Results 1 to 2 of 2
    July 2002
    2,191
    TeamSpeak 3 Package Installer
    Hello everybody,
    with the introduction of the TeamSpeak-3.0.0-rc2 Client, we now support so called "package files" which are basically archives containing all the files of a sound-pack, a skin, a plugin or a translation etc.. The package installer that automatically comes up when you try and "run" such a package file takes care of extraction and copying the files to the right places in the client.
    Since it greatly eases the installation of any add-ons, we recommend all authors to repackage their work into such a package file.
    Below some information on how this works:
    The TeamSpeak Package Installer allows users to install plugins, soundpacks,
    skins etc. by opening a package file in Windows explorer.
    Requires TeamSpeak 3 Client rc-2 or later.
    Package files are ZIP archives with another file suffix. Only zlib compression
    is supported. Do not use Umlauts in your filenames inside the ZIP archive, they
    are not supported.
    Package files are identified by their file suffix:
    .ts3_plugin
    .ts3_style
    .ts3_soundpack
    .ts3_iconpack
    .ts3_translation
    .ts3_addon
    The suffix is a hint for the user about the package content. The install
    structure is not defined by the suffix but by the content of the package.
    Packages which contain multiple types (like stylesheet and an iconpack)
    could use the suffix of the primary content (e.g. .ts3_style) or the
    more generic .ts3_addon.
    The root directory of the archive is required to contain a special package
    information file named "package.ini".
    [Example package.ini]
    Name = Test Plugin
    Type = Plugin
    Author = TeamSpeak Systems GmbH
    Version = 1.0
    Platforms = win32, win64, mac
    Description = "This is a test plugin."
    The Type field should match the file suffix or, in the case of a multiple
    content package, be a combination (e.g. "Style, Iconpack").
    The Platforms field can be empty (allowed for all platforms) or a list of
    supported platforms of this add-on.
    Valid platform names are: win32, win64, linux_x86, linux_amd64, mac
    The package installer will validate the current platform it is running on
    against the list of supported platforms in the package.ini file. If the
    current platform is included in the list, installing will be allowed.
    If the platform list is empty or the field is not given, installing will
    be allowed.
    The hierarchy of a package archive is required to reflect the structure of
    the installed files relative to the TeamSpeak 3 installation directory.
    [my_plugin.ts3_plugin]
    package.ini
    plugins
      my_plugin_win32.dll
      my_plugin_win64.dll
      my_plugin_data
        data1.dat
        data2.dat
    The root level of this package will be extracted into the TeamSpeak 3 Client
    root folder, excluding package.ini.
    Note that content needs to be at the root level of the package and *not*
    within a subfolder. The following would be *wrong*:
    [my_invalid_plugin.ts3_plugin]
    my_plugin
      package.ini
      plugins
        my_plugin_win32.dll
        my_plugin_win64.dll
        my_plugin_data
          data1.dat
          data2.dat
    A soundpack might be look like this:
    [my_soundpack.ts3_soundpack]
    package.ini
    sounds
      my_soundpack (directory)
        sounds.ini
        sound_1.wav
        sound_2.wav
    Example for a combine iconpack and style package:
    [my_soundpack.ts3_style]
    package.ini
    styles
      my_style.qss
      my_style
    gfx
      my_gfx_pack
      emoticons
    18,513
    You can leave Feedback or Problems here
  1. Teamspeak Package Installer doesn't appear for me.
    By LeonSKennedyBL in forum Windows
    Last Post: March 22nd, 2015, 08:29 PM
  2. Problem with Teamspeak 3 Package Installer
    By akolthas in forum Windows
    Last Post: August 12th, 2014, 08:13 AM
  3. TeamSpeak 3 Package Installer
    By Peter in forum Skins / Icon & Sound Packs
    Last Post: December 13th, 2011, 11:19 AM
  4. TeamSpeak 3 Package Installer
    By Peter in forum Client Plugins / Lua Scripts
