Results 1 to 9 of 9
    Unhappy Disconnects every 25 seconds exactly.
    So ever since I updated TS3 a few updates ago my client will start disconnecting from server (all servers I try it does this), then reconnect straight away to the same channel I was in.
    This happens every 25 seconds. This never occurs straight after I connect to server for the first time, it is always at least 250 seconds later that first disconnect happens and it will keep dcing and rcing to the server until I close my client and open again then I'm good for a little while
    If anyone else has had a problem with this and knows how to fix it please let me know because I'm on the brink of crying lol.
    Same here, many same post on forum, but no fix from developers.
    April 2009
    Australia
    75
    I just started getting this problem tonight... Any suggestions?
    6,080
    Firewall or security software is blocking the connection. See here
    April 2009
    Australia
    75
    Don't think so... Reboot fixed it.
    April 2009
    Australia
    75
    Started happening again. I closed the program a few times.
    I have had TeamSpeak installed with Windows 7 for about a year. Nil issues until the last week.
    No new software installed. Many other users are using the server, without having the same problem as me.
    Any ideas?
    Catalunya
    2,350
    As Chris told you, see this link: http://forum.teamspeak.com/showthread.php/68564
    April 2009
    Australia
    75
    As I said after his post, the link didn't help. See above, where I posted "Don't think so"
    Catalunya
    2,350
    Have you followed the instructions it gives you?
    You can connect to a server, but get disconnected after ~18 seconds/after minutes?
    We call this a timeout and this is a network problem there can be several reasons:
    - Your ping or packt loss to that server is to high.
    - Your firewall or security center does block the traffic to that server. Maybe your settings need to a change here?
    - Your router detects the traffic as spam or as an attack. Please check that there is nothing like this running.
    You could try to disable such settings for testing or set your LAN Ip to DMZ (Remove DMZ after testing!!!!)
    - Maybe your W-Lan conenction is not that good? Try a Lan cable instead for testing.
    - The servers ping or packet loss is for your connection is to high.
    - The server does have more then 1 IP and the hoster did nothing yet, to bind one of his IP's to his server.
    It can work without the IP binding and it can be random, that a user can connect or get's disconnected after 18 seconds.
    Sometimes a user can connect but is stucked in the lobby and the client does not reac to for any user interaction.
    Please try to connect to our test server first. Please try both links under this text for testing.
    Click to connect to the DNS address or Click to connect to the IP address
  1. Can't ban Users for more than 75 seconds
    By FelixOwnz in forum Permission System
    Last Post: July 29th, 2015, 08:50 AM
  2. Replies: 0
    Last Post: March 9th, 2015, 09:15 PM
  3. Everyone disconnects over a few seconds after startup
    By Tythus in forum Linux / FreeBSD
    Last Post: January 27th, 2014, 01:18 AM
  4. Server disconnects after a few seconds
    By HeWhoGames in forum Windows
    Last Post: September 6th, 2010, 09:19 AM
  5. Doing things every 1 seconds
    By rossmann in forum Client Plugins / Lua Scripts
    Last Post: January 16th, 2010, 02:31 PM
