Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
    November 2010
    US - Ohio
    21
    Unhappy Client: TS3 RC1 Keeps Freezing? Stale Decoder
    Edit by mod
    Please read this post, before you begin to type any report into this thread
    http://forum.teamspeak.com/showthrea...589#post284589
    Okay, so I've been running my own Teamspeak 3 server from my computer since January of this year. Teamspeak has always worked fine for me, until I got the RC 1 update today. I am running Windows 7 32 bit, and suddenly my teamspeak will freeze, my dot won't light up and someone's dot will stay lit but I don't hear anything. I look in my process manager and it's taking up 80 - 100% of my CPU usage. The only way I can stop it is to end the process and reopen it, where I will then see a clone of myself in the teamspeak until it times out. This has happened to me 4 times now, at first I thought I was running too many programs but now I was barely running anything and it happened. I really like a lot of the changes, but I don't like this. What should I do about it?
    July 2002
    2,192
    Quote Originally Posted by FierceFrankie View Post
    Give us some more information so we can fix it
    (1) What CPU is this?
    (2) Can you paste the Client Log File of a Session where the problem occurred?
    November 2010
    US - Ohio
    21
    CPU - AMD Athlon 64 Processor 3500+ 2.20 GHz
    Where would I find the Client Log Files?
    I looked in C:\....\AppData\Local\TeamSpeak 3 Client\config\logs
    and I found some logs, but the most recent one is from April 8th for some reason. Is there a way I can find out where my client logs are being saved to now?
    Krün, Germany
    510
    By default the logs should be in e.g. C:\Users\peter\AppData\Roaming\TS3Client
    In the unlikely case you happened to have run the installer and selected saving the config in the installation folder instead the users directory, the logs will be in <TS-install-path>\config
    The path you mentioned sounds like you did a local install (into Appdata\Local instead of C:\Program Files). You might have reinstalled later using the default install and config paths, which might explain why the log directory had changed for you.
    November 2010
    US - Ohio
    21
    Okay, so one log says the following like 50 times:
    2011-05-12 02:31:50.817382|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    Another log says that 50 times, and then is followed by the following several times:
    2011-05-12 02:32:17.576171|ERROR |GenericPlayback| | Stale gracefull playback detected, terminating forcefully
    The other logs the last thing is just:
    2011-05-12 08:03:21.874023|INFO |GenericPlayback| | LIMSTOPWATCH RecorderThread::run (wait): 2890 ms 2000
    2011-05-12 08:03:21.874023|INFO |GenericPlayback| | LIMSTOPWATCH RecorderThread::run: 2890 ms 2000
    2011-05-12 08:04:17.580078|INFO |GenericPlayback| | LIMSTOPWATCH RecorderThread::run (wait): 2041 ms 2000
    2011-05-12 08:04:17.580078|INFO |GenericPlayback| | LIMSTOPWATCH RecorderThread::run: 2042 ms 2000
    2011-05-12 08:05:19.680664|INFO |GenericPlayback| | LIMSTOPWATCH RecorderThread::run (wait): 2070 ms 2000
    2011-05-12 08:05:19.680664|INFO |GenericPlayback| | LIMSTOPWATCH RecorderThread::run: 2071 ms 2000
    May 2011
    9
    Same behavior here with the Línux client. Randomly crashes with cpu usage going to 100%, activity dot of someone else is lit. Program is not responding. Mostly (not only) happens when wine (with eve) is running.
    I'm running debian amd64 with pulseaudio and wine-pulseadio. Former client (with fmod?) worked like a charm.
    wine-pulseaudio 1.3.19
    pulseaudio 0.9.22
    Changing pulseaudio backend to esd and deactivating sound in eve under wine didn't help.
    Teamspeak crashes really randomly, sometimes runs for 30 minutes, then again 5 seconds after I connected to a server.
    Logs sadly don't give a clue:
    xxx:~/TeamSpeak3-Client-linux_amd64$ ./ts3client_runscript.sh
    2011-05-12 18:27:40.582131|INFO |MPSingleton | | Detected local codeset to be: UTF-8
    2011-05-12 18:27:40.583275|INFO | | | Logging started, clientlib version: 3.0.0-rc1 [Build: 14345]
    2011-05-12 18:27:40.688567|DEBUG |PulseAudio | | connected to pulse audio server
    2011-05-12 18:27:40.706711|INFO | | | Registering plugin command id: {89e10ef3-51d8-42c5-b5e9-940347e7e6cb} appscanner_plugin
    PLUGIN: registerPluginID: {89e10ef3-51d8-42c5-b5e9-940347e7e6cb}
    2011-05-12 18:27:41.193609|INFO |ClientUI | | Failed to init text to speech engine
    2011-05-12 18:27:41.193743|INFO |ClientUI | | TeamSpeak 3 client version: 3.0.0-rc1 [Build: 14345]
    2011-05-12 18:27:41.193781|INFO |ClientUI | | Qt version: 4.7.2
    2011-05-12 18:27:41.193814|INFO |ClientUI | | Using configuration location: xxx/.ts3client/ts3clientui_qt.conf
    2011-05-12 18:27:43.201784|INFO |ClientUI | | Last update check was: Do. Mai 12 17:47:34 2011
    2011-05-12 18:27:45.661182|INFO | | | No TSDNS found at "xxx"
    2011-05-12 18:27:45.814737|INFO |PreProSpeex | 1| Speex version: 1.2rc1
    QFSFileEngine:pen: No file name specified
    ^C
    Yeah the ^C is ctrl-c when the client is crashed.
    November 2010
    US - Ohio
    21
    It just did it again, my teamspeak froze up and caused my entire computer to freeze, thus lagging my teamspeak server and making everyone disconnect because I host the server from my computer, and I have to hear people complain because they were in the middle of talking while playing a game when the server lagged out.
    November 2010
    US - Ohio
    21
    It does this until I force close it:
    2011-05-12 22:53:01.337890|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.357421|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.367187|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.387695|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.425781|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.445312|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.484375|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.503906|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.523437|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.542968|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.562500|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.582031|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.601562|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.630859|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.650390|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.669921|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.718750|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.728515|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.758789|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.768554|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 22:53:01.806640|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    18,151
    We are aware of this bug, but we have problems to reproduce it at ths moment.
    It appears randomly and :-/
    May 2011
    So you mean that there's no solution atm?
    18,151
    Our developer tries to identify the problem, this is all, what i can say at this moment.
    May 2011
    7
    Exclamation
    my title says everything.
    since the update was @ 11.5.11 my Teamspeak crashes, if i want to enter the options or after 2 min. I cant speek i cant here anythink. i dont know what i have to do!
    pls help and sorry for my bad english
    cheezehaze
    my last log @ 12.5.11
    and i allready reinstalled it.
    2011-05-12 18:53:32.566649|INFO | | | Logging started, clientlib version: 3.0.0-rc1 [Build: 14345]
    2011-05-12 18:53:32.581650|DEBUG |Direct Sound | | setting timer resolution to 1ms
    2011-05-12 18:53:32.606651|INFO | | | Registering plugin command id: {ba5b8f11-2992-49cc-874b-2cde61d53ae9} appscanner_plugin
    2011-05-12 18:53:32.608651|INFO |Query | | listening on 127.0.0.1:25639
    2011-05-12 18:53:32.608651|INFO | | | Registering plugin command id: {4ca01eec-f27c-481b-b560-a3f59a6e04ca} clientquery_plugin
    2011-05-12 18:53:32.657654|INFO |GenericPlayback| | STOPWATCH1 closePlaybackDevice: 0 ms -1
    2011-05-12 18:53:32.985673|INFO |ClientUI | | TeamSpeak 3 client version: 3.0.0-rc1 [Build: 14345]
    2011-05-12 18:53:32.985673|INFO |ClientUI | | Qt version: 4.7.2
    2011-05-12 18:53:32.985673|INFO |ClientUI | | Using configuration location: E:/Program Files/TeamSpeak 3 Client/config/ts3clientui_qt.conf
    2011-05-12 18:53:33.271689|INFO |ClientUI | | Last update check was: Do 12. Mai 13:06:00 2011
    2011-05-12 18:53:51.045706|INFO |GenericPlayback| | STOPWATCH1 closePlaybackDevice: 0 ms -1
    2011-05-12 18:53:51.045706|DEBUG |Windows Audio Session| | WAS:penDevice-enter
    2011-05-12 18:53:51.056707|DEBUG |Windows Audio Session| | WAS:penDevice-leave
    2011-05-12 18:53:51.056707|INFO |GenericPlayback| | STOPWATCH1 internalOpenDevice: 11 ms -1
    2011-05-12 18:53:51.057707|DEBUG |Windows Audio Session| | WAS::startDevice-enter
    2011-05-12 18:53:51.057707|DEBUG |Windows Audio Session| | WAS::startDevice-leave
    2011-05-12 18:53:51.057707|INFO |GenericPlayback| | STOPWATCH1 internalStartDevice: 0 ms -1
    2011-05-12 18:53:51.057707|INFO |GenericPlayback| | STOPWATCH1 openPlaybackDevice: 11 ms -1
    2011-05-12 18:53:51.057707|INFO |GenericPlayback| | STOPWATCH1 closeCaptureDevice: 0 ms -1
    2011-05-12 18:53:51.057707|DEBUG |Windows Audio Session| | WAS:penDevice-enter
    2011-05-12 18:53:51.069707|DEBUG |Windows Audio Session| | WAS:penDevice-leave
    2011-05-12 18:53:51.069707|INFO |GenericPlayback| | STOPWATCH1 internalOpenDevice: 11 ms -1
    2011-05-12 18:53:51.069707|INFO |PreProSpeex | 1| Speex version: speex-1.2beta3
    2011-05-12 18:53:51.069707|DEBUG |Windows Audio Session| | WAS::startDevice-enter
    2011-05-12 18:53:51.070707|DEBUG |Windows Audio Session| | WAS::startDevice-leave
    2011-05-12 18:53:51.070707|INFO |GenericPlayback| | STOPWATCH1 internalStartDevice: 0 ms -1
    2011-05-12 18:53:51.070707|INFO |GenericPlayback| | STOPWATCH1 openCaptureDevice: 12 ms -1
    2011-05-12 18:54:02.203344|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.233346|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.253347|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.263348|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.283349|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.313350|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.333352|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.344352|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.363353|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.393355|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    2011-05-12 18:54:02.414356|ERROR |Decode | | Stale Decoder detected, terminating it. Was ever active = 0
    my log after reinstall @ 12.5.11 i dont
    November 2010
    US - Ohio
    21
    A few other people in my server have been having the same problem. Stale decoder and it randomly tries to crash the entire computer. It's been happening to me several times a day, and it does occur randomly. Sometimes I'm just in the away channel with my mic muted with nobody else in the teamspeak and it happens. :-/
    The MAIN reason this concerns me is that when it starts freezing my computer from which I host my teamspeak server (since Nov. 2010), it causes everyone else to lag and timeout from the server because my teamspeak froze my computer. I had to hit the power button on my computer and force shut down the computer 2 times the first day it started happening because I was running a game and watching a TV show at the same time.
    May 2011
    teamspeak locking up
    ever since i downloaded the latest update a few days ago my teamspeak client locks up about 4 times a day and i have to close and restart...if im talking when it happens my mic will lock open, if im no talking my mic will lock closed....basically everything locks and i cant do anything....any help on this matter would help out greatly thank u
    November 2010
    US - Ohio
    21
    Look here: http://forum.teamspeak.com/showthrea...-Stale-Decoder
    Sounds like it might be the same thing... If it is, they don't know what's causing it OR how to fix it... Sucks for us people with that problem.
  1. Replies: 14
    Last Post: November 10th, 2013, 10:13 AM
  2. [Resolved] Stale Decoder detected 3.0.8
    By balkanspy in forum Windows
    Last Post: August 5th, 2012, 07:21 PM
  3. Stale Decoder Detected .... Was ever active = 0
    By Pflanzenkuh in forum Client Support
    Last Post: January 4th, 2012, 06:20 PM
  4. Client 3.0.1 Stale decoder ... terminating forcefully
    By Daytrader in forum Bug Reports [EN/DE]
    Last Post: November 19th, 2011, 07:21 PM
  5. [3.0.1] Stale Decoder Detected .... Was ever active = 1
    By meiskam in forum Bug Reports [EN/DE]
    Last Post: November 18th, 2011, 07:37 PM
