Page 10 of 11 FirstFirst ... 891011 LastLast
Results 136 to 150 of 160
  1. #136
    4,319
    Clients are sorted by their talk power. If you do not use talk power on your server, you can delete the talk power from every server and channel group. Then the users are sorted by name.
  2. #137
    December 2017
    7
    How to sort groups from least to greatest
    For example: I have 6 server groups another person is on top of me with only 3 server groups, how can I sort it to where whoever has most server groups is on top, and the least go towards the bottom
  3. #138
    May 2018
    Sorting in Channel
    I've created a ranksystem an sort my users by theit Ranks - which are groups.
    But, The Server and CHannel admin am always on top. How can I be ranked by my Servergroup and not be on top of all others?
  4. #139
    May 2018
    Issue with rank order in channels.
    When in channels the places where the ranks sit are always messed up. It is a police community so we have PC, Chief Constables etc, and the Chief Constable is below the PC's. Help!
  5. #140
    July 2010
    Earth
    74
    i_group_sort_id Is the permission you want to play with.
    But you cant not mix up channel groups and server groups.
    Channel groups will always be most left from server groups, regardless of their sort ID. That´s possibly because of the tier the channel groups are on.
  6. #141
    May 2018
    Ordering clients based on server groups help
    Hello!
    I am trying to change how clients are ordered on my server based on server groups.
    For example:
    - Owner
    - Admin
    - Moderator
    - Helper
    - Super Donor
    - Donor
    - Defaults
    Any help would be appreciated!
  7. #142
    May 2016
    Talk Power Question
    Am I able to set Client Talk Power on a group without the users being re-ordered? I have groups that have talk power to order them and I want another group that they have to have a higher talk power but just changing that will change the order they are in when they are in a channel.
    If you need any other clarification please let me know.
    Thanks
  8. #143
    17,714
    Talk Power of user define the order they are shown in server tree.
    This can not be changed when both users have the same group.
  9. #144
    May 2017
    Sorting icons to the right of your name!
    Hello! I think this is my first post here. So i've had this problem now for QUIIIIITE a while, and i really want to get rid of it now. So i have a couple of server groups (16 in total), which i want to appear in a specific order to the right of someones name in order to make it look more organized, but the problem starts when some people arent supposed to get 2 or 3 groups and it all throws it out of order. And i've also noticed that, whenever i give someone mod or admin or such, the mod/admin icon shows its way between some groups which makes it look AWFUL. So i want to be able to decide exactly in what order groups will be shown, but no clue how.
    If i remember right, a friend of mine had it like, the icons would show in order of which she gave it to them. If she would give someone server groups "1, 2 and 3", they would appear as 1 being all the way to the right, 2 in the middle and 3 to the left. Or the other way around, but i hope you understand what i mean. Is that even possible anymore?
    So no matter what way, i want them organized and there must be a way to do so right?
    Thanks in advance!
    WeezMe
    Last edited by dante696; July 4th, 2018 at 07:32 AM. Reason: moved to permissions section
  10. #145
    17,714
    Group icons in server tree are sorted the same way as their group is sorted.
    Sort order is as following:
    1. After value set in permission i_group_sort_id in the group.
    2. The group ID when permission i_group_sort_id isn't set or permission value is the same.
  11. #146
    July 2018
    NB, Canada, North America, Earth, Milky Way, Virgo supercluster, observable Universe
    First Thing I would do if you haven't already is turn on Advanced permission mode In Teamspeak
Name:	Advanced permission set P1.PNG
    After you've done that have a look at your permissions Groupsort ID which looks like this
Name:	Group Sort ID.PNG
    When you have it configured It should look like this
    Group Sort number 1 is at the top of the list descending in order. Number 1 will be furthest to the left (So Commander in my example is the furthest to the left) on your clients screen, You can put multiple Groups under the same group ID but in that case I think it sorts alphabetically (But just a guess on my part.) I recommend skipping a few numbers here and there to leave room to add more groups in the future, I started with 1,3,5,7,9 ECT to give room for expansion.
  12. #147
    July 2018
    Sorting users by Talk Power somehow doesn't work
    So I wanted to sort the users in the channel by their Server Group (using the Talk Power)
    But it somehow doesnt work for some reason.
    Does anyone know that problem?
  13. #148
    17,714
    Maybe a group or channel permission overwrite the talk power.
    Check the permissions of the users via Permissions Overview (right click on user > Permissions).
  14. #149
    July 2018
    That actually helped, thank you very much
  15. #150
    17,714
    You may enable the Skip flag for their talk power. So channel groups will have no effect on their talk power in the future.
  1. [Resolved] How to sort users in channel
    By littledave in forum Permission System
    Last Post: March 24th, 2015, 03:40 AM
  2. [Resolved] How to sort groups
    By Daniel123 in forum Permission System
    Last Post: August 4th, 2013, 06:11 PM
  3. [Resolved] How to: Sort Groups/Users
    By auroxx in forum General Questions
    Last Post: August 3rd, 2011, 10:07 AM
  4. Sort Server and Channel Groups DB ID
    By Col_Crunch in forum Permission System
    Last Post: July 27th, 2011, 06:35 PM
  5. [Suggestion] Ability to arrange/sort groups order
    By -{HGH}-GEN.Skylab in forum Suggestions and Feedback
    Last Post: March 29th, 2010, 09:28 PM
