Results 1 to 9 of 9
    July 2010
    USA
    18
    Solved Default TTS and third party soundpacks don't work for me.
    I recently noticed that the "Default text to speech soundpack" and any third party soundpacks I enable don't seem to work at all, only the default soundpack works.
    I completely wiped my TS3 installation and re-installed it, re-installed my skin and my soundpacks...same problem.
    After some google searching I am led to believe that it is my operating systems fault. I am running Windows XP Pro SP3, but I copied the contents of my installation CD to my hard drive / ran it through nLite / turned it in to a "lite" install. Because of this, I believe I am missing some sort of Windows TTS components which may be the cause of the problem.
    Could anyone confirm this for me, and point me to where I can get these missing files and install them?
    July 2010
    USA
    18
    Wow...not a single reply in over two months? Wow.
    18,513
    These custom soundpacks are outdated, that's all.
    The creator of such a soundpack needs to know, that some sounds have been changed during the beta/RC state.
    July 2010
    USA
    18
    It's actually not the soundpacks, it's my installation of Windows. I made a customized "lite" install and I somehow removed the Windows TTS software/engine/drivers.
    I'm trying to find out if there's other free TTS software/engine/drivers I could use that will allow me to use soundpacks and phonetic names with TS? I know this problem will be fixed if I re-install windows, but I really don't want to do that.
    18,513
    Maybe it is possible to install it, over system control > software > Install/activate Windows... ? but you will need a real Windows CD
    July 2010
    USA
    18
    I have my original XP Pro SP3 CD that I made the lite install from, it's a legit/legal copy of windows I just wanted to make a custom install cd from it to get rid of some of the extra garbage windows comes with.
    Unfortunately, the default Windows TTS software/engine/drivers are not something you can add/remove within windows or within the repair function when you boot from the install CD. Microsoft also doesn't offer these software/engine/drivers from their website. My only two options are to either find a third-party TTS software/engine/drivers, or reformat my computer and use my full installation of Windows rather than my custom lite install. I'm trying to find a third-party software/engine/drivers, but I don't know which one would allow my TS soundpacks/tts/phonetic stuff to work.
    18,513
    I guess all of them would allow you to use it for TS, but you need to pay these voices.
    July 2010
    USA
    18
    Are you familiar with any third-party TTS engines for Windows?
    18,513
    Sorry,
    I can't give you any hints here. I never used a TTS engine
  1. Default channel only work for me
    By lala99 in forum Client Support
    Last Post: January 17th, 2012, 01:31 PM
  2. default ts3-3.0.0 soundpacks missings
    By DJBlackLight in forum General Questions
    Last Post: August 11th, 2011, 03:10 PM
  3. [Resolved] default settings wont work
    By w2323 in forum Client Support
    Last Post: July 4th, 2011, 04:45 PM
  4. Default Text to Speech does not work
    By Askari in forum General Questions
    Last Post: January 28th, 2010, 08:59 PM
