Page 1 of 15 12311 ... LastLast
Results 1 to 15 of 225
    February 2010
    Netherlands
    107
    Logitech G-Key Plugin
    TeamSpeak 3 G-Key Plugin
    This plugin provides support for Logitech devices with G-Keys for hotkeys. This allows you to use these macro keys directly without rebinding them to standard keyboard keys.
    Download and install the latest version from myteamspeak.com.
    Once installed G-Keys can be configured like any other hotkey, however by default these hotkeys can only be used when TeamSpeak 3 is in focus. To use these hotkeys with any application active you need to make TeamSpeak 3 the persistent profile in the Logitech Gaming Software.
    More information on the addon page. Source code is available on GitHub.
    2,351
    Plugin works great on Windows 7 / TS3 rc2-pre 64 bit, thank you.
    February 2010
    Netherlands
    107
    I just got into contact with someone who has a G35 headset, I expected it to use the same drivers with script functionality as the keyboards but this is not the case. I'm trying to come up with a solution, but this will require a completely different approach. This will be hard for me to even begin with, since I do not own an G35 headset. There is a dev kit for the G930 though, so it'll be easier to add support for it, but again I don't have access to the hardware to test it. Would anyone like to see support for the G-keys on Logitech headsets?
    UPDATE: Version 0.3 has been released, it fixes a crash while you use Push-to-talk when you haven't connected to any server yet.
    March 2011
    Quote Originally Posted by Armada651 View Post
    YES, Please!!!
    February 2010
    Netherlands
    107
    Quote Originally Posted by christophroeti View Post
    YES, Please!!!
    I can add support for it if you can help me test it, I've sent you a PM.
    11
    is it possible to get this working with G110 "http://www.logitech.com/en-us/gaming/mice-keyboard-combos/devices/5902" or maybe it already works but somehow TS3 dose not support it anymore i have no clue but i cant get it working can someone update the plugin or make another because i would love to have it im running out of buttons to set PTT on
    February 2010
    Netherlands
    107
    Quote Originally Posted by Inescapable View Post
    Are you running Windows XP by any chance?
    11
    im running win7
    February 2010
    Netherlands
    107
    im running win7
    Could you try this version? It fixes an error some users are having on Windows XP.
    11
    same thing been through all the steps in readme but TS dose not register a button
    February 2010
    Netherlands
    107
    This could have several causes:
    • Are you trying to set it as the PTT hotkey in the options? This not necessary, as the plugin will activate PTT itself ignoring any TS3 settings. (You can just clear the PTT hotkey be pressing ESC when assigning a hotkey)
    • Have you edited gkey == 1 and mkey == 2 to match your control scheme? (If you want to use G5 when M1 is active you change it to gkey == 5 and mkey == 1)
    • Are you sure the script is executed correctly? Try temporarily adding a log message and with the script editor open see if the message is logged when you press the key. Like this:
      function OnEvent(event, arg)
          gkey = arg
          mkey = GetMKeyState()
          if event == "G_PRESSED" and gkey == 5 and mkey == 1 then
              OutputDebugMessage("TS3_PTT_ACTIVATE")
              OutputLogMessage("PTT Activated\n")
          end
          if event == "G_RELEASED" and gkey == 5 and mkey == 1 then
              OutputDebugMessage("TS3_PTT_DEACTIVATE")
              OutputLogMessage("PTT Deactivated\n")
          end
      end
      Don't forget to save the script before testing. (Ctrl+S)
    11
          gkey = arg
          end
          end
      end
    in the script editor i get this
    attempt to call a nil value
    and in TS ive tried not using any PTT button and with but nothing works for some reason
    February 2010
    Netherlands
    107
    Could you show me your script?
    11
    the one i just put in
    gkey = arg
    if event == "G_PRESSED" and gkey == 7 and mkey == 1 then
    end
    if event == "G_RELEASED" and gkey == 7 and mkey == 1 then
    end
    end
    and the one i use before
    gkey = arg
    end
    end
    end
    February 2010
    Netherlands
    107
    The script is fine, but that error is definitely not normal. Do you get that error every time you press a key? What version of the drivers are you using? The current one or the legacy one?
  1. Missing a nice Plugin for Logitech G19
    By CreiX in forum Client Support
    Last Post: February 18th, 2013, 05:57 PM
  2. [Resolved] [Logitech G15] LCD Panel plugin
    By Y2Killer in forum Client Plugins / Lua Scripts
    Last Post: May 12th, 2012, 07:41 PM
  3. [Rejected] Logitech G19 Plugin.
    By mike82y in forum Suggestions and Feedback
    Last Post: November 24th, 2011, 08:24 AM
