Page 40 of 41 FirstFirst ... 3038394041 LastLast
Results 586 to 600 of 603
  1. #586
    September 2016
    Vienna
    10
    Everytime i connect to the server, i get this error message
    How can i fix this?
  2. #587
    January 2017
    47
    Quote Originally Posted by XeruTec View Post
    How can i fix this?
    Be sure that you use the right Port
  3. #588
    4,368
    Quote Originally Posted by NicoleSophie View Post
    Sobald ich über YaTQa rechte vergeben oder endziehen will bekomme ich immer die meldung
    Attachment 18368
    Per TS kann ich die aber kommischer weise vergeben.
    Was bitte mache ich da falsch oder wo liegt da der fehler?
    Gute Frage. Ich vermute, das müsste man via TS und TeamViewer klären. Wenn du das möchtest, bitte eine Mail schicken (hier im Forum oder über die Website). PNs gehen nicht.
  4. #589
    November 2016
    156
    Snapshot name IP/DNS parameter replacement/fix for IPv6
    When creating a snapshot with the IP/DNS parameter YaTQA shows an error while trying to save the snapshot because of the IPv6 illegal file name characters.
    Would be great if the tool would just skip those characters while creating the file, so switching back to an IPv4 connection is not required if you want the IP in the file name.
    A parameter to add the server nickname would be nice to have too.
  5. #590
    4,368
    I'll fix the bug for the next version.
    For the nickname, there are two things that make them a problem: Nicknames are multiline. Also, nicknames are not part of serverlist.
  6. #591
    November 2016
    156
    Maybe you could read out the nicknames from the selected server itself and if there are more than one just give a simple popup which one it should take or just use the first nickname of the server. I would go for the last solution and if there are no nicknames give an error message and overwrite the nickname variable with IP/DNS.
    Thanks anyways for the tool Makes life so much easier!
  7. #592
    February 2017
    Moin moin,
    ich versuche grade per YaTQA einen Channelbaum von einem Server auf einen anderen zu Übertragen. Wie hier beschrieben habe ich den Channelbaum als Datei abgespeichert, auf dem neuen Server sagt mir YaTQA aber folgendes wenn ich versuche die Channel aus der Datei einzufügen:
    Die Abfrage konnte nicht durchgeführt werden.
    Befehlsname: channelcreate
    Fehlertext: invalid parameter
    Fehlercode: 1538
    Weiß jemand Rat?
  8. #593
    4,368
    Von welcher TeamSpeak-Version auf welche TeamSpeak-Version migrierst du? Ziel-Versionen älter als 3.9.0-beta1 werden nicht unterstützt.
  9. #594
    February 2017
    Von 3.10.2 auf 3.10.2, beides Linux.
  10. #595
    4,368
    Dann bitte den Channelbaum per Mail schicken.
  11. #596
    February 2017
    Wie lautet denn die Adresse? Leider finde ich die grade nicht, sorry falls ich grade blind bin
  12. #597
    March 2010
    6
    ich musste aus einem Snapshot einen Server wiederherstellen dabei wurden folgende Sachen nicht gesichert/wiederhergestellt:
    Channel Rechte (alle auf 0 nirgendwo sind diese gesetzt [Betreten FileTransfer etc])
    ICONS - kein einziges Icon wurde gesichert / wiederhergestellt
    die Icons sind sicherlich schwerer zu sichern die Rechte der Channel wären für die Zukunft jedoch eine tolle Sache
  13. #598
    4,368
    Solange es sich bei dem Snapshot nicht um einen "Pseudo-Snapshot" (Snapshot ohne ASQ-Rechte) handelt, hat die Frage nicht mit YaTQA zu tun und gehört nicht in diesen Thread.
  14. #599
    March 2010
    6
    woran das kann ich die Snapshots unterscheiden? ich hatte damals einen ASQ account angelegt mit welchem ich seitdem YaTQA benutze dieses habe ich wiederhergestellt das mit den Channelrechten scheint zu teilen doch funktioniert zu haben jedoch hat die zuordnung der rechte zu den jeqailigen channels absolut nicht funktioniert vermutlich liegt dies an der Channel ID.
    Die ICONS gehen wohl auf meine kappe da ich nicht gesehen habe das diese eine eigenen file backup funktion benötigen
  15. #600
    December 2019
    Yatqa issue
    Currently have this issue when opening hyperinks or joining my teamspeak servers from the Yatqa program.
    - https://gyazo.com/37deb301a2d886311ebc499d1f706a33
    And then I get this issue when im uploading a server backup (snapshot) of a current server im running
    - https://gyazo.com/91225ea071cc6d657405cd1b5afe6fd5
    Been looking for a fix but I have yet to find one
    Anyone help?
    Last Post: October 3rd, 2018, 03:21 PM
  2. Replies: 0
    Last Post: August 10th, 2013, 05:25 PM
