Results 16 to 30 of 32
  1. #16
    i got the same issue after the latest update. before everything worked fine. i tried to unplug everything (except my mouse of course). didnt help. reinstalled ts3 severeal times. didnt try the old rc1 client yet, but i assume it works with that. i also got am microsoft sidewinder x6 keyboard with the latest drivers (there was a small update a few days ago, but it didnt help)
    i get this error message everytime i start ts3:
    http://images.pctflux.net/2011061604...enablage03.png
    any help would be appreciated
    €: rc1 works. but that wierd woman noise is scary :P
  2. #17
    18,151
    A test client will be build for you guys. I will update this post, when it is available.
    Update as said before: http://ftp.4players.de/pub/hosted/ts...leases/client/
    Plugins and addons won't work with this version - This client is only for testing with hotkeys.
    Please test our pre Rc3 client. Ignore, when it asks you for an update, or else it will downgrade to rc2 again
  3. #18
    i still get this error message (now in english), but now everything works fine again! thanks for the fast suport!
  4. #19
    7
    Here's two error messages I get using RC3.
    I've attached 2 images of the two errors/log I get.
ID:	5074   Click image for larger version.
  5. #20
    18,151
    What operation system do you use? Is it 32 or 64bit?
    What client version did you install for testing (32 or 64 Bit)?
    Is your driver for your mouse and keyboard 64 bit compatible?
    Is UAC enabled under windows 7/vista or do you start the client as admin?
  6. #21
    Windows 7 Ultimate 64bit
    on the rc2, i tried both, on the rc3 only 32bit
    my keyboard driver is, my mouse doesnt have any dedicated drivers (i guess it uses microsoft standart drivers and i have no idea if they are 64bit compatbile)
    UAC is disabled, i start as admin
    i got that first error message, hassan shows (test.jpg). i clicked yes twice, then it never showed up again and everything is working now. pretty wierd.
  7. #22
    August 2009
    53
    I hope you don't mean the client. It is not necessary for most of all the people!
    That is something we can work with. Two times "yes" means you gave the enumeration routine 10 more seconds to operate - strange. Now I'm really curious about which device or driver takes so long.
    What does dxdiag say and does it take ages too?
    Maybe you can post which " Info Input device name: ..." in the log is coming next after clicked 2 times "yes".
  8. #23
    7
    Operating System -> Windows 7 Ultimate 64-bit
    Client Version -> Teamspeak RC3 64-bit
    Driver for Mouse/Keyboard - As far as I know my mouse I have the 64-bit Setpoint and the Microsoft Sidewinder I have the latest 64-bit software (so I'm assuming both are 64-bit compatible)
    UAC is not enabled (because of the stupid annoying pop ups), I am running it as an admin either way.
    But like I said RC3 is working perfectly, I pressed No when the first error in the screenshot popped up. And it seems to be working great, I'm not going to mess with it.
  9. #24
    Well i use Vista home premium 32bit
    and i also tried to unplug all usb devices. And as my mouse was unplugged, it worked again. But i can't keep my freakin mouse unplugged. TS also told me to refresh my drivers, but it is the newest, so i cant install another.
  10. #25
    Quote Originally Posted by RicoH View Post
    how do i open the teamspeak log?
    i ran dxdiag and it didnt take long at all (2-3 seconds)
    Attached Files Attached Files
  11. #26
    Still problem with Hotkeys or push-to-talk working.
    Hey guys, since i havent found any solution in one of the other posts i try it on my own.
    I still (since the last client patch (3.0.0-rc2 [Build: 14642]) have the problem, that if my mouse is plugged in none of my hotkeys work.
    If i unplug the mouse, open TS, and replug the mouse again, i can use the hotkeys for this time. But it seems senseless to do this everytime.If i restart TS3 then, with the mouse replugged, the problem happens again. Someone got a similar problem, or a solution for thi one?
    Greetings
  12. #27
    Essen - NRW - Germany
    26
    simillar problem here, PTT doesnt work untill i replugg some of my usb connectors (don't realy know wich, seems to be different all the time)
  13. #28
    July 2011
    I'm having the same problem like Poster Advanium (#1). No problems with previous version.
    After updating to RC 2 I got that registry update thing he describes in #4. Now whenever I start Teamspeak I get: "Die Abfrage der Direct Input Geräte ist fehlgeschlagen. Das Teamspeak Hotkey System wurde deaktiviert. Sie können die Ursache des Problems finden ..." etc - it's your code, you will know the message in english I hope. #16 has the screenshot.
    Pressing num lock several times did not help. ... Hm ... just tried again, now it DID help.
    Win XP 32, Razer mouse and standard keyboard. No other USB devices, nothing special. Keyboard driver is windows standard so no way to update anything. Maybe theres a new driver for the razer but why should I? I doubt it helps anyway. If I unplug either mouse OR keyboard OR both bevor starting TS everything works. I can replug them afterwords and everything is fine.
    This is annoying, I'm reverting to RC 1. Or should I use that version you linked in #17?
    Never update a running system unless you are really forced to do so ... :-(
    Edit: Pressing NumLock doesn't help anymore ... RC1 works ok
  14. #29
    7
    An update would be appreciated from you TS3 guys whenever you do get around to it.
  15. #30
    August 2009
    53
    If you still get any hotkey issues, test one of our latest pre- preleases and don't forget to report back.
    Click here.
  1. CRASH: TS3 3.0.0-rc2 build 14642
    By hlbales in forum Off Topic
    Last Post: March 10th, 2012, 11:22 AM
  2. CRASH: TS3 3.0.0-rc2 build 14642
    By hlbales in forum Bug Reports [EN/DE]
  3. Still problem with Hotkeys or push-to-talk working.
    By shentoza in forum Client Support
    Last Post: July 2nd, 2011, 06:23 PM
  4. [Resolved] PTT on TS3 Build 14642
    By Walle34 in forum Permission System
    Last Post: June 27th, 2011, 09:57 AM
  5. Bug in TS3 v3.0.0-rc2 [Build: 14642]
    By Advanium in forum Client Support
    Last Post: June 15th, 2011, 03:35 PM
