Hello everybody,
with the introduction of the TeamSpeak-3.0.0-rc2 Client, we now support so called "package files" which are basically archives containing all the files of a sound-pack, a skin, a plugin or a translation etc.. The package installer that automatically comes up when you try and "run" such a package file takes care of extraction and copying the files to the right places in the client.
Since it greatly eases the installation of any add-ons, we recommend all authors to repackage their work into such a package file.
Below some information on how this works:
TeamSpeak 3 Package Installer
The TeamSpeak Package Installer allows users to install plugins, soundpacks,
skins etc. by opening a package file in Windows explorer.
Requires TeamSpeak 3 Client rc-2 or later.
Package files are ZIP archives with another file suffix. Only zlib compression
is supported. Do not use Umlauts in your filenames inside the ZIP archive, they
are not supported.
Package files are identified by their file suffix:
.ts3_plugin
.ts3_style
.ts3_soundpack
.ts3_iconpack
.ts3_translation
.ts3_addon
The suffix is a hint for the user about the package content. The install
structure is not defined by the suffix but by the content of the package.
Packages which contain multiple types (like stylesheet and an iconpack)
could use the suffix of the primary content (e.g. .ts3_style) or the
more generic .ts3_addon.
The root directory of the archive is required to contain a special package
information file named "package.ini".
[Example package.ini]
Name = Test Plugin
Type = Plugin
Author = TeamSpeak Systems GmbH
Version = 1.0
Platforms = win32, win64, mac
Description = "This is a test plugin."
The Type field should match the file suffix or, in the case of a multiple
content package, be a combination (e.g. "Style, Iconpack").
The Platforms field can be empty (allowed for all platforms) or a list of
supported platforms of this add-on.
Valid platform names are: win32, win64, linux_x86, linux_amd64, mac
The package installer will validate the current platform it is running on
against the list of supported platforms in the package.ini file. If the
current platform is included in the list, installing will be allowed.
If the platform list is empty or the field is not given, installing will
be allowed.
The hierarchy of a package archive is required to reflect the structure of
the installed files relative to the TeamSpeak 3 installation directory.
[my_plugin.ts3_plugin]
package.ini
plugins
my_plugin_win32.dll
my_plugin_win64.dll
my_plugin_data
data1.dat
data2.dat
The root level of this package will be extracted into the TeamSpeak 3 Client
root folder, excluding package.ini.
Note that content needs to be at the root level of the package and *not*
within a subfolder. The following would be *wrong*:
[my_invalid_plugin.ts3_plugin]
my_plugin
package.ini
plugins
my_plugin_win32.dll
my_plugin_win64.dll
my_plugin_data
data1.dat
data2.dat
A soundpack might look like this:
[my_soundpack.ts3_soundpack]
package.ini
sound
my_soundpack (directory)
settings.ini
sound_1.wav
sound_2.wav
Example for a combine iconpack and style package:
[my_soundpack.ts3_style]
package.ini
styles
my_style.qss
my_style
gfx
my_gfx_pack
emoticons
