Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 76
  1. #31
    18,513
    There is a ticket (TS-644) for that in our list.
    And the current plan says, we add this feature with 3.0.4 . But it does not mean, that it can't get delayed.
  2. #32
    February 2010
    brazil
    55
    i made a post about the tsdns and after reading this one i was wondering.
    so if you add the srv/txt suport, then what? you will be able to set the ip/port at your domain holder?
    if that is the case, here is something i think is relevant:
    -some domain holders have cheap plans with limited number of records that you can add to your domain
    -in case you have a redundant system, if one machine fails, doesn't you need to change the ip from the domain record at your domain holder? in that case you will have a problem, for most ppl the dns gets cached and when some domain changes his ip it might take some time until you get the new one.
    so i think the tsdns is a great idea, i just think we should have a different approach.
    btw i don't see tsdns eating my vps resources, even when i was running my whole server under a vps with 200mb ram, it wasn't a problem for me.
  3. #33
    March 2010
    Australia
    16
    <3 <3 <3
    Quote Originally Posted by loest View Post
    I no not believe TS will not remove tsdns support when support for SRV records are added. I'm guessing the behaviour will be similar to when TSDNS is not found it falls back to just using the IP address that the hostname points to.
    The main use case for TSDNS is for automagic configuration of host names where a single TS3 server hosts multiple instances (ie, for a TS3 provider, etc) - not for redundancy, and usually the TSDNS server would reside on the same host as all the TS3 servers that it services.
    For redundancy with TSDNS, I believe it is currently achievable (although I haven't looked into it much, so your mileage may vary) by setting say multiple A records to multiple machines, and on each of them running TSDNS on it with synchronised data (although I think one would have to manually sync the data as there is no way I am aware of to sync it automatically, but feel free to correct me if I'm wrong) to achieve redundancy - on the other hand, DNS is already rather redundant, so by using SRV records you gain this for free, as well as the ability to have fallback and load balancing options.
    Assuming the fallback methods mentioned above, there is no reason not to implement SRV records - if you have suggestions on changes to how TSDNS works, you're probably best off creating another thread for it.
  4. #34
    February 2010
    brazil
    55
    yeah well you can get some redundancy if you use like, ts1.ts2.ts3.mydomail.com to connect, them it will try to connect too all of them if some fails. but that is just not usable :P.
    but hmm i don't think you can set more than one ip for a cname record, in that case you would need to have a priority for each of them, like we have at mx records. which is basic my whole idea, make the tsdns use cname records as if they were mx ones. so the client can check for more than one ip in case it fails.
    in my opinion i think tsdns should check only some subdomains for ips, so you set at your domain 3 records, like
    ts1.mydomain.com
    ts2.mydomain.com
    ts3.mydomain.com
    each one can point to any ip, where there will be a tsdns server running, and after that the tsdns checks for the clan-name.mydomain.com, on the domain.
  5. #35
    October 2003
    2,527
    And the current plan says, we add this feature with 3.0.4 ....
    If I remember correctly, there won't be a 3.0.4 release...
  6. #36
    18,513
    Opinions and plans can change and the current plan says it'sa 3.0.4 feature.
    We use the client version in our system, even when server version will be 3.0.2 or 3.0.3.
  7. #37
    January 2004
    Levittown, NY
    27
    Just wanted to say thank you for your work on supporting SRV records, I can't wait! And dante696, I love you man, I just don't have any teddy bear pictures to share.
  8. #38
    December 2011
    Russian
    Quote Originally Posted by Dygear View Post
    be more careful, for bears - ban
    Amazon Route 53
    WRR + TTL=0
  9. #39
    St.Petersburg, Russia
    137
    DNS SRV records support
    This was asked many times in various threads and I decided to create a dedicated feature request thread for it.
    A lot of real system administrators need a proper way to set up virtualhosting. And support for DNS SRV records is a solution. All you need is to query _ts3server._udp.example.com (i.e. host -t srv _ts3server._udp.arts.bsrealm.net) and if the record exists, use information from it. If record does not exist, proceed with TSDNS method. This should be really easy to support since it's just an additional dns query on a client side, no server side modifications needed.
  10. #40
    March 2010
    Australia
    16
    It's already on the TODO as per http://forum.teamspeak.com/showthrea...TXT-SRV-Record
    Still waiting on that one myself personally too.
  11. #41
    February 2012
    Denmark
    Unhappy
    Client 3.0.4 was skipped and was never official released
    This is just so sad... (and looks like ScP was right..)
    So, what version does the plan (for ticket TS-644) say now? 3.0.6? 3.0.7? (... 3.99.999? xD)
    And, can I bribe you guys with bacon?
  12. #42
    137
    Thought about the same when read that notice about 3.0.4..
  13. #43
    18,513
    Was my full answer to this feature.
    All ticket get moved into the next client release automatically, when a ticket wasn't touched
    It's still on our todo and currently as 3.0.6 > My answer stays the same. It can get deleayed.
  14. #44
    137
    How much longer are you going to delay a request that only requires 2-3 lines of code and max 15 minutes of work? 3.0.6 is out on beta channel and still doesn't have it.
  15. #45
    March 2010
    Australia
    16
    Quote Originally Posted by shadow_lmd View Post
    Now now, it hasn't even been a year yet since it was added to the TODO! 2-3 lines of code most likely require massive testing to ensure it won't make things explode. (Anyway it's probably more like a dozen odd when you consider proper formatting, a single if statement with one line of code in it is 4 lines if you have opening braces on their own lines for example - 2-3 lines of real code perhaps, but a dozen considering formatting like braces and whitespace...)
  1. SRV Record Help
    By FPSDinu in forum General Questions
    Last Post: January 29th, 2013, 02:05 PM
  2. SRV Record Help
    By GWAVE23 in forum General Questions
    Last Post: January 21st, 2013, 04:45 PM
