 IP Adresses.
    Where can i config which IP is used for Teamspeak?.
    I read, i have to create a ts3server.ini
    I creat one with the following Parameters:
    machine_id=
    default_voice_port=9987
    voice_ip=78.111.76.166
    licensepath=
    filetransfer_port=30033
    filetransfer_ip=78.111.76.166
    query_port=10011
    query_ip=78.111.76.166
    dbplugin=ts3db_sqlite3
    dbpluginparameter=
    dbsqlpath=sql/
    logpath=logs
    logquerycommands=0
    Then i want to start the Server, but nothing happend.
    Where could i config, which IP Adress Teamspeak should use?
    Illiminator31
    May 2010
    6,310
    Wich command do you use to start your server ?
    (On windows, you can start with a dos window or create a shortcut with the start parameter "inifile=ts3server.ini" at the end of the target)
    October 2010
    11
    Hy,
    i use the Normal Windows TS3 64bit Server.
    I try to use the inifile=ts3server.ini command.
    Illiminator31
    EDIT: Ok, the Server did not Start. He does nothing...
    Whats wrong?
    The Shortcut path is: "C:\Documents and Settings\Administrator\Desktop\teamspeak3-server_win64-3.0.0-beta30\teamspeak3-server_win64\ts3server_win64.exe" inifile=ts3server.ini
    The name of my Ini File is ts3server.ini and it is in the same Dictory as the .exe
    May 2010
    6,310
    What do you get in the server log (post here)?
    October 2010
    11
    EDIT:
    Hy, it now works.
    My Mysql Server was crashed and i donīt recognize it.
    Now the Server is running
    Illiminator31
    May 2010
    6,310
    To try (if it's a fresh install):
    Delete the ts3server.sqlitedb file (on the server folder), and start your server.
  1. Replies: 2
    Last Post: January 1st, 2014, 03:13 AM
  2. [Resolved] Problem Internal Server " retrieving data " 25 % people got that same problem.
    By hunterpl in forum Bug Reports [EN/DE]
    Last Post: June 20th, 2012, 04:44 PM
  3. Replies: 2
    Last Post: July 18th, 2011, 08:44 PM
  4. Replies: 4
    Last Post: June 14th, 2011, 05:55 PM
