Results 1 to 3 of 3
    September 2010
    problems with database error
    i used the linux based tutorial on top in this forum. Now i have a problem.
    I used the ts3server.ini from the thread, insert my own ip's from the server and loaded it up.
    when i use ./ts3server_linux_x86 inifile=ts3server.ini
    following comes in command
    TeamSpeak Server 3.0.0-rc1 [Build: 14468]
    (c)Teamspeak Systems GmbH
    Logging started
    2011-07-03 17:32:04.902634|INFO |ServerLibPriv | | Server Version: 3.0.0-rc1 [Build: 14468], Linux
    2011-07-03 17:32:04.903193|INFO |DatabaseQuery | | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2011-07-03 17:32:04.903236|CRITICAL|DatabaseQuery | | unable to load database plugin library "libts3db_mysql.so", halting!
    I use it with libts3db_mysql.so and the libts3db_sqlite3.so . I changed the parameters to in the ts3server.ini
    How can i fix this problem? Need help thx
    September 2010
    Edit: I used too ./ts3server_minimal_runscript.sh inifile=ts3server.ini
    The server starts yeah. But when i close putty, the server close too! Thats bullshit. The vServer have to run 24/7 without my putty console from my desktop pc.
    May 2010
    6,310
    You have to use the startscript.sh
    Edit it and write this :
    COMMANDLINE_PARAMETERS="inifile=ts3server.ini ${2}" #add any command line parameters you want to pass here
    Now use this : ./ts3server_startscript.sh start
    Info:
    This question has been answered many times on this forum. Please, next time use the search function or read the documentation.
