Page 1 of 6 123 ... LastLast
Results 1 to 15 of 85
    December 2010
    Solved TS3 lowers volume of other application
    Hi everybody,
    since the last major update of the ts3 client, i have the problem
    that when i am in teamspeak while i am playing Cs:Source an i use
    my ingame voice, the complete teamspeak lowers his volume.
    I've tested if this does relate to the hotkey that i use ingame tu use voice,
    but if a change the ingame hotkey the same problem appears.
    The only solution to rebuild the normal volume is to close teamspeak and
    open it again.
    I hope s.o. can help me with this.
    Regards
    Vannelle
    18,027
    Please check the settings for the volume plugin (if installed).
    Tools > Plugins > volume plugin
    //Edit #1
    Check that "Do Nothing" is selected under your Windows Control Panel -> Sound -> Communications -> Check "Do Nothing" .
    This is a Windows setting!
    The plugin was removed and only can be installed manually.
    //Edit #2
    Check your installed sound card driver or install the latest version if you haven't done yet.
    Then go into your sound card manager/driver and check for feature which could lower sounds.
    Realtek as an example offers such feature (next to Windows Control Panel -> Sound -> Communications -> Check "Do Nothing") and ignores the value sometimes.
    When voice is coming in, other sound is quieted
    I am using two channels audio channels, one in my headset which is set to get sound from people's voices in Team Speak 3, and another channel which is plugged into my speaker system which usually plays music.
    When people are not talking/have not been talking for about 3 seconds the speaker system is at normal volume.
    But then when people say something, it is silenced a lot, so I can barely hear it. Turning up the volume will make it blast too loud, and it is currently not usable this way...
    What could I change to fix this?
    The speakers are hooked up to a small head unit, with an aux splitter, so the computer reads it as headphones if that helps...but the headset is a USB headset.
    Please help!!!
    May 2010
    6,310
    The Volume Control plugin is enabled?
    (Settings > Plugins)
    Game going quiet.
    When i first installed my TS it gave me the option to 'mute other sounds when ts is active' so i stupidly clicked yes. now i want to change it but i can't find the option! Any ideas?
    United Kingdom
    Teamspeak Sound
    I Was Woundering If Any Of You Guys Could Help Me With My Teamspeak..
    Ive Been Having This Problem With Teamspeak, Where If I Talk In Teamspeak All My Sound Auto Turns Its Self Down, And I Dont Know How To Stop It, Does Anyone Know How I Turn It Off?
    Thanks
    L36Medic
    May 2010
    6,310
    Check if the Volume Control plugin is activated
    Settings > Plugin
    September 2010
    PA
    14
    Teamspeak keeps lowering it's volume in mixer
    I keep having troubles hearing people in TS, I recently noticed that the volume was down in my mixer. I put it back up and I could hear everyone fine. Later that day I couldn't hear anyone again and I noticed that once again TS was down in the volume mixer. This is reoccurring it keeps going back down and I'm not sure why? Is there an option for automatic volume control that I can turn off or something?
    August 2011
    TS3 taking priority over other sounds.
    When I am playing Battlefield Bad Company 2 and someone starts talking, my sound in game drops significantly. A few seconds after they stop talking, my in game sound resumes to normal levels.
    OS:Win7 64-bit
    Sound card: Realtek HD on board sound
    I had the same problem with my last PC and the fixes were:
    Windows
    1. Sound options > Recording > Double click on the enable microphone > Advanced Settings > Un-tick "Allow applications to take exclusive control of this device".
    2. Sound options > Communications > When windows detects communications activity: Do Nothing.
    TS3
    Settings > Plugins > Un-tick Volume Control.
    I also downloaded the following driver http://www.realtek.com/downloads/dow...&GetDown=false (the first on the list) before applying the above changes.
    These fixes are not working on my new PC... anyone know a way round this problem?
    August 2011
    ingame Volume drops as soon as some1 talks
    Hey basically i did NOT enable volume control, and yes i did rightclick the speaker in the taskbar, sounds and did everything needed to let it STOP.
    But it still decreaess as soon as some1 talks.
    My sound driver is up to date and ive already restarted my pc.
    Any idea?
    18,027
    Quote Originally Posted by deviNe View Post
    Hey basically i did NOT enable volume control...
    Yes there is an option under windows to lower sound.
    Right click on the volume icon in your tray> select playback devices > click on communications tab, check do nothing, and click OK.
    August 2011
    FIX! Problem with sound in games lowering using TS3
    After hours of trying everything to fix the keystroke that lowered the volume of any game and not lowering TS I found the fix for me, real simple in fact. Before getting to that let me also address that while using TS, when others would press a key to talk it lowered my game volume,windows application volume as well. This was seen by bringing up the volume mixer and watching what happened and when.
    The fix is this, run the Team Speak wizard found under settings/setup wizard-proceed to run it until you get to the 6th page -Plugins, UNCHECK "enable volume control. That's it! What this does I believe, leaves it up to you to adjust volumes in every application you use. Now I have full volume in all games when using Team Speak 3. I hope this helps.
    August 2011
    Problem with sound
    when i join ts3 server and game server...when i use my mic...my sound in game isnt as aloud as it should be. Its only when i or someone on ts3 is useing mic. When noone is talking sound volume is going to correct level.
    August 2009
    53
    Sounds like the "Volume Control Plugin".
    Just deactivate it or configure to winamp-only solution.
    August 2011
    yep u were right, now works perfect, thanks
  1. [Resolved] TS Lowers volume of other clients when I talk.
    By Grandsatsuma in forum Client Support
    Last Post: October 20th, 2018, 08:21 PM
  2. Whenever someone talks the volume of my music lowers
    By Ferahn in forum General Questions
    Last Post: March 11th, 2014, 03:51 PM
  3. Teamspeak lowers the music volume of foobar
    By chapter14 in forum General Questions
    Last Post: March 18th, 2013, 09:07 AM
  4. Volume lowers longer they talk.
    By Seal_Clubr in forum Bug Reports [EN/DE]
    Last Post: April 24th, 2010, 07:58 PM
  5. [Solved] My talking lowers others volume
    By royalflushxx in forum Windows
    Last Post: February 8th, 2010, 11:09 PM
