Page 38 of 39 FirstFirst ... 2836373839 LastLast
Results 556 to 570 of 573
  1. #556
    December 2004
    RF
    3,002
    Quote Originally Posted by Zain Kamran View Post
    I meant to say that I updated my Yatqa client but my teamspeak 3 server not allowing me to add querry to normal clients. How to add querry to normal client please fix that.
    It's not an error in YaTQA or TeamSpeak itself that you can not assign a Query group to clients.
    The server itself does not allow this any longer.
    More about this and a supported way here
    What word in the answer was unfamiliar to you?
  2. #557
    4,335
    3.9.6-rc1 displays a new explanation when "servergroupaddclient" fails with code 512:
    In server version 3.6.0, TeamSpeak removed the option to add voice clients into query groups, a feature that has always been deprecated. This – or a client that doesn’t exist – is the most common reason for this error.
    TeamSpeak hat in Serverversion 3.6.0 die seit jeher missbilligte Funktion, Voice-Clients zu Query-Gruppen hinzuzufügen, entfernt. Dies ist – neben einem nicht existierenden Client – der häufigste Grund für diese Meldung.
    3.6.0-rc1 is now the current official release for YaTQA.
  3. #558
    July 2017
    I currently own the latest version of Yatqa. However there is a problem with the feature that allows you to change your nickname automatically when connecting to a server. Can you fix it ?
    My nickname doesn't change
  4. #559
    4,335
    Quote Originally Posted by Soulivan71 View Post
    Is version 3.3.x newer than 3.6.0-beta?
    No, it's not.
  5. #560
    July 2017
    I have this version :
    http://prntscr.com/mg2l1i
  6. #561
    February 2019
    Yatqa saying timeout
    So its been a while since im unable to connect yatqa
    Tho other stuff are working . I even tried an other ts freshly installed same machine works.
    But the current says timeout
    Without yaqta giving an erro im unable to fix it.
  7. #562
    17,942
    Read server log 0 for errors.
    Then check your system that ports are opened and listening
    Now check your firewall and that you use the right IP/domain etc..
  8. #563
    February 2019
    I just checked again . Telnet/ssh are not working either.
    Tho same vps/machine. But a new fresh copy
    works fine. My current server ts3.greensgaming.com is working. But unable to connect telnet/ssh/yatqa
  9. #564
    March 2018
    50
    Hello, @numma_cway
    Do you consider an idea to add folders into hosts list in YatQa good ?
    Not good if user have a lot of instances and can't immediately find needed
  10. #565
    4,335
    I don't want to. It would also be incompatible with Windows 7 Jumplists.
  11. #566
    March 2019
    7
    Connection lost -yatqa
    Good morning
    I have a small problem and I am a beginner to solve it myself
    When I log in to the server using the "yatqa" program and go to the "User DB" tab, I have an error
Name:	Bez tytułu.png
  12. #567
    January 2017
    Switzerland
    351
    "Connection established but no data received."
    Could anyone help me out? Happens while connecting to the server.
    Server version: 3.7.0
    YaTQA version: v3.9.6 (12 Feb 2019)
  13. #568
    June 2018
    Germani, Brandenburg
    8
    I have the following problem with Yatqa, connect it normally, but when I change the tab, Yatqa hangs up, and nothing works anymore. Where's the problem?
    server version: 3.3.0
    Yatqa version:3.9.7
  14. #569
    August 2014
    110
    Quote Originally Posted by blackangel1986 View Post
    Yatqa version:3.9.7
    Hello tried already update your servers it will work much better
  15. #570
    August 2014
    110
    Quote Originally Posted by MCGamingDE View Post
    the message says that the firewall has blocked you please enter your IP address IPV4 & IPV6 in the file query_ip_whitelist.txt on the servers (FTP) + restarting the server
    https://ip.lafibre.info/
    Last Post: October 3rd, 2018, 02:21 PM
  2. Replies: 0
    Last Post: August 10th, 2013, 04:25 PM
