Results 31 to 45 of 57
  1. #31
    May 2011
    7
    yeah i tryed it. nothing work. it keeps freezing if i test my mic. it keeps freezing alltime! pls fix it!thx
  2. #32
    May 2011
    hello,
    sorry my english isnt the best one. i have this problem too. before the last update comes, i works fine all the time. after the update ... i have the same problem that after a short time - ts3 client is freezing. i dont hear any sounds. if i kill the ts3client.exe from my taskmanager - the sounds are back.
    i use windows 7 professional 32bit - on an athlon xp 3500+ processor.
    my logfile looks like this one:
    2011-05-24 20:03:15.385742|INFO    |              |   | Logging started, clientlib version: 3.0.0-rc1 [Build: 14345]
    2011-05-24 20:03:15.625976|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2011-05-24 20:03:16.221679|INFO    |              |   | Registering plugin command id: {6461c155-7efd-4597-9eb3-27e04e042708} appscanner_plugin
    2011-05-24 20:03:16.747070|INFO    |Query         |   | listening on 127.0.0.1:25639
    2011-05-24 20:03:16.748046|INFO    |              |   | Registering plugin command id: {5b72c45d-cf97-4f5e-a8a6-17924e20e8f8} clientquery_plugin
    2011-05-24 20:03:19.703125|INFO    |GenericPlayback|   | STOPWATCH1 closePlaybackDevice: 0 ms -1
    2011-05-24 20:03:24.489257|INFO    |ClientUI      |   | TeamSpeak 3 client version: 3.0.0-rc1 [Build: 14345]
    2011-05-24 20:03:24.489257|INFO    |ClientUI      |   | Qt version: 4.7.2
    2011-05-24 20:03:24.490234|INFO    |ClientUI      |   | Using configuration location: C:/Users/rhonin/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    2011-05-24 20:03:25.077148|INFO    |ClientUI      |   | Last update check was: So 22. Mai 00:16:10 2011
    2011-05-24 20:03:25.077148|INFO    |              |   | Checking for updates...
    2011-05-24 20:03:26.027343|INFO    |              |   | Update check, my version: 14345, latest version: 14345
    2011-05-24 20:03:52.604492|INFO    |GenericPlayback|   | STOPWATCH1 closePlaybackDevice: 0 ms -1
    2011-05-24 20:03:52.604492|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2011-05-24 20:03:52.624023|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2011-05-24 20:03:52.625000|INFO    |GenericPlayback|   | STOPWATCH1 internalOpenDevice: 20 ms -1
    2011-05-24 20:03:52.625000|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2011-05-24 20:03:52.626953|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2011-05-24 20:03:52.626953|INFO    |GenericPlayback|   | STOPWATCH1 internalStartDevice: 1 ms -1
    2011-05-24 20:03:52.626953|INFO    |GenericPlayback|   | STOPWATCH1 openPlaybackDevice: 22 ms -1
    2011-05-24 20:03:52.627929|INFO    |GenericPlayback|   | STOPWATCH1 closeCaptureDevice: 0 ms -1
    2011-05-24 20:03:52.627929|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2011-05-24 20:03:52.857421|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2011-05-24 20:03:52.857421|INFO    |GenericPlayback|   | STOPWATCH1 internalOpenDevice: 229 ms -1
    2011-05-24 20:03:52.858398|INFO    |PreProSpeex   |  1| Speex version: speex-1.2beta3
    2011-05-24 20:03:52.859375|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2011-05-24 20:03:52.860351|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2011-05-24 20:03:52.860351|INFO    |GenericPlayback|   | STOPWATCH1 internalStartDevice: 1 ms -1
    2011-05-24 20:03:52.860351|INFO    |GenericPlayback|   | STOPWATCH1 openCaptureDevice: 232 ms -1
    2011-05-24 20:09:33.523437|INFO    |GenericPlayback|   | LIMSTOPWATCH GenericPlayback::fillSoundBuffer 2: 111 ms 10
    2011-05-24 20:09:33.524414|INFO    |GenericPlayback|   | LIMSTOPWATCH GenericPlayback::fillSoundBuffer 1: 112 ms 10
    2011-05-24 20:09:33.524414|INFO    |GenericPlayback|   | LIMSTOPWATCH PlaybackManager::fillSoundBuffer 2: 112 ms 10
    2011-05-24 20:09:33.524414|INFO    |GenericPlayback|   | LIMSTOPWATCH onGetPlaybackData: 112 ms 10
    2011-05-24 20:13:18.145507|INFO    |GenericPlayback|   | LIMSTOPWATCH RecorderThread::run (wait): 2666 ms 2000
    2011-05-24 20:13:18.146484|INFO    |GenericPlayback|   | LIMSTOPWATCH RecorderThread::run: 2666 ms 2000
    2011-05-24 20:13:22.793945|ERROR   |Decode        |   | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-24 20:13:22.794921|ERROR   |Decode        |   | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-24 20:13:22.803710|ERROR   |Decode        |   | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-24 20:13:22.862304|ERROR   |Decode        |   | Stale Decoder detected, terminating it. Was ever active = 0
    is there an solution in mind ?
    regards
    thorolf
  3. #33
    June 2002
    Netherlands
    1,049
    Quote Originally Posted by cheezehaze View Post
    Yes it was not supposed to be fixed. That version should put some extra lines in the log files. Please send me a log file made by the new version when you got a freeze.
  4. #34
    May 2011
    9
    Linux test result:
    xxx:~/TeamSpeak3-Client-linux_amd64$ ./ts3client_runscript.sh
    2011-05-24 14:07:32.447078|INFO |MPSingleton | | Detected local codeset to be: UTF-8
    2011-05-24 14:07:32.447768|INFO | | | Logging started, clientlib version: 3.0.0-rc2-pre1 [Build: 14412]
    2011-05-24 14:07:32.454613|DEBUG |PulseAudio | | connected to pulse audio server
    2011-05-24 14:07:32.473454|INFO | | | Registering plugin command id: {01dcbb0c-17cf-42a8-bdc8-7065ca22ef9d} appscanner_plugin
    PLUGIN: registerPluginID: {01dcbb0c-17cf-42a8-bdc8-7065ca22ef9d}
    2011-05-24 14:07:32.625621|INFO |ClientUI | | Failed to init text to speech engine
    2011-05-24 14:07:32.625865|INFO |ClientUI | | TeamSpeak 3 client version: 3.0.0-rc2-pre1 [Build: 14412]
    2011-05-24 14:07:32.625963|INFO |ClientUI | | Qt version: 4.7.2
    2011-05-24 14:07:32.626055|INFO |ClientUI | | Using configuration location: xxx/.ts3client/ts3clientui_qt.conf
    2011-05-24 14:07:33.442703|INFO |ClientUI | | Last update check was: Di. Mai 24 14:03:59 2011
    2011-05-24 14:07:37.395493|INFO | | | No TSDNS found at "xxx"
    2011-05-24 14:07:37.813952|INFO |PreProSpeex | 1| Speex version: 1.2rc1
    QFSFileEngine:pen: No file name specified
    2011-05-24 16:00:16.980945|ERROR | | | Long Running Function client/clientlib/sound/sounddevicemanager.cpp:568
    2011-05-24 16:00:16.981066|ERROR | | | Long Running Function client/clientlib/sound/sounddevicemanager.cpp:1371
    2011-05-24 16:00:16.981105|ERROR | | | Long Running Function client/clientlib/sound/playbackmanager.cpp:305
    2011-05-24 16:00:16.981139|ERROR | | | Long Running Function client/clientlib/sound/playbackmanager.cpp:393
    2011-05-24 16:00:16.981173|ERROR | | | Long Running Function client/clientlib/sound/genericplayback.cpp:417
    2011-05-24 16:00:16.981207|ERROR | | | Long Running Function client/clientlib/sound/genericplayback.cpp:705
    ^C
  5. #35
    June 2002
    Netherlands
    1,049
    Thank you. It looks like help full results. I will look at them tomorrow.
  6. #36
    June 2002
    Netherlands
    1,049
    thorolf: Did you try the test version in post 26 and waited at least 12 seconds before killing ts3 client? The information in the log produced by that version could help me find this problem
  7. #37
    18,153
    We hope to fix this bug with our latest pre version of our Rc2 client.
    Please download it and update your client.
    Rc2-pre2 for Windows 32-bit or
    Rc2-pre2 for Windows 64-bit
    - Please give us some feedback, when it solved your problem.
    - If this does not solve your problem
    Give us feedback and some logfiles from your client, to get more informations about this problem.
    This client sends more informations to your log files, when something went wrong.
  8. #38
    18,153
    I can reproduce Stale Decoder when i unplug my G35 :-/
    I try to find out what's going on, my config is weired
    Build14512
    25.05.2011 15:47:40 SoundDevManager Info Default device changed
    25.05.2011 15:47:45 Decode Error Stale Decoder detected, terminating it. Was ever active = 0
    Edit
    Internal ticket ID TS-546
  9. #39
    May 2011
    9
    Is this fix attempt only present in the Windows version or the Linux rc2 too?
    *EDIT Ok no rc2pre for Linux available so ignore the question
  10. #40
    18,153
    Windows only at this moment. Looks like Direct sound causes some problems here.
    Do you get Stale decoder on linux too?
  11. #41
    June 2002
    Netherlands
    1,049
    No, this fix is for all versions. That includes linux
  12. #42
    May 2011
    7
    Exclamation .
    hello,
    my teamspeak 3 client dont work with:
    2011-05-25 22:12:34.261675|INFO | | | Logging started, clientlib version: 3.0.0-rc2-pre2 [Build: 14508]
    2011-05-25 22:06:36.790229|INFO | | | Logging started, clientlib version: 3.0.0-rc1 [Build: 14345]
    logfiles u can download free here: https://rapidshare.com/files/4159092...chiv__neu_.zip
    edit:
    My Computer:
    Cpu: Intel Core 2 Quad 9550 @ 3.2 Ghz
    Mainboard: Asus Maximus 2 Formula
    Ram: Kinston Hyper X 4 GB
    Soundcard: Creative Surpreme FX from Asus Maximus 2 Formula
    Tell me what i have to do to help updating teamspeak.
  13. #43
    May 2011
    9
    Nope, I get the log like I posted, more info is sadly not available.
    Quote Originally Posted by nwerensteijn View Post
    And where can I get the rc2pre2 linux client?
  14. #44
    18,153
  15. #45
    May 2011
    9
    Thumbs up
    The Linux rc2pre2 version seems to work for now, but couldn't test it with a reasonable amount of other people on the ts yet.
    So a cautious "yaaaay it works"
  1. Replies: 14
    Last Post: November 10th, 2013, 10:13 AM
  2. [Resolved] Stale Decoder detected 3.0.8
    By balkanspy in forum Windows
    Last Post: August 5th, 2012, 07:21 PM
  3. Stale Decoder Detected .... Was ever active = 0
    By Pflanzenkuh in forum Client Support
    Last Post: January 4th, 2012, 06:20 PM
  4. Client 3.0.1 Stale decoder ... terminating forcefully
    By Daytrader in forum Bug Reports [EN/DE]
    Last Post: November 19th, 2011, 07:21 PM
  5. [3.0.1] Stale Decoder Detected .... Was ever active = 1
    By meiskam in forum Bug Reports [EN/DE]
    Last Post: November 18th, 2011, 07:37 PM
