Page 7 of 40 FirstFirst ... 5678917 ... LastLast
Results 91 to 105 of 588
  1. #91
    2,029
    I just checked again and can definitely say that I am right. A query client gets its permissions from query groups only. I created a standard group with some testing permissions. Then I made a copy of that group but as a query type. If I put a test user in only the standard server group, he only has the query guest group permissions when using the query interface, but is unaffected by the standard group. If I put him in the query group, he gets that group's permission (but loses the guest group ones, but that does not care). You can try yourself.
    I would need to do some checks on Query Users and their Permissions again myself since I haven't bothered with this for a couple versions.
    But in any case: What does this (the fact where/how Query Users get Permissions from) to do with anything?
    Fact of the matter is that whatever Credentials he is using (be it global default serveradmin, any manually hacked in global Query account, a Guest Query session or a query Login on his own Unique ID created using the Client) he is lacking the b_icon_manage Permission which is required (regardless of credentials used) to change Icons.
    Since he is missing that he cannot do it and needs to add that Permission, which btw. is all I said. I never even mentioned where or how he needs to add that permission as I neither know nor really cared about how or with what credentials he is using your Tool. He should know what Credentials he is using your Tool with and thus also know where to add the missing Permission, in case he doesn't he could always just ask in which case I or someone else would've requested the required information to help him properly. Since as of now he didn't ask for any more help he was either satisfied with my answer and managed to add the Permission required or didn't read the reply yet.
  2. #92
    4,351
    If you are a normal Server Admin and create a Query Account in the client, it will not work properly for query. Maybe the user created such an account instead of using the serveradmin query account. That's all.
    BTT: I fixed a bug with YaTQA where the UTF-8 decoder did some bad work. It was a workaround for a bug in the old version of Delphi, but it is not necessary in the current version anyway. If you downloaded YaTQA within the last few hours, please download again.
  3. #93
    July 2002
    Stockholm, Sweden
    34
    Greetings!
    I love your tool and find it a excellent addition to someone like me who doesn't have time to get gritty with the different syntaxes for the standard query tool.
    I have one issue though. If I head in to one of my virtual servers and try to even look at the permissions I get this error.
    Either I am missing something completely or my serveradmin account is missing some permissions which is weird since I can basically do everything else except work with the permissions on the different virtual servers at all.
    Thanks in advance.
  4. #94
    4,351
    This thread is for YaTQA-related issues only.
    General questions on how to get your server running belong to the Server Support forum, as they are not related to YaTQA in any way. YaTQA is just a wrapper for commands. E.g. if TeamSpeak crashes on your Windows computer, I doubt that Microsoft can help, so can't I.
  5. #95
    July 2011
    10
    Hy there,
    Can I found this program for linux? Or smthg like this..? Thx.
  6. #96
    July 2006
    1,600
    Quote Originally Posted by LaN4CSW View Post
    Hy there,
    I think the author wrote something about WINE compatibility. You need to check this.
  7. #97
    This is a error i keep getting if someone can help would be nice.
    Socket-Fehler#10061Verbindung abgelehnt
  8. #98
    4,351
    Make sure to use the actual server query port (defaults to 10011) and not the voice port. The query port may have been changed by the owner. Please also make sure to use serveradmin credentials. YaTQA is not made for limited permissions. Additionally, the server adress might be incorrect due to TSDNS.
  9. #99
    June 2012
    8
    Server Admin Password
    Hello guys .
    i use server admin password in a program called yatqa but today when i tried to enter in it it didnt work it says that password is wrong i also tried to change pw from shortcut like serveradmin_password=password but nothing . so any help please
    Dear roun512 .
  10. #100
    4,351
    Just noticed that topic got moved here. Please read this topic. There is nothing more I can do.
  11. #101
    November 2012
    Question Yatqa Problem
Name:	Ekran Alıntısı.JPG
    What is this Problem ?
  12. #102
    UK
    768
    Just installed this program...great job!!
    Just one question, in the statistics section there is a shutdown button right next to a refresh button. I'm hopeless with a mouse so if I accidentally hit the shutdown button instead of refresh, will it ask for confirmation?
  13. #103
    UK
    768
    What credentials are you using to log in? Serveradmin or ordinary user?
  14. #104
    November 2012
    serveradmin
  15. #105
    UK
    768
    Have you tried logging in as serveradmin via telnet?
    Last Post: October 3rd, 2018, 02:21 PM
  2. Replies: 0
    Last Post: August 10th, 2013, 04:25 PM
