Results 1 to 3 of 3
    May 2011
    Question problem with volume...
    Hi all, I have a problem with TeamSpeak 3, what happens is that being in the program, speaking of the PC volume is lowered automatically to highlight the volume of TeamSpeak, and to be playing or listening to music is to be first time it happens and not how to fix it, perhaps by the new update or may have moved to something.
    Hopefully I can help. Thanks
    PS: if you do not understand is because of google translator.
    __________________________________________________ _______________
    Hola a todos, tengo un problema con el TeamSpeak 3, lo que pasa es que al estar dentro del programa, al hablar el volumen de la PC se baja automaticamente para resaltar el volumen del TeamSpeak, como al estar jugando o estar escuchando musica es la primera vez que me pasa y no se como arreglarlo, tal vez sea por la nueva actualización o que le haya movido a algo.
    Ojala que me puedan ayudar. Gracias
    PD: si no le entienden es por culpa del traductor de google.
    Catalunya
    2,350
    Well, this forum is english only.
    Respect your problem, check if you turned on : Volume_Control, in Settings > Plugins > ...
    May 2011
    Thank you so much man, no one could resolve my doubts until I wrote here: D
    Thanks! Greetings.
  1. Volume problem
    By H20Ts in forum Windows
    Last Post: September 4th, 2014, 02:20 AM
  2. Replies: 1
    Last Post: October 22nd, 2011, 08:27 PM
  3. Replies: 1
