Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 166 to 180 of 238
  1. #166
    January 2018
    Transfer "icon" reports: (lost file transfer connection)
    Hello guys nowdays i start having a problem with my teamspeak i will send u an image so u can understund what i mean..
    Also when i try to connect teamspeak start lagging
    https://imgur.com/a/qskku
  2. #167
    January 2018
    Server badge icons and server icon itself
    Hello there
    Recently I created my own TS3 server without any license. Just for private use for my couple of friends that I play games with.
    I am hosting it on my small laptop while I am playing games and I'm connected on TS through my main PC.
    The problem is.
    I created few server groups with icons +channels with icons
    I can easily and clearly see all icons (that have been downloaded from TS3 addons) even at "View Icons" option but
    my friends cannot see them. They just see blank papers on the places where Icons should be
    TS writes and error in the chat for them:
    The icon for channel "We play Roblox in here" (54) was not found.
    The icon for channel "We play Minecraft in here" (53) was not found.
    I have opened port 30033 on my router but that didnt help
    I changed b_icon_manage for every group in permissions but that didnt help as well
  3. #168
    September 2017
    49
    Android 3.1.8 on server 3.1 bug, bug no view icon
    I installed on the vps, the new server version of teampeak, the 3.1.0 beta, and I noticed that there is a bug, it doesn't show the icons, from the windows client, the icons are visible, but if within Android teampeak, the icons are not visible anymore.
    Solve as soon as possible please.
    Thank you
  4. #169
    18,409
    The reason is that 3.1.8 beta did had the file transfer bug where you crashed.
    This broke the icons that where downloading before you crashed.
    Solution for anyone who used the Android beta 3.1.8:
    Stop the TeamSpeak application.
    Open TS3/cache on your SD card on your device.
    Delete affected or all folders.
    Now use the application again and the client will download the icons (as long file transfer works on server).
    i moved the thread to Android section and removed Server 3.1 from title.
    This is not a server bug.
    edit
    Sorry for the circumstances.
  5. #170
    September 2017
    49
    Hi dante, thank you for your reply.
    I think it's a 3.1.0 server problem, because when I access with teampeak android teams on all the other servers that are not 3.1.0, the icons are normally visible...
    I also tried to clean up the cache, and reinstall teamspeak on Android, but nothing changes.
    What should I do?
    Thank you
  6. #171
    18,409
    Can you please send me the server in a private message?
    I will check that it when I'm back in the office.
  7. #172
    September 2017
    49
    Icons are not only visible on version 3.1.0 2 beta
  8. #173
    18,409
    I mean a server address
    Do you test in your LAN or a server we still can reach later?
    Edit
    Got your private message. You don't have to answer.
  9. #174
    September 2017
    49
    On teampeak server 3.1.0, I added the snapshot of the virtualserver, which I had created when using version 3.0.13.8, can this be the problem somehow?
    Thank you
  10. #175
    18,409
    Are the files still there on your server?
    It could be that you have the same problem with your pc client, when you clear the cache there too.
  11. #176
    September 2017
    49
    Yes, all the files are still on my server, no on pc, there's no problem, it all works normally.
    Thanks
  12. #177
    18,409
    That's all i need for now.
    Will check with pc when I'm back at my office.
  13. #178
    September 2017
    49
    I noticed that from Teampeak android, on server 3.1.0, you can only see the ServerQuery icon, all the others are not.
    It is strange, however, that the ServerQuery client icon is visible, and the others are not.
    Thanks
  14. #179
    18,409
    Your problem is not a client problem.
    Your set icons do not exist on server or can't be read.
    Here is my output from pc client (with empty cache).
    <08:31:41> The icon for channel "Co-Founder" was not found.
    <08:31:41> The icon for channel "Administratore" was not found.
    <08:31:41> The icon for channel "Moderatore" was not found.
    <08:31:41> The icon for channel "Helper" was not found.
    <08:31:41> The icon for channel "Builder" was not found.
    <08:31:41> The icon for channel "Provino" was not found.
    <08:31:41> The icon for channel group "Unknown (0)" was not found.
    <08:31:41> The icon for server group "Unknown (0)" was not found.
    <08:31:47> The icon for channel "Opfactions" was not found.
    <08:31:47> The icon for channel "SkyWars" was not found.
    When inserting a snapshot your files are not restored. This only works, when you restore the server on same location.
    You need to copy the old files folder to the new server to make it work again or you upload the icons again.
    Thread will be merged to https://forum.teamspeak.com/threads/65614
  15. #180
    September 2017
    49
    I know that the icons are not included in the snapshot, but the icons of the virtualserver and room "Founder" are loaded, and from the client on pc, you can only see them from android no.
    Thanks
  1. Replies: 2
    Last Post: July 16th, 2018, 07:01 PM
  2. Icons (file transfer connection timeout)
    By pown otto in forum Server Support
    Last Post: September 30th, 2013, 04:02 PM
  3. Replies: 6
    Last Post: October 17th, 2012, 05:48 PM
  4. "/file transfer connection timeout" and much more
    By Ziollum in forum Server Support
    Last Post: September 19th, 2011, 10:28 PM
  5. Replies: 5
    Last Post: December 4th, 2010, 07:47 AM
