Results 46 to 59 of 59
  1. #46
    January 2012
    6
    Server logs being spammed with "TSANetwork::Send failed error: 1"
    My server logs are being spammed with the following error:
    TS3ANetwork::Send failed error: 1
    I have checked already the thread http://forum.teamspeak.com/showthrea...ailed-error-22
    Port 2010 is opened in UDP mode for the weblist
    Port 2008 is opened in TCP mode for the license check
    I can also ping accounting.teamspeak.com without problems:
    64 bytes from accounting.teamspeak.com (62.146.63.84): icmp_seq=3 ttl=58 time=3.07 ms
    All features of the TS3 server are working without problems and the server is also appearing correctly in the weblist as "Crogges Teamspeak Server" (Germany).
    *** Thread Merged ***
  2. #47
    May 2010
    6,310
    It's all the time or all these messages appear at some time ?
    Do you get another error message in the server log ?
    Also, and to avoid any dns problem, you could add the accounting resolution in your hosts file
    62.146.63.84       accounting.teamspeak.com
  3. #48
    January 2012
    6
    Quote Originally Posted by florian_fr40 View Post
    Well the error is being displayed most of the time, the server is correctly displayed in the weblist also while the error is appearing. I get no other messages in the logs and the server itself is working just fine.
    I added accounting.teamspeak.com to the hosts file but I couldn't find any DNS errors in the server logs, so I guess that the problem is caused by something else.
  4. #49
    May 2010
    6,310
    The address is added on the hosts file, so keep a look on this.
  5. #50
    January 2012
    Same problem
    I don't know why this post is marked "solved" because it's not wright. I have the same problem with my Teamspeak Server :
    - In the Teamspeak server log, i have this error message :
    2012-01-16 13:45:00.076712|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2012-01-16 13:45:00.076901|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2012-01-16 13:45:02.075884|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2012-01-16 13:45:02.076060|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2012-01-16 13:45:04.075881|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2012-01-16 13:45:04.076007|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    - In my iptables firewall, i had created this rules entry :
    Chain INPUT (policy DROP)
    target     prot opt source               destination
    ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:2008
    ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:search
    ACCEPT     udp  --  anywhere             anywhere            udp dpt:2008
    ACCEPT     udp  --  anywhere             anywhere            udp dpt:2010
    Chain OUTPUT (policy DROP)
    ACCEPT     tcp  --  anywhere             accounting.teamspeak.com tcp dpt:2008
    ACCEPT     udp  --  anywhere             accounting.teamspeak.com udp dpt:2008
    ACCEPT     tcp  --  anywhere             accounting.teamspeak.com tcp dpt:search
    ACCEPT     udp  --  anywhere             accounting.teamspeak.com udp dpt:2010
    I had reboot my server but the problem is not solved. Could you help me ?
    PS : excuse me for my english but i am french and not very good with english spoken.
  6. #51
    May 2010
    6,310
    Don't forget to allow the DNS traffic
    (or write the accounting resolution in the hosts file)
  7. #52
    January 2012
    The DNS traffic is ok and the dns redirection for accounting.teamspeak.com is ok but i allready have the error.
  8. #53
    May 2010
    6,310
    Ok make point:
    To be sure it's not a Iptable problem:
    If you switch to ACCEPT your input and ouput rule (from iptables) do you get the same result (I don't think so) ?
    Also, the 2008 port is TCP and 2010 is UDP
    Quote Originally Posted by AlembraCODE
    ACCEPT udp -- anywhere accounting.teamspeak.com udp dpt:2010[/CODE]
    This rule is wrong. The server for this is weblist.teamspeak.com
    You could set theses output rule for "everywhere".
  9. #54
    June 2002
    Netherlands
    1,049
    Alembra, some info:
    1. Florian is right, your input line for udp port 2010 should be weblist.teamspeak.com
    2. on linux, error 1 means "operation not permitted" which seems to indicate the OS (linux) is actively stopping the network traffic.
    If you still have problems, I have some questions for you:
    1. Do you have a licensekey or not?
    2. What exactly is your problem besides the error in the log. Does your server shutdown after those errors or does it keep running?
  10. #55
    January 2012
    i have made some tests :
    - for the ping, the test is OK (62.146.63.84).
    - enable all trafic on iptables : no error in the log.
    Could you explain exactly what ports number and protocoles i must open for not have the error 1 ?
  11. #56
    May 2010
    6,310
    @nwerensteijn
    From my last test on linux with the 2010 blocked on iptable :
    - 6 error lines in the log (at each server request) - normal
    - The server still running
    - About the machine %CPU 1.3 - %MEM 3.1 - during the requests
    @Alembra
    The iptables rules from the test machine :
    ACCEPT     all  --  anywhere             anywhere            state ESTABLISHED <= don't care about it
    ACCEPT     udp  --  anywhere             anywhere            udp dpt:domain <= DNS
    ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:2008 <= license
    ACCEPT     udp  --  anywhere             anywhere            udp dpt:6000 <= the virtual server
    Chain FORWARD (policy ACCEPT)
    ACCEPT     udp  --  anywhere             anywhere            udp dpt:2010 <= weblist
  12. #57
    January 2012
    Quote Originally Posted by nwerensteijn View Post
    Alembra, some info:
    1 - Yes i have a license key
    2 - After 6 days, the server crash (the service is still running but it's not possible to connect on it). For solve this, i must restart the server.
    --- Merged ---
    Ok i just test this on iptables and it's ok !
    For resume, the solution is (iptables configuration) :
    - OUTPUT rules => open port 2008 tcp, destination : accounting.teamspeak.com and open port 2010 udp destination : weblist.teamspeak.com
    - INPUT rules => open port 2008 tcp and open port 2010 udp.
    If i understand good, this solution works ONLY if it is on a server WITH a license key.
    Thanks you Florian and nwerensteijn for your help ;-)
  13. #58
    May 2010
    6,310
    Glad it works for you.
    You understand why now
  14. #59
    April 2014
    Server setup help ( JustHost)
    Let me say first i have searched many many threads on here and have not found a resolution to my problem. I have my server up and running, ports are open and everything.
    i used the command
     ./ts3server_startscript.sh inifile=ts3server.ini
    to start it and when i check the status it says running. Although i cannot connect to the server at all...can someone help me please, i have dedicated ip and everything
    I have checked all the ports
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address               Foreign Address             State       PID/Program name
    tcp        0      0 69.195.112.72:10005         0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:21                  0.0.0.0:*                   LISTEN      -
    tcp        0      0 69.195.112.72:10006         0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:22                  0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:5432                0.0.0.0:*                   LISTEN      -
    tcp        0      0 69.195.112.72:10009         0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:25                  0.0.0.0:*                   LISTEN      -
    tcp        0      0 69.195.112.72:10010         0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:26                  0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:10011               0.0.0.0:*                   LISTEN      4475/./ts3server_li
    tcp        0      0 0.0.0.0:2077                0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:2078                0.0.0.0:*                   LISTEN      -
    tcp        0      0 69.195.112.72:16000         0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:993                 0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:2082                0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:995                 0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:2083                0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:2086                0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:2087                0.0.0.0:*                   LISTEN      -
    tcp        0      0 173.254.28.52:17864         0.0.0.0:*                   LISTEN      -
    tcp        0      0 127.0.0.1:45642             0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:3306                0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:587                 0.0.0.0:*                   LISTEN      -
    tcp        0      0 50.87.69.202:53772          0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:110                 0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:143                 0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:2095                0.0.0.0:*                   LISTEN      -
    tcp        0      0 127.0.0.1:783               0.0.0.0:*                   LISTEN      -
    tcp        0      0 69.195.112.72:10000         0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:2096                0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:30033               0.0.0.0:*                   LISTEN      4475/./ts3server_li
    tcp        0      0 69.195.112.72:10001         0.0.0.0:*                   LISTEN      -
    tcp        0      0 0.0.0.0:465                 0.0.0.0:*                   LISTEN      -
    tcp        0      0 50.87.69.202:45234          0.0.0.0:*                   LISTEN      -
    tcp        0      0 :::21                       :::*                        LISTEN      -
    tcp        0      0 :::22                       :::*                        LISTEN      -
    tcp        0      0 :::5432                     :::*                        LISTEN      -
    tcp        0      0 :::25                       :::*                        LISTEN      -
    tcp        0      0 :::26                       :::*                        LISTEN      -
    tcp        0      0 :::443                      :::*                        LISTEN      -
    tcp        0      0 :::587                      :::*                        LISTEN      -
    tcp        0      0 :::110                      :::*                        LISTEN      -
    tcp        0      0 :::143                      :::*                        LISTEN      -
    tcp        0      0 :::80                       :::*                        LISTEN      -
    tcp        0      0 :::465                      :::*                        LISTEN      -
    udp        0      0 0.0.0.0:58918               0.0.0.0:*                               -
    udp        0      0 0.0.0.0:9987                0.0.0.0:*                               4475/./ts3server_li
    udp        0      0 172.16.132.52:123           0.0.0.0:*                               -
    udp        0      0 173.254.28.52:123           0.0.0.0:*                               -
    udp        0      0 127.0.0.1:123               0.0.0.0:*                               -
    udp        0      0 0.0.0.0:123                 0.0.0.0:*                               -
    udp        0      0 0.0.0.0:32954               0.0.0.0:*                               -
    udp        0      0 0.0.0.0:56697               0.0.0.0:*                               -
    udp        0      0 :::123                      :::*                                    -
    everything shows that it is listening to the right ports i dunno im getting lost here....i have done everything to the best of my knowledge. Please help would be greatly appreciated
    2014-04-20 20:55:46.299449|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-04-20 20:55:46.308831|INFO    |ServerLibPriv |   | SystemInformation: Linux 3.4.87-20140414.1.bh6.x86_64 #1 SMP Mon Apr 14 15:59:08 EDT 2014 x86_64 Binary: 64bit
    2014-04-20 20:55:46.308888|INFO    |ServerLibPriv |   | Using hardware aes
    2014-04-20 20:55:46.317838|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-04-20 20:55:46.318017|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2014-04-20 20:55:46.318513|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-04-20 20:55:46.353284|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2014-04-20 20:55:47.495193|INFO    |              |   | Puzzle precompute time: 1125
    2014-04-20 20:55:47.495612|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2014-04-20 20:55:47.534132|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2014-04-20 20:55:47.535576|INFO    |Query         |   | listening on 0.0.0.0:10011
    2014-04-20 21:00:47.647886|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:00:47.673169|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:00:49.075324|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:00:49.075462|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:00:51.078731|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:00:51.078830|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:10:47.658687|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:10:47.658781|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:10:49.060899|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:10:49.060991|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:10:51.064150|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:10:51.064249|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:20:47.688327|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:20:47.688418|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:20:49.090678|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:20:49.090765|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:20:51.093742|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    2014-04-20 21:20:51.093841|ERROR   |              |   | TS3ANetwork::Send failed error: 1
    there is my log file....i really need some help let me be more clear i do have multiple domains in my account and i have the teamspeak3 server in a specific domain folder does it need to be moved from that folder?
  1. TS3ANetwork::Send failed error: 1
    By brodach in forum Linux / FreeBSD
    Last Post: October 2nd, 2015, 12:10 AM
  2. TS3ANetwork::Send failed error: 1
    By Gallitin in forum Server Support
    Last Post: January 31st, 2014, 07:56 PM
  3. TS3ANetwork::Send failed error: 1
    By Barut in forum Linux / FreeBSD
    Last Post: October 3rd, 2012, 04:01 PM
  4. TS3ANetwork::Send failed error: 113
    By burnacid in forum Linux / FreeBSD
    Last Post: November 8th, 2010, 02:39 PM
  5. TS3ANetwork::Send failed error: 1
    By Teddy in forum Linux / FreeBSD
    Last Post: November 4th, 2010, 08:49 AM
