Results 1 to 7 of 7
    March 2010
    127.0.0.1
    Solved Guest have kick power
    For some reason my guests have the rights to kick people of the server. There is no one in the default guest group and i removed all possible rights from that group. What am I doing wrong here. This used to work perfectly. Did an update screw things up or did I
    March 2010
    127.0.0.1
    Yeh I read that one and they lost me after "Hi all, ..." Am at the point of delete ts3 and reinstall ventrillo. This server worked fine for years, but aftre some updates its &^@&*^@. Guest can kick/ban, my use token option is gone, I cant edit the server settings....etc etc
    When i search for kick in the guest rights, its grayed out. i select add permission, but then it just disappears.
    March 2010
    127.0.0.1
    Did a total reinstall on my debian server, dropped the lic file back in, recreated the channels...... now its looks liek a normal TS3 server again.
    December 2007
    Austria,Linz
    214
    All user can kick
    Hi there,
    I'm using the TS Server since first beta, after the update from the latest and last beta to the first rc I got a problem with the server.
    All users can kick others. Because I cannot setup the permissions witht he new ts version, I downlaoded the beta36 client version to modify the permissions. I cannot set the Client Kick Power and Need Kick Power it is deactivaed. If I try to activate and want set the Need Kick Power to 25 I got this message:
    insufficient permission modify power
    I'm not able to add new groups with the new version of TeamSpeak (rc).
    February 2006
    Texas, USA
    4,143
    The reason this kick problem arose is because you did not set your auto update permission correctly so when the kick permissions got changed with an update your permissions did not. They got disabled so now no one has a needed_kick_power associated with them and everyone has the power to kick everyone else.
    February 2006
    Texas, USA
    4,143
    September 2009
    somwhere
    92
    refer to this thread in order to fix your "insufficient permission modify power" issue
    http://forum.teamspeak.com/showthrea...400#post286400
    good luck and swear at the comp all you like its ok
  1. Guest can kick Guest
    By setman590 in forum Permission System
    Last Post: March 24th, 2013, 02:21 PM
  2. Guest can kick with -1 power?
    By Jane88 in forum Bug Reports [EN/DE]
    Last Post: February 2nd, 2011, 10:46 PM
  3. Guest can kick with -1 power?
    By Jane88 in forum Permission System
  4. Guest can kick and ban other Guest?
    By Shadowreaver in forum General Questions
    Last Post: January 23rd, 2011, 03:59 AM
  5. Guest can kick
    By Slicky456 in forum Permission System
    Last Post: July 12th, 2010, 04:27 PM
