Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 76 to 90 of 163
  1. #76
    2,698
    Quote Originally Posted by CrazyT666 View Post
    What's the right for the sortorder in the clienttree for single groups for example:
    Other classic thread, from 2010, post#2:
    http://forum.teamspeak.com/showthrea...ght=priorities
  2. #77
    February 2014
    Sorting channels independently by channel ID
    Hi, how can i change sequence my channels independently to channel ID like this ? Click image for larger version.
    Result is Click image for larger version.
    Flags under flags, ranks under ranks independently to their channel ID
    Please step by step manual.
    Thanks, buddyns
  3. #78
    4,365
    Read this.
    By the way, these are called Groups, not Channels.
  4. #79
    March 2014
    [HELP]Order grups on chanel.
    I need help with setting the order of ranks users visibility to channels. My point here is that people with the best ranking were the first on the channel than those with lower rank.
    Last edited by dante696; March 12th, 2014 at 03:52 PM. Reason: merged, please use search function first
  5. #80
    March 2014
    Order of Server Group List
    Sorry if this has been posted before, as I imagine it has - I couldn't come up with any results under search.
    What I am trying to do is basically put Knight, Lordship, and Soldier in ID 10, 11, 12 - instead of 30, 31, 32
    That way, they appear before the other icons next to the users name.
    EDIT:
    "Yes. You can arrange the icons using the i_group_sort_id permission. You still can not change the actual ID of the group, but you can change the sort order with this permission, so in your server/channel group dialogs and menus you can have the ranks in the correct order."
    This post can now be closed.
  6. #81
    April 2014
    Hierarchy Within Channels. How?
    Here is what I am looking for
    Channel:
    [CEO Corp 1]
    [CEO Corp 2]
    [Member Corp 1]
    [Member Corp 1]
    [Member Corp 1]
    [Member Corp 2]
    [Member Corp 2]
    [Member Corp 2]
    How can I do that?
  7. #82
    July 2014
    Moving order of groups in channels
    I need to move the order clients are in. I need to do this in descending rank.
    http://gyazo.com/d126899f9f1eb45f39c7a85bb1d32d52
    in that picture I want the icons to go Red S Gold S Red H and than Blue A is there a perm for this?
  8. #83
    April 2011
    1,266
    If you would have used the search function you might have found that clients are sorted by their talk power and equal talk power alphabetical by nickname.
  9. #84
    July 2014
    Yea I just found it thanks.
  10. #85
    July 2013
    How to group sort
    How would I get something like this, that is organized
    http://gyazo.com/2be681a3bdf4e5c4c455f06400c795d6
    That the ranks are in order?
  11. #86
    May 2006
    Europe/Czech Rep.
    1,616
    change values of permission for your server groups
    Group sort id or i_group_sort_id
    Edit: Ok, my answer is related to sorting which group icon appears where on the row.
    Answer above in this thread made by Barungar is correct if you want to sort users based on one of the groups.
  12. #87
    July 2014
    Server groups are not sorted properly
    This group: (Name:  56e1013a2ce689d8371fb0abe3f40c9e.png
Size:  882 Bytes) is a standard group if a person applies on the forums. it should be higher than a person without a group, but lower than a person with any other group.
    This group: (Name:  df5dfc08539b9afd48cb497a66d9ce8c.png
Size:  758 Bytes) is a special group assigned to moderators. It should be higher up than a the standard group, as stated above.
    However, as you can see, that is not the case. The moderator group has a talk power of 25, while the standard group has a talk power of 10. This should make the moderator group higher, and yet it doesn't. Anybody know a fix?
  13. #88
    4,365
    Read the FAQ of the appropriate forum.
  14. #89
    July 2014
    Whoops, sorry. Thought i posted in the Permissions section
    EDIT: Also, I have. As I stated, the talk power of the moderator group is higher than the talk power of the regular group. Yet the moderator group is still below it.
    EDIT2: Nevermind, I managed to fix it by adding the b_client_skip_channelgroup_permissions permission to all the groups.
    Again, sorry for posting in the wrong place!
  15. #90
    February 2015
    How to set permission value?
    Hello, I want to set my groups in order and looked at another thread asking the same question, the answer to it was set the group value to i_group_sort_id I have looked around everywhere and could not find where to set this. I have tried clicking on everything on TeamSpeak and looked all over the internet, I found one tutorial on it however, it was outdated. If anyone knows how to do this could you please let me know. Thank you!
  1. [Resolved] How to sort users in channel
    By littledave in forum Permission System
    Last Post: September 10th, 2019, 04:06 AM
  2. [Resolved] How to sort groups
    By Daniel123 in forum Permission System
    Last Post: August 4th, 2013, 07:11 PM
  3. [Resolved] How to: Sort Groups/Users
    By auroxx in forum General Questions
    Last Post: August 3rd, 2011, 11:07 AM
  4. Sort Server and Channel Groups DB ID
    By Col_Crunch in forum Permission System
    Last Post: July 27th, 2011, 07:35 PM
  5. [Suggestion] Ability to arrange/sort groups order
    By -{HGH}-GEN.Skylab in forum Suggestions and Feedback
    Last Post: March 29th, 2010, 10:28 PM
